Old 10-21-2005, 11:37 AM   #1
MY ADV OP
"ZERO.. POINT.. ZERO"
MY ADV's Avatar
Oddometer: 493
Ktm 950 Adv - Head Shake
MY 2005.5 KTM 950 ADV, HAS A MEAN HEAD WOBBLE WHEN YOU CHOP THE THROTTLE FROM 50+MHP DOWN THROUGH 40MPH. IF YOU USE A LIGHT GRIP ON THE BARS DURING THESE SPEEDS THE WOBBLE IS VERY DANGEROUSE. ARE THERE ANY OTHER RIDER EXPERINCEING THE SAME?
MY ADV
MY ADV is offline   Reply With Quote
Old 10-21-2005, 12:19 PM   #2
AntWare
Lost In Translation
AntWare's Avatar
Oddometer: 16,483
Has it done this from new?
Have you checked your tyre pressure?
How many miles on the tyres?
Have you tried re-balancing the front wheel?
Have you checked the headstock?
Choose Life. Choose a job. Choose a career. Choose a family.
Choose a fucking big television.
Choose sitting on that couch watching mind-numbing, spirit-crushing game shows,
stuffing fucking junk food into your mouth.
Choose rotting away at the end of it all, pishing your last in a miserable home,
nothing more than an embarrasment to the selfish, fucked up brats you spawned to replace yourself.
Choose your future. Choose life.
I chose not to choose life, I chose something else instead.
AntWare is offline   Reply With Quote
Old 10-21-2005, 12:22 PM   #3
Pantah
Red Sox Nation
Pantah's Avatar
Oddometer: 10,229
MY ADV
As stock front Pirelli wears, a wobble can develop. Mine was most noticeable with loaded panniers. However, I cured mine completely by simply checking all my fork adjustments and making sure they were at the standard settings. It turned out my spring pre-load was way soft. After that, no wobble even hands off.
Good Luck!
-p
Straight ahead and faster -Bo Weaver 1970
"There I was..." -Griffin Niner Three Hotel
"One day closer to a parade..." Jonny Gomes, spring training 2013
Pantah is offline   Reply With Quote
Old 10-21-2005, 12:26 PM   #4
creeper
Still alive...
creeper's Avatar
Oddometer: 10,718
What Ant said... particularly a loose steering head will create a excessive decel wobble.
You can also add to the list seriously off compression & rebound damping and spring preload adjustments.
C
So... how's tricks?
creeper is offline   Reply With Quote
Old 10-21-2005, 12:26 PM   #5
vfr700
172S
Oddometer: 573
My 950's front end is busy compared to my other bikes, but nothing like you have described. The only time I get head shake is in deep sand, and I plan on putting a stabilizer on it. Have you checked head bearing adjustment, wheel /tire balance and runout? I've also noticed that the steering on my 950 is sensitive to rear shock preload adjustments. My 05 S had loose head bearings as delivered from the dealer. A few other people reported loose head bearings on their 05 950's too. Rob.
Phoenix, Az
vfr700 is offline   Reply With Quote
Old 10-21-2005, 12:30 PM   #6
AntWare
Lost In Translation
AntWare's Avatar
Oddometer: 16,483
C
The "Sport" settings in the owners manual is a good starting point...and don't forget to crank up the rear pre-load if you're running luggage or a passenger, although failure to do that usually results in a headshake during acceleration or high speed runs due to the front end being light
Old 10-21-2005, 12:52 PM   #7
sashapave
riders on the strom
sashapave's Avatar
Oddometer: 1,431
i had the same problem with mine. it got worse as the stock scorpion wore. i just replaced the bent front wheel with a new one, and put a tkc on. no more wobble.
i think some of it has to do with bike geometry and tire grip. this bike seems to be very sensitive to both.
my old RZ500 was a death-trap on de-acceleration. if you didn't have both hands on the bars, it would buck you off between 50-30mph.
11 250XC: Tweak Bunny
09 TE 610: Gunnar
74 Vespa Rally: Cream Dream
A ship in port is safe, but that's not what ships are built for. -Admiral Grace Hopper
sashapave is offline   Reply With Quote
Old 10-21-2005, 01:35 PM   #8
redfishguide
Old Dirt Biker
redfishguide's Avatar
Oddometer: 492
I had the exact same problem on my 05 S model from new. I just set up my suspension on the sport settings and switched to tkc's and the wobble is no more. Unfortunately I made both changes at once so cannot be sure what had the most effect. I would certainly try adjusting your suspension first. I also noticed the problem was worse with luggage.
Jack Brown
Beaufort S.C.
redfishguide is offline   Reply With Quote
Old 10-21-2005, 03:26 PM   #9
Desmofan
Desmofan's Avatar
Oddometer: 582
I developed a similar problem post Baja, then I noticed my front rim is roughly octagonal
KTM990 SMT
BMW R1200 GSW
DRZ400S
Desmofan is offline   Reply With Quote
Old 10-21-2005, 04:34 PM   #10
rider914
Agnostic Adventurer
rider914's Avatar
Oddometer: 2,461
My 05.5 developed a scary head shake as the stock scorps neared 4k miles. Worst was between 30-40 mph. I could coast down from 60+, in neutral (no engine braking), with hands off (but very near!) the bars. At 35 the grips would slap my hands so hard it would hurt. Switched to TKCs in Ouray and the shake was gone absolutely completely. Unfortunately I also increased front preload (alot) at the same time. So which was it? Well, with 2500 miles on the TKCs the rear was toast and the front was half gone but still smooth and stable, so I switched back to scorps for commuting. Guess what? She's twitchy again and I haven't changed the suspension this time. I'll wait to see what happens, but this may be my last set of scorps.
BTW, new scorp front has not been balanced. Installed at home, but the TKC was installed in a prking lot.
- Matt
'05 950ADV
'04 525EXC D/S
'07 Tiger1050
Will herd cats for beer (... but I rescue puppies for free )
SmugMug (coupon: bLfv2vBXZicd6)
rider914 is offline   Reply With Quote
Old 10-21-2005, 07:17 PM   #11
furndog
at least it's orange
furndog's Avatar
Oddometer: 204
MY ADV
That sounds exactly like the problem that a fellow I met on the Washington State Adventure Ride had, is that you Dan? At any rate, by chance I met TOHC the other day and he had a similar problem. While not the obvious this was what he thought was wrong with his bike.
it seemed like a good idea at the time
furndog is offline   Reply With Quote
Old 10-24-2005, 04:06 AM   #12
RAGrote
RAGrote's Avatar
Oddometer: 1,021
yes....
sportbikes do it too...
I found a slight head shake with a new tire... decellerating, downhill...
When the tire wears the shake gets worse the more worn the tire is.
RAGrote is offline   Reply With Quote
Old 10-24-2005, 04:33 AM   #13
munichboy
munichboy's Avatar
Oddometer: 396
getting front wheel re-balanced fixed it for me
2007 KTM 950 Super Enduro - Stolen
munichboy is offline   Reply With Quote
Old 10-25-2005, 09:02 PM   #14
Jking
It's just a bike
Oddometer: 273
Scotts just came out with their stabilizer for the 2005
ktm adventure. I put one on and it stopped any and all
headshake, regardless of anything else involed.
Jerry king
Jking is offline   Reply With Quote
Old 10-26-2005, 11:11 AM   #15
Chadd
I live in the wrong place
Oddometer: 467
How much did it set you back? and where did you get it from?
Chadd Thompson
94 Ducati Elefant
04 625 SXC
03 WR250F
95 GasGas JT25
Chadd is offline   Reply With Quote
Times are GMT -7.   It's 09:06 PM.
