Old 10-09-2012, 08:03 AM   #7336
Rob.G
Mostly Harmless
Rob.G's Avatar
Oddometer: 2,166
Sand performance is as much about the tire as it is the rider. Not to knock you or anything; but I used to think it was almost all in the tire, until I rode my friend's KLX at the dunes a few weeks ago on his stock D605 front (with a paddle tire in back). It hooked up surprisingly well. We aired it down to 12 psi and as long as you keep your weight back, your arms relaxed, and stay on the gas, it does quite well.
Now, that's not to say your new knobby won't be even better (it probably will)... just that the stock tire is totally doable in sand as long as you keep your speed up. In any case, they're not great tires to begin with, so you'll enjoy having two good tires!! :)
Rob
'12 Suzuki V-Strom DL650
'96 Suzuki DR650
'92 Yamaha TW200
Rob.G is offline   Reply With Quote
Old 10-09-2012, 08:31 AM   #7337
mikesova
mikesova's Avatar
Oddometer: 1,891
Rob
the ORV trails that I ride are pretty tight and sandy, so I play it cautious, since I don't want to eat any bark. I should just find a big sandy open spot to practice.
2009 Kawasaki KLX250S
2001 Yamaha TW200 (Wife's bike)
2005 Yamaha FZ6
2009 Honda Ruckus
mikesova is offline   Reply With Quote
Old 10-09-2012, 08:44 AM   #7338
Rob.G
Mostly Harmless
Rob.G's Avatar
Oddometer: 2,166
Good point. Out in the open sand, it's a lot easier. In confined spaces, it's very hard on any tire. Though I bet the better knobby will help keep from washing out at slower speeds.
Rob
'96 Suzuki DR650
'92 Yamaha TW200
Old 10-09-2012, 09:38 AM   #7339
NJ-Brett
Brett
Oddometer: 6,411
For the sand around here, a wider tire with aggressive tread aired down works best.
I got a chance to push that to the limit on a TW200 this summer, fitting a 5.10 shinko 244 tire to the front.
I never had a bike that was so easy to ride in and through sand and swamps before.
I went places I would never go (solo anyway) on any other bike, and I did not fall once the entire time I had the bike.
NJ-Brett is offline   Reply With Quote
Old 10-09-2012, 01:19 PM   #7340
Bultaco206
Back-to-back motos suck
Bultaco206's Avatar
Oddometer: 2,183
Rob
It's more about body position and tire pressure than the tire itself. It's mostly technique. Tire choice is more important in mud, rock, or loam than with sand.
Just my experience.
'07 DL650, '06 KLX351, '97 DR350, '83 XR350R (vintage GP racer), '74 Bultaco Alpina (trials)
Bultaco206 is offline   Reply With Quote
Old 10-09-2012, 11:34 PM   #7341
Scrambleon
Scrambleon's Avatar
Oddometer: 331
Thumb Seat Concepts Low Height Seat
Originally Posted by PhoenixGirl63 View Post
Thanks so much, Scrambleon! That would be great. Customizing the seat would probably be required, too.
PhoenixGirl63,
Got the custom low cut, Seat Concepts seat installed last week. It came out real nice. I put about 150 miles on it the last two days and I can honestly say it is a big improvement over the factory seat in comfort and in seat height. I estimate the seat to be about 1.5 inches shorter. It is enough of an improvement that I am going to wait and see about doing any other lowering for the time being. In the picture below the old seat foam is above the new seat for a comparison view.
Scrambleon
Scrambleon is offline   Reply With Quote
Old 10-10-2012, 06:50 AM   #7342
fastdadio
Still gettin faster
fastdadio's Avatar
Oddometer: 2,104
I hope I did the right thing. This year I've done a lot of modifcations on my KLX, but I never changed out the front tire. Could that have been my downfall in the sand? I replaced my rear tire with a D606, but my front tire seemed to be in good shape so I kept it, the stock D605. I am always losing control in the sand and after talking to some friends, I decided to order the Pirelli Scorpion All Terrain front tire. Do you think this will be a drastic improvement in sandy conditions (Michigan)?
