2004 950 Adv S Alarm Use Instructions
Discussion in 'Dakar champion (950/990)' started by cooneyr, Jul 9, 2009.
  1. cooneyr
    cooneyr terra firma rider
    Dec 15, 2005
    520
    Christchurch, NZ
    Gidday. My new to me 04 Adv S has a factory alarm fitted and while it came with the fitting instructions it didn't come with any instructions on how to use the alarm. Is there any? Ive done a few web searches with no luck. If not whats the deal, what does the yellow and red button on the remote do?
    Cheers R
  2. cooneyr
    Dec 15, 2005
    520
    Christchurch, NZ
    Nobody? Surely someone out there has a factory alarm in an 950? Can you give me a brief written description of how to use the alarm.
    Cheers R
  3. mookymoo
    mookymoo Mookish Mook
    Aug 26, 2007
    4,451
    Either UK or Australia ...
    The Red (LH) (1) button arms. (bip)
    The Yellow (RH) (2) button disarms. (bip-bip)
    Pressing both at the same time will set the alarm off (panic function)
    You can disable the alarm by turning the key on, press-and-hold (2) for 5 seconds. (1 bip = disabled, 2 bips = enabled).
    When enabled, the alarm will auto-arm 3 mins (iirc) after the ign is turned off.
    If you PM me your email address, I will see if I can scan the instructions & email them to you.
  4. thugdog
    thugdog Druid Revisionist
    Sep 17, 2004
    396
  5. cooneyr
    Dec 15, 2005
    520
    Christchurch, NZ
    Thanks for the info guys. Will give it ago later tonight.
    Cheers R
