F650GS Fuel Question
Discussion in 'Parallel Universe' started by skysailor, Aug 11, 2013.
  1. skysailor
    skysailor Rat Rider
    Oct 3, 2007
    5,019
    Kenora, Canada
    Okay, the owner's comic book calls for regular.
    Most regular fuel up here in the GWN has at least 10% ethanol.
    My dealers says avoid regular fuel. He means containing ethanol.
    I use regular with NO ethanol.
    What do you Yanks do? Doesn't almost all of your fuel contain ethanol?
    Lyle
  2. vtbob
    vtbob wanderer
    Jun 20, 2009
    697
    Western Vermont
    Yep Most of out fuel contains ethanol.
    The F650 and all other F800 are designed to work well with ethanol. all the parts...the ignition timing etc
    Having said that, unless it is winter and you have a water in tank condensation problem (ethanol absorbs water good some times bad others)...you are better off with straight gas. You will get slightly better gas milage...more energy in a Oz of gas vs an Oz of ethanol.
    Ethanol is an octane booster..ie anti knock..which helps in a high compression engine like the 800s....so to get regular straigth gas to get to the right octane they have to use other additives...also a mixed bag.
    bottom line don't worry....biggest change is long term storage life of the 10% ethanol fuel ...over winter seems ok here but some have had problems
  3. Pete7874
    Pete7874 Been here awhile
    Jul 3, 2013
    409
    Michigan, USA
    No ethanol-free gas at all around where I live.
