Old 10-26-2005, 07:02 AM   #1
JohnTM OP
I suck toes
JohnTM's Avatar
Oddometer: 29,206
R100 clutch won't release
A friend has a clutch on a R100 that won't release. New plate, new spring, new rods, crank isn't shifted back, no marks on the flywheel. Any thoughts?
JohnTM is offline   Reply With Quote
Old 10-26-2005, 07:11 AM   #2
norton73
drinkin'
norton73's Avatar
Oddometer: 8,308
Clutch cable length?
Did he just install the new clutch, or was it done a while ago?
Did he check the splines on the input shaft? Rust or wear could make the clutch disc hang up.
Loose nut holding the handlebars
He’s one of those who knows that life is just a leap of faith. Spread your arms and hold your breath, always trust your cape. Guy Clark "The Cape"
norton73 is offline   Reply With Quote
Old 10-26-2005, 08:41 AM   #3
JohnTM OP
I suck toes
JohnTM's Avatar
Oddometer: 29,206
He's replaced just about everything. Maybe he got the wrong plate and it is thicker? Is there a difference between models?
Old 10-26-2005, 08:54 AM   #4
norton73
drinkin'
norton73's Avatar
Oddometer: 8,308
What year is the bike?
Looking at my Clymer manual, page 223, clutch specs;
Friction plate;
R50/5, R60/5, R60/6 R60/7,
1979-1980 R65 Min thickness 2.4 mm
R75/5, R75/6, R75/7, R80/7 2.6 mm
All 900cc, 1977-1980 1000cc 2.8 mm
1981 - up 4.5 mm
Certainly looks like if it's a pre-81 model, a later model friction plate could be a problem.
Times are GMT -7.   It's 07:00 AM.
