r90/6 master cylinder leak
Discussion in 'Old's Cool' started by Kitchen, Feb 2, 2011.
  1. Kitchen
    Kitchen Adventurer
    Jan 20, 2011
    25
    Northern Kentucky
    My master cylinder is leaking, I hate to have to spend all that money on a rebuild kit:cry I can't need anything more than an o-ring? Is it possible to fix with out the rebuild kit? Anybody ever remove the C clip and pull it apart and just replace the o-ring?? I need a cheap quick fix:ear:ear
  2. gplane
    gplane Putty Conjugator
    Nov 23, 2007
    1,649
    Rat Cheer.
    $65 the last time I bought one. [rebuild kit] A master cylinder is upwards of $350. No cheap fix there.
    Often they become pitted in the bore, and have to be resleeved to be rebuilt.
  3. Wirespokes
    Wirespokes Beemerholics Anonymous
    Jul 26, 2002
    9,677
    Jackson's Bottom Oregon
    It appears your mastercylinder is fine.
    Does it work properly?
    Normally, when they leak (and are malfunctioning) you'll see rust and crud around the piston. Yours doesn't have that, instead it's rusty on top which tells me the reservoir o-ring is bad. It seals the reservoir to the body of the mastercylinder.
  4. Kitchen
    Kitchen Adventurer
    Jan 20, 2011
    25
    Northern Kentucky
    The bike had been sitting for over 5 years. Now I'm tring to get her back on the road. The mastercylinder was bone dry. I filled the sytem and bleed the brakes. They now work but fluid is comming out around the piston bore for sure. I guess I'll be getting the rebuild kit.
  5. Wirespokes
    Jul 26, 2002
    9,677
    The piston normally doesn't travel the full length of the bore, except when the brakes are being bled. In the unused untraveled portion some corrosion or gunk can build up, then when the piston is forced into that section, the seal gets compromised.
    Rebuilding is a good way to go, and if it's badly pitted in the normal travel area, it can be re-sleeved for much less than new. Once re-sleeved it should be good for another 30 years at least.
  6. bmwhacker
    bmwhacker Still on 3 wheels
    May 6, 2009
    4,959
    MONTANA NATIVE from NATIVE MONTANA
    +1.... and your life could depend on that $65.00 rebuild kit. I cleaned up my master cylinder prior to rebuilding with some very fine crocus cloth as it was not pitted, but had some surface crud in the bore in the untraveled portion. Works fine.
  7. Mista Vern
    Mista Vern Knows All - Tells Some.
    Dec 1, 2005
    25,203
    McMinnville, Oregon
    Handy tip: I wound that putting the end of a .22 cleaning kit on a drill and using fine emory cloth I could give master cylinders a good hone to clean them up.
