Old 06-29-2013, 09:48 AM   #8056
Lutz
Killer Rabbit
Lutz's Avatar
Oddometer: 1,463
Originally Posted by doxbike View Post
does anyone know for sure which years of the 300 klx head pipe and muffler will fit a 2009 klx250s?
All of them. 1997-2007.
Lutz is online now   Reply With Quote
Old 06-29-2013, 01:38 PM   #8057
BroncoDave
BroncoDave's Avatar
Oddometer: 4,408
Help What is the trq for the front sprocket nut 2006 klx250s also what is the stock sprocket 14 ? I have a 13 second owner i thought it was stock
BroncoDave is offline   Reply With Quote
Old 06-29-2013, 09:43 PM   #8058
turbodieseli4i6
turbodieseli4i6's Avatar
Oddometer: 463
Sent from my LG-L40G using Tapatalk 2
turbodieseli4i6 is offline   Reply With Quote
Old 06-30-2013, 05:39 AM   #8059
Dan888
Dan888's Avatar
Oddometer: 427
Originally Posted by TNC View Post
...and ram air.
Just so no one mistakes humor for reality, dan888 and IDRIDR are great forum contributors both here and on the Kawasaki Forums. In fact, sometimes we have so much fun over there that we forget just how serious motorcles really are.
WHOA!!!
I am not the same Dan888 as over on KF. That guy over there is just awesome. Very knowledgeable and extremely funny. TNC are you the same TNC over on KF???? I never made teh connection, you seem so level headed, and pleasant here on ADV.......
Are you the same TNC that won the Concho Enduro down in Texas?
Dan888 is offline   Reply With Quote
Old 06-30-2013, 05:49 AM   #8060
Dan888
Dan888's Avatar
Oddometer: 427
92 ft lbs front sprocket nut. I put some anti-seize on mine. Yours has obviously been off before but these things are notorious for being super hard to remove, the first time off. They really put them on tight, or lock them with something, at the factory.
14 is stock, but 13 works great, unless all you do is ride on the road.
Old 06-30-2013, 06:43 AM   #8061
BroncoDave
BroncoDave's Avatar
Oddometer: 4,408
Help!!!! I had the rear tire in the air to lube chain, found it a little hard to rotate, felt like a dragging brake or wheel bearing. Removed chain,turns out its the drive sprocket that has the resistance. This does not seem normal to me. With the chain off, I can not rotate front sprocket by hand. With a wrench I can get it to rotate then continue by hand. There seems to be a lot of drag internally. It does not have tight spots or clunking when I rotate it, no play in the shaft, does this sound normal or do I have an internal issue? Bike has about 3000 miles on it. Please help before I freak...
Old 06-30-2013, 02:41 PM   #8062
grahamfitter
Oddometer: 73
You sure its in neutral?
Graham Fitter
2009 KLX 250S, 2011 Versys
grahamfitter is offline   Reply With Quote
Old 06-30-2013, 02:48 PM   #8063
BroncoDave
BroncoDave's Avatar
Oddometer: 4,408
Yes and the killswitch is on DOH bike was hot now it's cold I can turn it with my hand but still not easy
Old 07-01-2013, 08:32 AM   #8064
Gillus
High Desert Rat
Oddometer: 834
before or after you lubed the chain. did you clean it all before you lubed it?? Maybe it is all super sticky
Disclaimer: I am only responsible for what I said........... Not what you understood or how you interpreted my words!!
Gillus is offline   Reply With Quote
Old 07-01-2013, 09:37 AM   #8065
BroncoDave
BroncoDave's Avatar
Oddometer: 4,408
Both the chain is not adding much. all my other bike spin freely It's all at the output shaft
Old 07-02-2013, 06:49 PM   #8066
FloorPoor
Oddometer: 712
Quite possibly you have a toasted counter shaft bearing, or worse
What kind of chain tension have you been running? Dirtbikes, especially non cush hub ones, like the chain to be on the looser end of the spec. Possibly you ran the chain tight too long and toasted the bearing? An over tight chain will put A LOT of pressure on the countershaft bearing when the suspension compresses rapidly from a big hit. Or perhaps the bearing is just faulty. I would start with the counter shaft bearing, hopefully it's not a bearing deeper in the gear box.
"You can have anything you want, but not everything you want."
"There's nothing like that fresh tire feeling "
FloorPoor screwed with this post 07-02-2013 at 06:54 PM
FloorPoor is offline   Reply With Quote
Old 07-03-2013, 07:33 AM   #8067
brieninsac
brieninsac's Avatar
Oddometer: 206
I'm going to be installing a new IMS tank this weekend. It comes with a 2-way vented gas cap. I'd like to get the Acerbis locking cap which only vents in. Is there any safety concerns using a 1-way cap like this? I just don't want to have excessive pressure in the tank and have it fail on me.
2012 Kawasaki KLX250S
Dynojet • FMF Q4 • K&N Air Filter • KDX Snorkel • RAM Mount
15/42 • Pirelli Scorpion MT 90/AT • Pro Moto Rack • Seat Concepts
brieninsac is offline   Reply With Quote
Old 07-03-2013, 08:35 PM   #8068
sealsam
Sam...I am.
Oddometer: 1,991
Spent a couple days in the St. Geo, UT & Zion NP area last week for my birthday. Did about 400 mi in the 2 days. One of those days was with RedRockRider, StG & Simbaboy. RRR found us some fairly remote, beautiful high country stuff.
The Seat Concepts continues to offer great comfort. Great investment!
sealsam is offline   Reply With Quote
Old 07-03-2013, 09:55 PM   #8069
rickypanecatyl
SE Asia adventure tours
Oddometer: 1,122
Brick rider that sounds like it could be a great bike - if it was done, put together well!
Pluses
- about 40 pounds lighter than the new ones.
- much better suspension for off road. (might feel washy on curvy pavement... It will have more adjustability though.)
- one of the best learner/forgiving engines for riding off road. The ratio of torque to hp/gentle hp curve.
If it s done right you could have a bike that performed similarly to a WR250F or CRF250X off road with 4 times the engine life doing 1/4 the maintenance.
Because it lasts so long I'd advise having a custom suspension guy totally dial it in for you and your riding. Those mods will only cost you 1/4 as much per mile. :-)
In Malaysia you could get a custom chromaly sub frame that is a bit heavier but can even handle a passenger.
Sent from my SAMSUNG-SGH-I847 using Tapatalk 2
rickypanecatyl is offline   Reply With Quote
Old 07-04-2013, 07:14 AM   #8070
NikLyk
Oddometer: 33
You guys with the Big Bore kits, I am interested in knowing your highway cruising speeds.
My near-stock EFI 250 goes 70 mph @ 7100 rpm pretty comfortably.
Stock gearing, no big bore, standard speedo.
What I am interested in knowing is if the Big Bore kit makes it slightly more highway capable. I would love to be able to go 80-85 comfortably.
At what speeds and rpm do you usually cruise on the highway?
(Please list gearing, cc´s, stock/modded speedo and such) Do the big bore kits help in this department or is it mostly low and mid-range grunt?
NikLyk is offline   Reply With Quote
Times are GMT -7.   It's 08:17 AM.
