Old 11-27-2005, 11:14 AM   #1
rokklym OP
one man wolfpack
rokklym's Avatar
Oddometer: 4,453
KTM LC4 400? Is it a good bike?
I just found a 2001 KTM LC4 400 for sale and I'm seriously considering getting it if its a good bike but I really don't know anything about these.
Anyone know details about these bikes, or known problems. Would this be a DRZ with better components?
Check out the Blog!
MotoGraphic
MotoGraphic Tumblr
Chad Berger DR650, KTM 990 Adventure R
Lone Wolf Expeditions
rokklym is offline   Reply With Quote
Old 11-27-2005, 12:29 PM   #2
clintnz
Trans-Global Chook Chaser
clintnz's Avatar
Oddometer: 3,515
Yup, they're a good bike. A lil' heavier than a DRZ but more comfy on the road. As the LC4 640 is essentially the same but with more grunt most people go for the 640 over a 400.
Most people replace the failure prone mainshaft bearing on 640's of that era with the updated roller bearing, I assume that would apply to the 400 also.
Cheers
Clint
'03 KTM 640 LC4 Enduro
The wilderness, the desert - why are they not crowded
.................................................. .....with pilgrims?
clintnz is offline   Reply With Quote
Old 11-27-2005, 12:39 PM   #3
ram1000
ram1000's Avatar
Oddometer: 1,835
I had a 1995 400 and have a 2002 640. I have also ridden a DRZand KLX 400. The DRZ is a much better bike than my 400 KTM was. The 400 is heavy although not as much as my 2002 LC4. It had less power than the DRZ400 offroad model I rode. The DRZ felt much smaller and manuverable, the KTM made you feel like you needed to be in control always. The KTM may have the advantage in suspension but not enough that you couldn't upgrade the DRZ to match.
ram1000 is offline   Reply With Quote
Old 11-27-2005, 01:11 PM   #4
rokklym OP
one man wolfpack
rokklym's Avatar
Oddometer: 4,453
Thanks for the info.
I think I'd be happier with the extra grunt of the 640.
Check out the Blog!
MotoGraphic
MotoGraphic Tumblr
Old 11-27-2005, 02:25 PM   #5
HighwayChile
greetings from Wa state
HighwayChile's Avatar
Oddometer: 4,400
-the 400 is the most over built 400 ever made. i had a 2001.
-other then a skid plate ( $75? ) its good to go out of the box, the DRZ can suck $$ on doo-dads
-the drzs is only 5-7 lbs lighter, the 640 vibrates the LC4-400 doesnt.
-the LC4-400 can really be opened up by re-jetting, see ktmtalk for details,
-the 5 gal tank w/ the 400 goes along ways.
-the quality of components of the ktm is second to none. park one next to a DRZ, look at the hubs, spokes etc.....the drz is a great bike But if you need the quality, you'll pay Big time.
as mentioned be aware of the main bearing issue.oil change is a pain in the ass.
I think it handles rock solid, in tight riding you can ride easier and faster then a 640.
the plastic is way cheap.they tend to be cheap compared to 640, if your looking at a 640, consider a ATK 605,
I would rather wake up in the middle of nowhere than in any city on earth. .....Steve McQueen
HighwayChile is offline   Reply With Quote
Old 11-27-2005, 03:07 PM   #6
Pezz_gs
Cant ride for crap
Pezz_gs's Avatar
Oddometer: 3,808
What parts are interchangeable between the 400 and the 640 LC4
The 400 runs a 64mm stroke and 89mm Bore = 398
The 640 runs a 78mm stroke and 101mm Bore = 625
The 400 running a 101 Barrel and 64 stroke gives 513cc
The 400 running the 89mm barrel & 78mm stroke gives 625cc - interesting
The 400's seem so cheap to buy here on Oz?? Might be a good project bike??
Pezz :)
Pezz_gs is offline   Reply With Quote
Old 11-27-2005, 04:33 PM   #7
dirty dave
dirty dave's Avatar
Oddometer: 1,086
ill take the number of the 400 if your not interested...im in the neighborhood(wi) dirtymotodave@sbcglobal.net
dirty dave is offline   Reply With Quote
Old 11-27-2005, 04:39 PM   #8
2whlrcr
gooligan
Oddometer: 6,536
Rokklym, where have you been? Hadn't seen any posts from you for quite awhile, now your back again.
As others have stated above, the 400 and 640 were identical except for bore and stroke. The 400 might make a better trail bike, because the motor is softer, but IMHO the 640 would be superior in every other arena.
I just gear mine down one tooth on the CS, if I'm anticipating mostly dirt roads or trails. This is what I ran at the Big Woods and Enduraid runs.
I'm still thinking about the new Husky, but will probably keep my Adventure for at least another year.
2whlrcr is offline   Reply With Quote
Old 11-27-2005, 06:21 PM   #9
rokklym OP
one man wolfpack
rokklym's Avatar
Oddometer: 4,453
I've been around! Heck, I posted this trip report just a couple weeks ago!
http://www.advrider.com/forums/showthread.php?t=105637
Check out the Blog!
MotoGraphic
MotoGraphic Tumblr
Times are GMT -7.   It's 04:29 AM.
