Leaking final drive.
Discussion in 'Airheads' started by rayford, Feb 11, 2014.
  1. rayford
    rayford n00b
    Apr 30, 2005
    3
    Looking for someone in Charleston, SC area that works on Airheads.
    I have a 1992 r100r that is leaking between the final drive and drive shaft boot.
    Any direction would be a great help.
    Thanks.
  2. ME 109
    ME 109 Long timer
    Jun 25, 2009
    9,192
    Albury Australia
    Do you mean the rubber boot is leaking?
    Is it leaking from the front or rear of the boot, or does the boot have a hole in it?
    Welcome to the nuthouse.
  3. Big Bamboo
    Big Bamboo Aircooled & Sunbaked
    Sep 29, 2010
    17,403
    Big Island of Hawaii
    I would check the oil levels in the rear drive AND transmission ASAP. The oil should be level with the bottom threads on the fill hole, approximately, with the bike on the center stand. Just because it's leaking from the rear boot doesn't mean the oil isn't coming from somewhere higher up. If the results are inconclusive, drain both and refill with a measured amount, then ride it for awhile and drain and measure what comes out. As always, pictures would be a plus...
  4. patrkbukly
    patrkbukly Life at 10,000 feet Supporter
    Sep 28, 2002
    3,664
    Fairplay, CO
  5. ME 109
    ME 109 Long timer
    Jun 25, 2009
    9,192
    Albury Australia
    Yeah, either blonde or brunette is ok.
  6. patrkbukly
    Sep 28, 2002
    3,664
    Fairplay, CO
    careful because I may not want to see a leaking "Final Dtive" on a blonde OR Brunette.
  7. rayford
    rayford n00b
    Apr 30, 2005
    3
    Looks like it is leaking from the rear of the boot. I have a pic but having trouble posting it. I will check the oil level when I get back home.
    Thanks for the input.
  8. AntonLargiader
    AntonLargiader Long timer
    Aug 28, 2003
    8,431
    Charlottesville, VA
    Could be trans oil that has leaked down the swingarm due to a bad output shaft seal or unplugged vent notch, or from a leaking pinion seal on the FD. Some of the Paralever trans seals from those years delaminate and leak after a while.
    Change the trans oil to a different color than the FD oil and see what color continues to accumulate inside the boot. This is not a critical issue at all.
    #8
