Old 10-15-2005, 10:16 AM   #1
Crush OP
Oddometer: 992
Restoring an R75
I am in the process of restoring / rebuilding an R75/6 and need a little direction on refinishing the engine and transmission cases and other unpainted aluminum castings. The castings are dirty from years of use and have the associated aluminum tarnish. I know I can clean it up to looking like new, but how do I keep it looking nice? Any suggestions?
TIA, Dennis
Crush is offline   Reply With Quote
Old 10-15-2005, 12:16 PM   #2
Team Dennis
Certified Troublemaker
Team Dennis's Avatar
Oddometer: 4,538
Etching mag wheel cleaner should get it clean but keeping it clean is a whole different can of worms.
Team Dennis is offline   Reply With Quote
Old 10-15-2005, 12:27 PM   #3
Andrew
Optimus Primer
Andrew's Avatar
Oddometer: 15,764
I've seen Airheads that had silver paint rubbed into their pores with scotchgard pads - pretty impressive to look at, if you're into making your bike look purdy.
Splitting lanes, and splitting hairs.
Andrew is offline   Reply With Quote
Old 10-15-2005, 05:25 PM   #4
gsweave
Yinz, blinkers are on.
Oddometer: 11,905
Use of kerosene, as your regular choice of cleaning agent on the motor will keep it very nice and clean for years and years. Will also keep the bugs down around the driveway.
I would worry about using paint, as recommended above. Once you do that, even glass beading may not remove the paint due to the porous nature of the casting.
1 Peter 2:16 Live as free men, but do not use your freedom as a cover-up for evil;... .
gsweave is offline   Reply With Quote
Old 10-15-2005, 05:30 PM   #5
Andrew
Optimus Primer
Andrew's Avatar
Oddometer: 15,764
Agree,Kero kept my R80's jugs and case looking fine. Applied with old toothbrushes and rags.
I didn't say it was good for the engine, just that it was pretty to look at. If that's what someone's after... I wouldn't want anything adding thermal resistance to the parts that need to shed heat.
Old 10-15-2005, 08:46 PM   #6
mneblett
Professional Lurker
Oddometer: 151
This may sound strange, but I had excellent results when restoring my SWMBO's R75/5 and with removing a bunch of surface corrosion from a later R100 engine with WD-40, green ScotchGuard pads and elbow grease. A couple benefits: a not very aggressive combination (better too little than too much at first), and leaves a bit of a protective coating behind from the WD-40.
mneblett is offline   Reply With Quote
Old 10-15-2005, 08:52 PM   #7
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,709
Yah man, the dude who was keeping his R90/6 in my garage spent many a night with wd40 and fine steel wool.. Cleaned it up nice..
Boon Booni is online now   Reply With Quote
Old 10-16-2005, 06:43 AM   #8
gsweave
Oddometer: 11,905
WD is great choice. Kerosene is sold at 1.59 per gallon. Same results, I am frugal.
Old 10-16-2005, 09:03 AM   #9
KL5A
Bugs are the new black
KL5A's Avatar
Oddometer: 4,480
I'd suspect that kerosene has gone up a bit lately. A fiver here is $30, up from $20 last winter.
HACKSAW: One of a family of cutting tools built on the Ouija board principle. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
Only dead fish go with the flow.
KL5A is offline   Reply With Quote
Old 10-21-2005, 08:09 AM   #10
mitch
mitch's Avatar
Oddometer: 1,326
Thumb
A good soak in molasses will clean them to start with. Then its up to you
mitch
02 GSA written off by a DRUNK in pickup.
04 GSA Written off by a pickup.
06 GSA . SE. will try to stay away from pickups.
Well it was a car this time #L/tib & fib in the same place as the previous F wit crushed it
Ducati making mechanics out of riders for 50 years
mitch is offline   Reply With Quote
Old 10-21-2005, 09:35 AM   #11
mneblett
Professional Lurker
Oddometer: 151
When I was researching how to clean up the engine, someone mentioned that steel wool shouldn't be used because it can leave behind minute bits of steel imbedded in the aluminum, which later rust. I have no idea whether that's true, but I avoided the issue by using the Scotchbrite pads,
Times are GMT -7.   It's 08:13 AM.
