05-21-2012, 09:57 PM
#6811 | |
09 klx250s
Oddometer: 10
smooth vibrations
09 klx250s - 03 kx125 - 98 kx125 - 93 rm250 |
05-21-2012, 10:05 PM
#6812 | |
09 klx250s
Oddometer: 10
just wait
05-22-2012, 07:56 AM
#6813 |
Oddometer: 51
Chain Guide Block needed
My chain guide block is shot, bent pretty bad and unable to be straightened. Starting to nip the side of my new chain. My Google searches are not pulling up any results for a 2007 KLX250S. Would the block from another model fit... KLX300, others? Any suggestions welcomed, or if someone has a block they're looking to sell PM me. Thank you!
2007 KLX351S, lots of farkles, even more scratches |
05-22-2012, 08:13 AM
#6814 | |
Bike-curious
Oddometer: 35
http://www.2wheelpros.com/oem-parts/...-assembly.html |
05-22-2012, 08:35 AM
#6815 | |
The road less traveled.
Oddometer: 195
My "SPOT" | Two Brothers on Two50's | Ride Report 1 | Ride Report 2 Rides: 09' KLX250s, 03' V-Star 1100 |
05-22-2012, 08:56 AM
#6816 | |
Oddometer: 51
thanks for looking and sending the link!
05-22-2012, 10:21 AM
#6817 | |
Occasional Venturing
Oddometer: 673
05-22-2012, 11:10 AM
#6818 |
Oddometer: 195
Starter Jet
Ok, does anyone know if and where I can get another stock starter jet. Yep, drilled mine out to much. The 0.018" bit broke and I couldn't get it out. So I had to drill it out with a bigger bit (0.032" was the smallest I had) and now the choke doesn't work at all.
05-22-2012, 11:48 AM
#6819 |
Oddometer: 1,724
Fill it with the too big hole with a gasoline resistant epoxy and drill it again?
Not all who wonder are confused " I say VW's are like VD.....once you get a good one, it's hard to get rid of." oldmonkeybut |
05-22-2012, 12:16 PM
#6820 |
Oddometer: 195
Thought about that actually but I'd like to try and find another jet first, if it's available.
05-22-2012, 12:20 PM
#6821 | |
Oddometer: 673
edit: here's the thread -- http://www.kawasakiforums.com/forum/...ter-jet-35202/ |
05-22-2012, 12:24 PM
#6822 | |
Oddometer: 195
05-22-2012, 12:46 PM
#6823 | |
Oddometer: 195
05-22-2012, 08:32 PM
#6824 |
Mostly Harmless
Oddometer: 1,713
Speaking of jetting, I finished up mine today. Thanks to my wideband O2 sensor, I was able to get my jetting to be almost perfect for this elevation. It's just slightly richer than ideal. I'm at 0.7 to 0.8 lambda (ideal is 0.8 to 0.9). I have a 135 main jet, 37.5 pilot and needle in middle clip. This is on the Bill Blue TM33 (bored to 34mm) pumper carb.
From looking at a jetting calculator page, if it's right, for sea level I will need either a 140 or 142.5 and a 40 pilot. I'm curious as to what I'll need for a 351, since that will hopefully happen in July. I'm very pleased with the instant throttle response of the new carb. You really can't imagine the difference until you have one. It really is instant compared to the stock CVK. Rob
'96 Suzuki DR650, '10 Kawasaki KLX250S, '01 Yamaha FZ1 The Lane Sharing Works Blog | My SPOT Page |
05-24-2012, 09:32 PM
#6825 |
Oddometer: 9
2006 lkx 250 previous owner mods
Hi,
I've got a 2006 klx 250 that has some work done to it from the previous owner... I'm just trying to figure out what the hell he has done to it. It runs fine, but it still makes me curious. The bike has a muzzy full system, it's likely been jetted, in fact I'm sure the carb has been out because the throttle return cable has a kink in it, telling me they bent it slightly in the process. What I am curious about is the AIRBOX. This airbox has a hole cut into the top of it that is rounded off... and when I pulled the filter, the strange thing is there is a mesh filter there once you remove the entire filter... but the mesh covers only 3/4 of the round cone surface. What is the scoop with this? |
