Old 07-13-2013, 08:43 AM   #8101
DurtDevil
DurtDevil's Avatar
Oddometer: 69
Originally Posted by TNC View Post
Could you share all your jetting numbers?...main jet, needle #, needle jet #, needle clip position, pilot jet, pilot air jet, pump opening/closing position...everything.
Shoot - if course I don't know it all. I remember my friend/mechanic saying that he didn't mess with the carb settings (he did play with it a little but said it seemed to work best the way the Bill Blue had sent it out).
I will make some calls and see what I can find.
It's a 2007 w/351, 36 pumper, KDX200 snorkel, K&N filter, and Two Bros exhaust. I' guessing its probably not possible to ask for standard sea level settings with that set up?
I'll post again once I have all the jetting info - thanks TNC.
2007 KLX351S, lots of farkles, even more scratches
DurtDevil is offline   Reply With Quote
Old 07-13-2013, 08:49 AM   #8102
TNC
Candyass Camper
TNC's Avatar
Oddometer: 4,629
If it's Bill Blue's modded 33mm pumper bored to 34mm, it's different from my 36mm Mikuni pumper. I was hoping to get you closer to proper jetting for the KLX, but I'm not really as familiar with BB's carb settings. There are quite a few here that have that carb, however, and perhaps they could steer you closer.
TNC is offline   Reply With Quote
Old 07-13-2013, 09:02 AM   #8103
Navin
Navin's Avatar
Oddometer: 8,230
Pull the main and try one step leaner, failing that and if it gets worse, one richer. Sounds fat to me on the main but better to test and tune. The pump should be finished at that point when you roll the throttle slowly to get past the blubber.
Another thing to try, roll it to point and pull the choke on. I'd bet it gets worse.
Navin is offline   Reply With Quote
Old 07-13-2013, 09:07 AM   #8104
tjrockit
One day closer...
tjrockit's Avatar
Oddometer: 1,211
What do you guys use for case savers to keep the gear shifter from punchering the case?
2007 Honda XR650L
Dirt Roads within a 100 mile radius of Austin, TX
*** The views or comments I express on this site and/or on any other site/forum/social media are strictly my own and do not reflect any past, current or future employer and/or any organization. They are solely my own personal opinions.***
tjrockit is offline   Reply With Quote
Old 07-13-2013, 09:28 AM   #8105
TNC
Candyass Camper
TNC's Avatar
Oddometer: 4,629
I was wondering about that. Being that he could slowly accelerate up to WOT without much issue but have noticeable stumbling when whacking the throttle open, it sounds like his pump may not be working or at least not keeping up...pump timing or even not pumping at all. I agree that the pump should be through at 3/4 throttle or so.
Old 07-13-2013, 10:42 AM   #8106
FIDOLLAZ
Dirty D
FIDOLLAZ's Avatar
Oddometer: 744
Originally Posted by 1994klr250 View Post
Do you have any pictures of the new head pipe and muffler? I have big gun EVO x exhaust on my 94 klr 250 and its loud, now I'm looking for something a bit quieter for my 06 klx250. Any video clips of it running?
its really quiet & huge performance gain
FIDOLLAZ is offline   Reply With Quote
Old 07-13-2013, 12:07 PM   #8107
doxbike
Oddometer: 278
Originally Posted by Rob.G View Post
No, the ACR is on the exhaust cam, so if you change it, you will have to change the ACR.
As I understand it, you have to do both to have any improvement.
Rob
See post 428 on that other forum
doxbike is offline   Reply With Quote
Old 07-13-2013, 12:09 PM   #8108
doxbike
Oddometer: 278
Wondering that myself. think I'm gonna bend the shifter out just a tad and jb weld a piece of 1/4" aluminum on there, unless anybody has a reason not to, or has a better idea
Old 07-13-2013, 02:13 PM   #8109
cjbiker
Nobody's Robot
cjbiker's Avatar
Oddometer: 2,813
I extended my shifter 3/4" and while I had the welder out, I welded a flat piece of steel to the back. I had a lowside crash and bent the shifter and it hit the case but didn't damage it, so it worked as planned.
cjbiker is online now   Reply With Quote
Old 07-13-2013, 04:59 PM   #8110
Dan888
Dan888's Avatar
Oddometer: 427
You start with a box of Cheezits. Take the Cheezit box and cut away anything that doesn't look like a case saver.
It's held on with some 3M high heat two sided tape . I will have to pull it off when I do a valve check.
Dan888 is offline   Reply With Quote
Old 07-13-2013, 06:00 PM   #8111
1994klr250
1994klr250's Avatar
Oddometer: 692
Wow, that looks great! What thickness aluminum did you use?
2300 miles on a 250 all for a sticker http://www.advrider.com/forums/showthread.php?t=616239
Fall ride on a KLR250 http://www.advrider.com/forums/showthread.php?t=754065
1994 KLR250, 2009 F800GS, 2006 KLX351
1994klr250 is offline   Reply With Quote
Old 07-14-2013, 07:45 PM   #8112
tjrockit
One day closer...
tjrockit's Avatar
Oddometer: 1,211
Having you considered making a few and selling them?
2007 Honda XR650L
Old 07-15-2013, 09:46 AM   #8113
zippets
WilD&CrAzY
zippets's Avatar
Oddometer: 50
LOL wow why don't you cut out a hole in the middle os you don't have to remove for a valve check ??
KLX250s Mods: FmF Q4 Pipe with a Mega bomb Header, FmF power core 4 Queit 1 1/8 Insert, DJ carb kit, DJ needle 3rd slot down, DJ jet #132, 2 turns out, Snorkle Removed, airbox screen removed, twin filter, Enduro Performance, Hand Guards, IMS 3 gallon tank, 13t front 48t rear, Soupy lowering link, seat concepts 1" lower cover, mercelo cam timing mod
zippets is offline   Reply With Quote
Old 07-15-2013, 11:36 AM   #8114
250senuf
250senuf's Avatar
Oddometer: 2,410
I wouldn't put a hole in it either.
Not all who wonder are confused
250senuf is offline   Reply With Quote
Old 07-15-2013, 12:18 PM   #8115
FIDOLLAZ
Dirty D
FIDOLLAZ's Avatar
Oddometer: 744
Has anyone put the sm front rotor on the s with the s wheel?
I have not looked at the sm setup yet...I can make a caliper relocation bracket on my mill if needed.
also if anyone has what im looking for PM me if its for sale
Times are GMT -7.   It's 02:25 AM.
