1100 GS - removing BOTH wheels at the same time?
Discussion in 'GS Boxers' started by kfsinc, Jun 5, 2013.
  1. kfsinc
    kfsinc Chaingolian Observer Supporter
    Aug 12, 2003
    2,876
    Salem, SC
    Time for new shoes on my GS.
    I usually take it to a local wrench, but got a very good deal on a set of Anakee2s. I plan to remove the wheels and have him mount and balance the new tires. Any suggestions on removing BOTH at the same time and keeping the bike balanced on the center stand? Milk crate under the front forks?
    TIA!
  2. biometrics
    biometrics Been here awhile
    Aug 11, 2011
    144
    Northern Virginia
    Put a bike stand (or milk crate) under the engine, another milk crate under the forks, or a jack stand under the axle that has been reinserted into the forks...
    Tie down straps (not bungee straps) to balance it ... you can attach the other end to the garage door supports overhead...
    Most of all use common sense, and BE CAREFUL and don't work alone. :eek1
  3. def
    def Ginger th wonder dog
    Feb 28, 2004
    14,308
    The woods and mountains of Alabama
    Here is how I have new tires installed. I bring the needed tools (no torque wrench) with me to the installer.
    Put the bike on the center stand on a secure, level surface.
    Remove the rear caliper and then the rear wheel and have the new rear tire mounted.
    Prepare the front wheel for removal while the rear tire is being installed. Once the new tire is mounted, install the rear wheel and then removed the front wheel.
    As the new front tire is being fitted, I completed the rear wheel installation and fit the rear caliper.
    Once the new front tire is fitted, completed the wheel installation. Once back at your garage, torque all fasteners as needed.
    This way, there is no danger of the bike coming off the center stand and you don't tie up the installer. It can all be done in 30 minutes.
  4. mouthfulloflake
    mouthfulloflake Not afraid
    Aug 21, 2008
    37,174
    The Berkeley of Arkansas
    lay it on its side?
  5. kfsinc
    Aug 12, 2003
    2,876
    Salem, SC
    That's exactly what I DON'T want to happen :lol3
    I'm going to try the jack stand method and see if I'm comfortable with it -- if not, two trips may be in order.
    kfs
  6. mouthfulloflake
    Aug 21, 2008
    37,174
    I was serious...
    :D
  7. kfsinc
    Aug 12, 2003
    2,876
    Salem, SC
    Understood and I actually thought about that -- it certainly wouldn't be the first time she's been down.
    We'll see how the other method works first -- I'll report back.
    kfs
  8. reBARman
    reBARman Been here awhile
    Apr 16, 2007
    540
    Seattle
    I usually remove the rear first. Then rest the final drive on something that keeps the front of the bike tilted upward. Then remove the front. As a side note I have gotten into the habit of securing the center stand to the front of the bike to keep it from folding over if it's knocked or something.
    #8
  9. GS&S1K rider
    GS&S1K rider Adventurer
    May 28, 2013
    12
    SoCal
    on the regular inline 4 bike, K13S or S1000RR, the dealer would use the exhaust manifold as point to jacked all the weight of the bike for the tire change. However, i will think using regular front stand plus some playing weight distribution method on the center stand should suffice...no?
    #9
  10. jaak
    jaak Adventurer
    Dec 7, 2008
    69
    Estonia
    I removed the rear one first and tied it down.
    But if you try to losen the strap even an inch... :evil been there done that.
    #10
  11. 200GRLSWC
    200GRLSWC Been here awhile
    Apr 22, 2013
    192
    How did you get it up on the table in the first place? Jump it up? :lol3
    #11
  12. Ua the Destroyer
    Ua the Destroyer Been here awhile
    Sep 30, 2011
    466
    Portland
    From some old thread on here I learned the trick of strapping the center stand forward so it cant fold back. Then remove the rear and gently set it down on the final drive (with some kind of pad underneath). Now the nose is skyward and you remove the front wheel. No extra stands needed. I wouldn't recommend this in a high traffic area though.
    #12
  13. Ua the Destroyer
    Sep 30, 2011
    466
    Portland
  14. WoodButcher
    WoodButcher Long timer
    Sep 17, 2004
    2,398
    Austin, TX
    I strap the center stand as mention above so it won't fold back up. Take off the rear tire. Then I have a short sawhorse that just fits under the GSA rear pannier crossbar. I put it there and then use a jack under the front of the motor to slowly raise the front. The sawhorse keeps the bike from tipping too far back and the bike sits stable that way. Then the front comes off.
    Hope that helps. Oh, and if it is going to be more than a couple of hours I put a block of wood under the front in case my hydraulic jack starts to lose pressure.
    #14
  15. Racegun
    Racegun Single Track Mind!
    Jun 14, 2005
    3,103
    Cajun Land!
    i like and use "def"'s idea.... works like a charm if you are accomplished enough to tighten fasteners w/o torque wrench
    #15
  16. def
    Feb 28, 2004
    14,308
    And we are all skilled enough not to over tighten if we use a wrench without a long handle. I like the OE toolkit. But, do check those rear wheel bolts with a torque wrench once you get back to the house.
    #16
  17. Y E T I
    Y E T I Unpossible
    Apr 26, 2007
    8,521
    San Diego
    This is very important. Don't ask me how I know. Don't ask me about the scratches on the side of my tank either. :augie
    Keep in mind that whichever wheel you remove first, the bike will be lighter on that end and tilt the other way. If you remove the rear wheel first, be prepared for the bike to rock forward and vice versa. I remove the rear wheel first and put an appropriate sized Pelican case under the final drive with a towel for padding. Since the 1100 is rear weight balanced (at least I believe mine was), it was good to go to then take the front off.
    It's also always a good idea to have someone to help ensure the bike doesn't rock forward or back when you don't want it to.
    #17
  18. kfsinc
    Aug 12, 2003
    2,876
    Salem, SC
    It works!! At lease it was standing last time I checked...
    See below --
    1. I used a cable to secure the center stand and bungees on the handle bars to keep the front end stable.
    2. I removed the brakes, front and rear, then took off the front wheel and reinserted the axle.
    3. I rested the axle on a jack stand.
    4. I then positioned my floor jack with a towel on it under the torque arm attachment point on the final drive and lifted it just enough to get the back wheel off the ground.
    5. I removed the back wheel and gingerly stepped away :clap :clap :clap
    I lowered the jack ever so little to see where the balance point is and as expected, about 95% of the weight is on the center stand. She's a little back-end heavy, but can be balanced with one finger. I raised the jack just enough to put some pressure on the front axle, and she's very stable.
    Total time: 45 minutes -- about how long the conference call I was on during the project lasted. :wink:
    Wheels and tires are in the shop now and I expect to be re-installing and riding tomorrow.
    #18
