Old 05-01-2013, 05:15 AM   #2176
Tourniquet
Tourniquet's Avatar
Oddometer: 75
What is the average weight people carry in their top case?
What is the maximum weight Caribou suggest that you carry?
Tourniquet is offline   Reply With Quote
Old 05-01-2013, 10:57 AM   #2177
CaribouCases OP
Boulder CO
CaribouCases's Avatar
Location: Adventure Rider & Aftermarket Systems Manufacturer
Oddometer: 1,225
No more than 15 lbs (6 kg) is our recommendation. However, we also recommend that you not exceed the carrying capacity of your bike.
Caribou Luggage Systems.
PH: 303-786-8947 Mon-Sat 8:00am-5:00pm Mountain
CaribouCases is offline   Reply With Quote
Old 05-03-2013, 07:12 AM   #2178
CaribouCases OP
Boulder CO
Oddometer: 1,225
New BMW R1200GS Waterboxer (2013) Caribou Side Luggage Now Availale
Caribou side luggage systems for the new 2013 BMW R1200GS are now available. Several sizes to choose from:
35L Pelican (1550 based) http://cariboucases.com/Complete-Side-Luggage-Pannier-Systems/35L-Pelican-Side-Luggage-Pannier-Systems/BMW-R1200GS-2013-35L-Pelican-Side-Luggage-Pannier-System.html
35L Storm (iM2600 based) http://cariboucases.com/Complete-Side-Luggage-Pannier-Systems/35L-Storm-Side-Luggage-Pannier-Systems/BMW-R1200GS-2013-35L-Storm-Side-Luggage-Pannier-System.html
40L (SKB based) http://cariboucases.com/-Complete-Side-Luggage-Pannier-Systems/40L-SKB-Side-Luggage-Pannier-Systems/
36L Top Loading (Pelican 1440 based) http://cariboucases.corecommerce.com...er-System.html
Photos coming soon. For more information and to order please visit www.cariboucases.com. Thank you!
-roger
CaribouCases screwed with this post 10-09-2013 at 08:34 AM
Old 05-07-2013, 02:40 PM   #2179
bwphoto
bwphoto's Avatar
Oddometer: 79
Thinking about getting a set of 35L Pelicans for my '12 R1200GS. Anyone know if they are equal or less than the width of the handlebars when mounted w/ the Caribou Cases rack? Tried searching but found nothing.
Any deals going on a rig for a 2012 GS to make room for 2013 gear??
bwphoto is offline   Reply With Quote
Old 05-07-2013, 03:01 PM   #2180
slowgoer
Oddometer: 10
I might add that the PDF file for install directions ref. the H-B racks on the Triumph Explorer 1200 have been unavailable for some time. That link on the site 40L case site brings you to an error "not found" message. Interested in seeing those. Thanks.
slowgoer is offline   Reply With Quote
Old 05-07-2013, 05:52 PM   #2181
CaribouCases OP
Boulder CO
Oddometer: 1,225
Seems to come up fine when I click on the .pdf file for the 40L system and HB racks. Maybe your browser cache needs to be cleared?
Old 05-07-2013, 05:54 PM   #2182
CaribouCases OP
Boulder CO
Oddometer: 1,225
The side case system will be about 38"-39" wide.
-rog
Old 05-09-2013, 09:46 AM   #2183
CaribouCases OP
Boulder CO
Oddometer: 1,225
We need a 2013 R1200GS
Anyone in the Denver/Boulder CO area with a 2013 BMW R1200GS? We need one for a few hours to do some rear top case design work. Big discount in it for you. Please send me an email roger@cariboucases.com
Thank you!
Old 05-11-2013, 06:26 AM   #2184
JesperDenmark
Oddometer: 21
Can you make a kit for a Yamaha XT660R with a single exhaust?
JesperDenmark is offline   Reply With Quote
Old 05-30-2013, 08:17 AM   #2185
CaribouCases OP
Boulder CO
Oddometer: 1,225
New Top Loading Caribou Motorcycle Side Cases
Introducing the new Caribou 25L Top Loading side case system! Based on the 25 Liter Pelican Storm iM2435, this system offers adventure and dual sport riders a nearly indestructible top loading case that is still narrow and light weight.
FEATURES:
-Easy to assemble turn-key System, no drilling or modification to the bike.
