Old 08-23-2014, 01:36 AM   #16
murdock84
Oddometer: 550
I took a wheel with everything needed to a local shop and it cost $30 to take the old tire off and put the new one on and balance. I just couldn't get the front tire off by hand. It just cost me my time for the rear though.
murdock84 is offline   Reply With Quote
Old 08-26-2014, 10:21 AM   #17
sparkymcgee
sparkymcgee's Avatar
Oddometer: 335
Originally Posted by mosey.levy View Post
Researching doing it myself. God bless the you tubes.
Sent from my iPad using Tapatalk
That's all I did. It is easier than you think. Just remember to take your time. If you are working too hard, you're probably doing something wrong. Step away before you get frustrated and come back to it later. Here are the tools I invested in:
Motion Pro Bead Breaker:
http://www.amazon.com/Motion-Pro-08-.../dp/B008OXIYM6
Levers:
You can use the levers that are part of the Bead Breaker, but I bought some more. It's nice to have at least 3, I've found. Something like this:
http://www.revzilla.com/motorcycle/c...ro-tire-levers
Rim Protectors
You can use cut up milk cartons, but I sprung for these. I also found life to be a lot easier by having 3 of them, which means 2 sets:
http://www.revzilla.com/product/moti...rim-protectors
Lubricant:
Spray it all over the tire bead and lip of the rim. Overdo it. I use some dish soap and water in a spray bottle.
Use the new tire as a tire changing stand while removing the old tire. Then use the old tire as a stand when installing the new tire. That will keep your rotor/sprocket off the floor. You can also use some sections of 2x4.
As you said, google lots of videos to watch people do it. Your first change might take an hour. Your subsequent changes will easily drop to under a half hour.
Good luck and if you have any problems or questions, just post here and you'll get help.
2008 VFR800
2012 Super Ténéré
sparkymcgee is online now   Reply With Quote
Old 08-26-2014, 10:23 AM   #18
mosey.levy OP
mosey.levy's Avatar
Oddometer: 937
Thanks guys. That's actually an awesome informative post above.
I ended up finding someone locally through advrider. He reached out to me and changed my tires for $40 each.
I watched him do the entire thing. He had tons of awesome tools specially for the job. Balanced and all.
aka motech
http://city-gs.com/
mosey.levy is offline   Reply With Quote
Old 08-26-2014, 10:50 AM   #19
Pete7874
Pete7874's Avatar
Oddometer: 408
Which tires did you end up buying?
2013 F700GS
Pete7874 is offline   Reply With Quote
Old 08-26-2014, 10:51 AM   #20
mosey.levy OP
mosey.levy's Avatar
Oddometer: 937
K60
http://city-gs.com/2014/08/26/heidenau-k60/
aka motech
http://city-gs.com/
Old 08-26-2014, 10:58 AM   #21
Pete7874
Pete7874's Avatar
Oddometer: 408
Thanks. Planning on doing lots of non-paved trails?
2013 F700GS
Old 08-27-2014, 06:43 PM   #22
LavaFrog
LavaFrog's Avatar
Oddometer: 70
diy
K60 trailside tube change was one of the most difficult tires to wrestle in the rough. A bar of soap would be a good addition to the trail bag instead of toothpaste.
Yikes! Two bills for changing out tires at a shop is a bit much = would rather put it towards- 2 rear 18" tires - although, 40$ ea. change is not bad, heh, k60 full change is something I would rather watch than do myself.
Can't agree more with sparkymcgee - Some good items and tips there.
That amount for two tires and the waiting and scheduling and transporting to the shop can easily set yourself up with your own changing station tools.
I use - http://www.motosport.com/dirtbike/Mo...Changing-Stand
Leaving the rubber in the Sun and using lots of soap is key! Like the milk carton rim protector idea. As mentioned, two in the kit is good but one more would be perfect.
