06-03-2012, 05:51 PM
#6871 | |
Oddometer: 314
Sent from my SCH-I500 using Tapatalk 2 |
06-03-2012, 11:28 PM
#6872 |
Oddometer: 1,152
06-04-2012, 12:01 PM
#6873 |
Oddometer: 485
June 17th this year
Landon 06 Kaw KLX250s 09 Kaw Versys |
06-04-2012, 03:21 PM
#6874 |
Mostly Harmless
Oddometer: 1,772
Jetting issues...
I'm also having jetting issues. This is with the Bill Blue TM33 pumper carb.
Current settings: 37.5 pilot, needle in middle, 135 main, AF screw 2 turns out Mods: Snorkel Removed, TwinAir filter, KLX300 exhaust w/o end cap, brand new spark plug (NGK CR8E, stock plug) Anything from 3/4 throttle on up (except WOT), and it "cuts out" pretty bad... RPM doesn't matter, just happens on throttle position. Going WOT solves issue, but that's not always practical. Today I did some testing. I put the snorkel back in. Now the thing barely runs above half throttle, including WOT. Came back, removed air box lid entirely. Runs MUCH better... best it has so far, except there's still a stumble/miss at 7500 RPM in every gear. I would prefer to have it running properly with either the air box lid/snorkel or the air box lid w/o snorkel, and get rid of that miss at 7500. What do you think? Drop the pilot to a 35 and drop the needle a notch? I'm at 4500' elevation if that matters, though I would like to have it set to run fine at sea level and have it a little fat up here and up to 6-8k as long as it doesn't run like crap. I could then pull the air box lid if I had to at higher elevations. Rob
'96 Suzuki DR650 '10 Kawasaki KLX351S #320 '01 Yamaha FZ1 The Lane Sharing Works Blog |
06-04-2012, 03:43 PM
#6875 | |
Oddometer: 172
Norm
'09 KLX250S & '09 KLX351SF '02 Moto Guzzi Stone '76 R90/6 '74 Harley Aermacchi Sprint 350SS '32 Body could use some repairs |
06-04-2012, 03:50 PM
#6876 | |
Mostly Harmless
Oddometer: 1,772
If I already had the 35 pilot, I would go ahead and pull the carb and make the changes... but I don't, and it's windy and getting colder today with rain coming tonight and tomorrow, so no point in trying again before Wednesday. I can't help but wonder if the cutting out at 7500 might be my CDI or regulator. If it was at a particular throttle position, I might think it was going fat right then, but since it's at exactly 7500 in every gear, it kinda seems ignition-related. Rob
06-04-2012, 04:15 PM
#6877 |
Occasional Venturing
Oddometer: 699
Rob, Have you done that grounding thing that a bunch of 09+ owners have completed?
06-04-2012, 04:24 PM
#6878 | |
Mostly Harmless
Oddometer: 1,772
Rob
06-04-2012, 06:08 PM
#6879 | |
Oddometer: 51
If you're already considering the 351, do it and don't look back - I for one am not only really pleased, I'm really surprised at how well it works with the bike.
2007 KLX351S, lots of farkles, even more scratches DurtDevil screwed with this post 06-04-2012 at 06:34 PM |
06-04-2012, 06:23 PM
#6880 |
Oddometer: 1,464
Call Rick at Cogent Dynamics when you are ready to change the suspension. He rebuilt my KLX250SF shock when I converted it into a dualsport. Best thing that I have done so far. The Cogent shock works great. Just added the IMS tank and the 351cc engine kit is next on my list.
SamM screwed with this post 06-04-2012 at 06:29 PM |
06-04-2012, 06:39 PM
#6881 | |
Oddometer: 1,767
http://www.kawasakiforums.com/forum/...e7/#post452954
Not all who wonder are confused " I say VW's are like VD.....once you get a good one, it's hard to get rid of." oldmonkeybut |
06-04-2012, 07:06 PM
#6882 | |
Back-to-back motos suck
Oddometer: 654
Now, for that ridiculous suspension...
'07 DL650, '06 DR650, '06 KLX351, '06 KX250, '83 XR350R, '74 Bultaco Alpina (trials) |
06-04-2012, 07:48 PM
#6883 |
Mostly Harmless
Oddometer: 1,772
More testing...
Being bored, I went out and dropped the needle one notch. It's now in the 2nd position from the top. I removed the snorkel again and replaced the air box lid, then went for a ride. It runs waaaay better than it has so far. Wow, very nice... it actually has torque!! That is, up until around 9000 RPM and 7/8th's throttle... that's when the "cutting out" starts again. It's not quite as bad as before. So now I'm thinking... what if this is how it would be if jetted for sea level? Maybe I should put the needle back in the third (middle) position and just run w/o the air box lid up here, and replace the lid when I'm at sea level? Rob
06-04-2012, 09:54 PM
#6884 | |
Candyass Camper
Oddometer: 3,412
06-05-2012, 06:35 PM
#6885 |
Mostly Harmless
Oddometer: 1,772
Might be.
I made more changes today but it's been cold so I haven't ridden it to test. I dropped the main jet one notch to a 132.5, and dropped the pilot to a 35. I'm eager to go for a test ride tomorrow to see what the difference is. Rob