-Nearly indestructible top loading Pelican Storm cases with a heavy duty watertight O-ring lid seal - will not crack or shatter like hard plastic, will not dent & leak like aluminum luggage. These cases come with a limited lifetime guarantee.
-Cases are pre-drilled for optimum performance & safety with pre-installed waterproof lid locks (if you prefer undrilled cases just ask). Wheels and telescoping handle are easily removed.
-Caribou quick attach/release system holds the case tightly on the rack to eliminate all case movement. Our locking latch is fully adjustable to account for wear and to keep the system tight and secure forever
-Our latch is on the outside of the case, so no need to open and unload case to access pucks or bolts. It is field replaceable and designed to release the case from the bike in a hard crash thereby protecting the bike's subframe and luggage rack.
-Super strong Hepco Becker side luggage racks - the best fit and most durable side racks available. The "Lock-It" version allows one to remove most of the rack in a few short minutes leaving behind small unobtrusive attach plates, and still offers superior strength over any other rack on the market.
- All mount components are made of high strength powder coated steel with bushing material to prevent metal-on-metal wear. No brittle plastic parts to break.
-Passenger Friendly Design - plenty of room for passenger's legs and feet on passenger peg.
- 38-39" width across outside of cases at widest point, depending on the bike.
- Total weight of the side case system is approx. 39 lbs including cases, racks, hardware, and all bracket components
- Case dimensions 14" (356mm) Deep, 2" (51mm) Deep Lid, 6.5" x 17.5" (165mm x 445mm) Top Opening, 5.5" x 16.5" (140mm x 419mm) at bottom.
- Case Color is Black only
Here are some photos, more to come later...
Handle nicely recessed so you may strap things to the top...
Wheels and telescoping handle removed for lighter weight and less width...
Caribou hardware....
T6 aluminum backing plate with special coating...
To order please visit www.cariboucases.com or go here.... http://cariboucases.com/-Complete-Side-Luggage-Systems/25L-Top-Loading-Storm-Side-Luggage-Pannier-Systems/
Please post any questions you may have. Thank you!
-roger
CaribouCases screwed with this post 10-09-2013 at 08:35 AM
Old 06-11-2013, 10:27 AM   #2186
CaribouCases OP
Boulder CO
Oddometer: 1,225
36L Top Load vs 25L Top Load
We've had several folks ask us to compare our 36L Pelican Top Loading cases to our new 25L Storm Top Loading cases. Here you can see that they are nearly the same height, and a little shorter length. However the 25L cases are much more narrow and therefore offer a nice narrow width across on the bike....
25L upper, 36L lower in the photo
36L left and 25L right in the photo...
Also, when you remove the wheels and handles from the 25L Top Load cases they are only a little over 6 lb each (without mount hardware). That's really light.
I'd be happy to answer any other questions about the new cases. Thank you!
-roger
Old 06-11-2013, 12:49 PM   #2187
levain
STILL Jim Williams
levain's Avatar
Oddometer: 7,452
-roger
Hmmmmmmmmmmm. I have Wolfman racks on my bike. The side loading is really what has kept me from using your cases. I've been using wolfman soft saddlebags happily, but these have me thinking.
Are you familiar with the Wolfman racks? Would your mount work on the Wolfman racks? Alternatively, with the wheels/handles removed, would I be able to use pucks or the Wolfman kit?
Interesting..
2015 KTM 690 Enduro R, 2008 Yamaha WR250R, 1971 Lambretta DL
levain is offline   Reply With Quote
Old 06-11-2013, 02:55 PM   #2188
CaribouCases OP
Boulder CO
Oddometer: 1,225
Interesting..
You would have to use the pucks for these kind of racks. I guess you could also use U-bolts. A rack like these without a rear crossbar is not recommended.
-rog
CaribouCases screwed with this post 06-11-2013 at 07:13 PM
Old 07-23-2013, 05:13 AM   #2189
CaribouCases OP
Boulder CO
Oddometer: 1,225
New 25L Top Loading Case pics
Here are a few pics of the new 25L Top Loading cases, enjoy....
BMW F650GS...
Yamaha Super Tenere...
Please visit www.cariboucases.com for more info and to order. Thank you!
-roger
Old 07-24-2013, 02:08 PM   #2190
CaribouCases OP
Boulder CO
Oddometer: 1,225
Top Of the Rockies Rally
See you at the Top Of the Rockies Rally in Paonia CO this weekend! Stop by our tent and see all our new products .
Times are GMT -7.   It's 02:39 AM.