Hey mikesova, I play in the same sandbox as you. Take RobG's advice. It's more about technique than tire. Allow me to add to his advice. Weight bias, front to rear. When you roll off the gas, the weight transfers to the front tire and it sinks in and wants to wash out. When you roll on the gas, it gets light and starts to float over the sand. While on the gas, you steer with the throttle while shifting your weight on the pegs. Hang your ass over the rear. Keep the bike in a lower gear with the rev's higher and pulse the throttle. Gas on when your headed in the right direction, gas off when your not. Practice. Head up to the scramble area in St.Helen. Lots of open sand to play in. Consider a steering damper. They really help in the deep stuff and keep you from having to fight the wash out. This will allow you to ride longer without becoming exhausted so quickly.
fastdadio is offline   Reply With Quote
Old 10-10-2012, 07:42 AM   #7343
Shwafish
Shwafish's Avatar
Oddometer: 78
Question about UNI air filters
Hello all,
I am new here, I just traded my V Star for a 2007 KLX250S and now I have a question. Yesterday I took the seat of to see if there had been any airbox modifications already done and I got a surprise. The snorkel had been removed but other than that the lid was intact, but when I took the lid off I was staring at an empty box. The backfire screen was there but that was it, no filter or anything else. My first thought was "How long has this thing been running without a filter and how much damage has been done to the engine already". I quickly realized that those questions will probably never get answered and all I can do at this point is get a filter and hope for the best. My question to you is if I get an UNI filter do I also have to get the support cadge thing that came stock on the bike or do they have an integrated support system? For some reason I feel like they have a plastic structure built into them but I do not know why I think that and I just want to make sure I get what I need but don't spend more money than I need to. Thanks in advance for any help.
Shwafish is offline   Reply With Quote
Old 10-10-2012, 08:46 AM   #7344
TNC
Candyass Camper
TNC's Avatar
Oddometer: 4,622
Just my experience.
I don't know...the discussion of the tire vs. the rider technique is interesting, but it's hard to qualify a real number on the level of importance for each. However, if the tire wasn't a major element in the mix, we wouldn't have sand paddle tires.
TNC is offline   Reply With Quote
Old 10-10-2012, 10:26 AM   #7345
cjbiker
Nobody's Robot
cjbiker's Avatar
Oddometer: 2,658
Originally Posted by Shwafish View Post
Hello all...My question to you is if I get an UNI filter do I also have to get the support cadge thing that came stock on the bike or do they have an integrated support system?.
You'll need to get the support cage from a Kawasaki dealer or online. I like to order from Ron Ayers, but there's plenty of others to choose from.
I agree. If you're talking the difference between two different knobby tires, then yes, rider technique is far more important. Talking about the difference between a real knobby, and the 50/50 tires that our bikes come with stock, well that's another story. To take this to the extreme, imagine putting on Avon Distanzias and taking the bike to the sandpit. Tell me the tire doesn't matter then.
cjbiker is offline   Reply With Quote
Old 10-10-2012, 11:24 AM   #7346
Shwafish
Shwafish's Avatar
Oddometer: 78
Thanks cjbiker, I figured that would be the case but I wanted to make sure.
Old 10-10-2012, 11:32 AM   #7347
mikesova
mikesova's Avatar
Oddometer: 1,891
Good to hear!!!
2005 Yamaha FZ6
2009 Honda Ruckus
Old 10-10-2012, 11:48 AM   #7348
cjbiker
Nobody's Robot
cjbiker's Avatar
Oddometer: 2,658
Good to hear!!!
And of course, tire pressure is more important than tire choice, but that's another can of worms...
Old 10-11-2012, 09:39 AM   #7349
mikesova
mikesova's Avatar
Oddometer: 1,891
The Pirelli came in yesterday:
I'm really hoping there is a decent difference.
2005 Yamaha FZ6
2009 Honda Ruckus
Old 10-11-2012, 03:13 PM   #7350
fastdadio
Still gettin faster
fastdadio's Avatar
Oddometer: 2,104
Whats wrong with the tire on the left? Looks prime for zip screws to me!
Times are GMT -7.   It's 11:05 PM.
