Old 11-10-2005, 08:27 AM   #1
Zapp22 OP
ZAPP - Tejas
Zapp22's Avatar
Oddometer: 13,771
How do I change XR650R to DC power? partslist?
Gearheads
I need some help. not an ace about automotive electrical by any means.
the XR650R is a simple machine with a low output stator, no battery, AC system. I need to convert to DC power and add a battery.
What all does it take to do this job?, and if you have some specific parts info I could really use a Shopping List!
thanks mucho
zapp
Zapp
"I will not let the White City fall... nor our people fail. - Aragorn
K4 WEESTROM Stealthfighter Black -SOLD - Invisible to Radar, '02 DR650SE SOLD ,'Ole 97' DR650SE My Fave K5 WEESTROM ADVbomber
Zapp22 is offline   Reply With Quote
Old 11-10-2005, 08:35 AM   #2
ALLDRTY
I can do that...
Oddometer: 405
Call these guy's.....
http://www.bajadesigns.com/
ALLDRTY is offline   Reply With Quote
Old 11-10-2005, 09:16 AM   #3
jeff_in_rc
A DRZ kind of guy
jeff_in_rc's Avatar
Oddometer: 616
Thumb
Or these guys http://rickystator.com
I just got one of there's for my XR400 and can't wait to put it on. Night riding will be soo much better.
Go forth and modify my friend.
jeff_in_rc is offline   Reply With Quote
Old 08-20-2013, 03:35 AM   #4
TJE
Space Emperor
Oddometer: 72
What did you end up doing, Zapp? I'm about to do the same, so would appreciate some tips :)
(if you can remember that far back, that is :)
2006 Vespa Grantourismo 125L
1998 Honda XRV750 Africa Twin
2003 Honda XR650R
My gallery: http://www.subsignal.com
TJE screwed with this post 08-20-2013 at 03:57 AM
TJE is offline   Reply With Quote
Old 08-23-2013, 11:57 PM   #5
MCVL
MCVL's Avatar
Oddometer: 256
umm, actually, you don't need to install any kits, you just need 1 little thing that is under 5$ cost and some wires, I don't know how to call it on English, but it looks like that
connects like this
all it does is converts the AC to DC, so your front bulb eats 12V AC, you cut those wires, connect them to ~ ~ things and get + - DC from those sticks, then from that + - you can connect back to the bulb and any other 12V device from that same bulb + - wires, easy enough
But the stock stator can't hold much of electrical stuff, a computer fan, turn signals don't use much, they are ok, but something like a ktm fan will dimm out the lights to invisible )
P.S. the stock RR on xr650r only lowers the voltage from 100-400V AC to 12V AC, becouse the usual not led lights doesn't need it to be DC, smth like that anyway, there should be some info about it somewhere =)
MCVL screwed with this post 08-24-2013 at 07:01 AM
MCVL is offline   Reply With Quote
Times are GMT -7.   It's 06:25 PM.