K60
LavaFrog is offline   Reply With Quote
Old 08-27-2014, 10:49 PM   #23
Dadayama
Constant Adventurer
Dadayama's Avatar
Oddometer: 587
Ok... here is the deal about changing tire that everyone who does it knows and i'm guessing everyone else doesn't....
IT IS REALLY NOT THAT HARD TO CHANGE YOUR OWN FRIGGIN TIRES...
there i said it... really ... i have done if four times with no formal training other then youtube.... actually the four times is on my bike... have done more then i can count doing other peoples tires...
Anyway... please don't pay someone unless you have some physical limitations, have no arms, or, you are stupid rich...
Ich Fahre Nicht Zu Schnell, Ich Fliege Nur Niedrig
Oklahoma Adventure Trail
YouTube
Dadayama is offline   Reply With Quote
Old 08-28-2014, 07:20 AM   #24
Reaver
Outta Here
Reaver's Avatar
Oddometer: 3,080
I call it "office hands".
Life is a Rollercoaster and I'm not strapped in!
Leaving it all behind 2014
Reaver is online now   Reply With Quote
Old 08-28-2014, 07:32 AM   #25
FredRydr
Danger: Keep Back 500 Ft.
FredRydr's Avatar
Oddometer: 2,460
Changing tires is fun. Yeah, riiight. But it must be done, and it's better to know how than not. Be careful not to gouge alloy wheels near the bead surface, though.
My F800GS wheels and tires awaiting my love and attention:
Fred
FredRydr is offline   Reply With Quote
Old 08-28-2014, 07:37 AM   #26
Reaver
Outta Here
Reaver's Avatar
Oddometer: 3,080
Fred
Speaking of Office Hands..................
Old 08-28-2014, 08:14 AM   #27
FredRydr
FredRydr's Avatar
Oddometer: 2,460
May your tire irons find their way under your fingernails.
Fred
Old 08-28-2014, 11:37 AM   #28
LadyNerdRider
LadyNerdRider's Avatar
Oddometer: 3
Tire changes on the road
I was on a trip and got a puncture (close to the sidewall). It all worked out as I was in Wisconsin and was able to rely on the kindness of strangers. Plus, I discovered the president of the local MOA had his phone number published on his website. He was a great help.
My partner says he really doesn't want to have to change a tubeless tire on the road because it's so hard to get the tire on and off. I assume it's harder than a tire with a tube, but how difficult is it really?
LadyNerdRider is offline   Reply With Quote
Old 08-29-2014, 05:03 AM   #29
Loutre
Cosmopolitan Adv
Loutre's Avatar
Oddometer: 3,607
just as easy if you have filled out your profile first
Really I find the difficulties arise more from the tire than from the rim. Well I changed the tires of an englishman who had a puncture in his tube on a 76ish suzuki 750. Easiest tire change in history, litteraly took me 9minutes with time to unmount and put it back it on the bike.
On my boxer it is a bite more pita due to the design of the rim but takes me a bit longer but not that much. just use your sidestand to break the beat and you're good to go :o)
Keep the smile on your face!
You can be imitated but not replaced. You're such a special blend the recipe is guarded like KFC's 11 herbs and spices.
Homeless Otter on the road – One month to find the rising sun
Loutre is offline   Reply With Quote
Old 08-30-2014, 12:11 AM   #30
MTrider16
Ridin' in MT
MTrider16's Avatar
Oddometer: 1,668
I usually buy my Conti's from a local Honda dealer, if I take the wheels off the bike and bring them in, he usually works out a reasonable price. Looking at the price and comparing the online price, I probably am paying about $30 a tire to have them mounted.
David
'13 VFR1200D, '13 XVS950, '09 F800GS, 07 CRF250X
Riding roads in Montana - Big Sky Country
www.mtrider16.smugmug.com
Mountains, Moose, and Miles: a Montanan's Alcan Highway Story
Continental Divide and More: the "No Dust" Tour of WY and MT
MTrider16 is offline   Reply With Quote
Times are GMT -7.   It's 03:49 PM.
