Old 09-19-2012, 06:07 PM   #1
hodgie441 OP
Oddometer: 3
Laugh R1200GS ESA Disable?
I have a 2012 R1200GS that is equipped with ESA. I want to upgrade my suspension to Ohlins, but I don't really want to dish out the $$$ for the mechatronic setup. I was wondering is there a away to disable the ESA so I don't get a warning light or trouble light? I was thinking of getting the good old manual adjustment Ohlins front & rear shocks. Any help or advice would be greatly appreciated, thanks.
Jeff
hodgie441 is offline   Reply With Quote
Old 09-20-2012, 04:27 AM   #2
aschnell
Oddometer: 92
I just put yacugar manual shocks on my 09 gsa with esa and I don't get any warning lights.
aschnell is online now   Reply With Quote
Old 09-20-2012, 04:52 AM   #3
aGremlin
aGremlin's Avatar
Oddometer: 395
You should be able to simply unplug the OEM suspension, seal up the connectors for safety and use other suspension.
When the ECU cannot read the OEM gear it does generate an error in the logs, but that's pretty much it. Shop will see when they connect to the bike and clear it...
Warning: My post quality varies according to my mood. If I sound sane give it a few minutes and I'll be back to normal
aGremlin is offline   Reply With Quote
Old 09-20-2012, 07:42 AM   #4
Some Dude
what attitude problem???
Some Dude's Avatar
Oddometer: 4,609
Send a message via AIM to Some Dude
I am pretty certain BMW changed the software so that the criteria for the warning light was for malfunctioning ESA instead of "missing" ESA. This seemed to have happened coincidently when they shifted to WP as the ESA shock manufacturer mid 2010. It would also appear the software has been updated in older units now so that when ESA is unplugged it will not generate a warning light, but will generate a soft fault in the data log for technician to see with diagnostics.
Just some dude on the internet,..
Some Dude is offline   Reply With Quote
Old 09-20-2012, 08:34 AM   #5
jimmex
Guero from SanAngelo
jimmex's Avatar
Oddometer: 1,433
Jeff
Unplug it and enjoy your new suspension.
Guero from San Angelo
jimmex is offline   Reply With Quote
Old 09-20-2012, 12:12 PM   #6
hodgie441 OP
Oddometer: 3
Thanks so much for all the info!
Times are GMT -7.   It's 12:10 PM.
