Old 08-05-2013, 08:29 PM   #8251
mikezx10
Happy hooligan!
mikezx10's Avatar
Oddometer: 208
Oh... I also have these...
Complete with tubes, tires, rotors, 39T sprocket and caliper bracket!
mikezx10 is offline   Reply With Quote
Old 08-06-2013, 01:14 AM   #8252
Zniper
Zniper's Avatar
Oddometer: 1
Hi, I have a 1997 KLX 250 and now intend to replace the clutch basket with one of '09 (from eBay). They look quite similar but I'm not sure that will fit and properly work. Any advice?
Zniper is offline   Reply With Quote
Old 08-06-2013, 09:36 AM   #8253
Earthscape
Have ya got a helmut?
Earthscape's Avatar
Oddometer: 349
Originally Posted by Bama67 View Post
It runs great once it is cranked.
It seems if I run it every couple days it does okay, still turns over far more than anything I am used to.
I assume when you say "crank" you really mean "start". If the bike won't crank, your battery is not good. A bike is cranking while you are holding the starter button down. If it cranks (turns over) fine but doesn't start, check your float height; chances are good that Kawasaki didn't.
"You do your own thing in your own time, you should be proud."
2004 KTM 950 ADV : : : : : : : 1998 Triumph Tiger
1999 KTM 640 ADV : : : : : : : 1993 Kawasaki KLX650
2007 Kawasaki KLX350S : : : : 1996 Yamaha XT350
Earthscape is offline   Reply With Quote
Old 08-07-2013, 08:15 AM   #8254
GS750T
GS750T
GS750T's Avatar
Oddometer: 370
Little introduction:
This is my new to me 07 KLX. Had a KLR for 18,000 miles but being an old fook it became harder and heavier to get on the rack behind our motorhome. Replaced the KLR with a 150 scooter that just did not cut it with my kind of riding. The KLX sat outside for a year and needed some new sneakers and some tlc.
The KLX is a hoot to ride but takes forever to warm up after starting. The thing is most definetly running lean from the factory. After spending at least three weeks reading this thread, into the carb I go for some new jets. Having had many previous bikes, I put together a jet kit. Single carbs are so much better than in-line fours.
The EPA sucks and now the bike runs like it should from the factory!
"In God We Trust" If you don't like this quote, go F%$K yourself!
11 FLHPT
06 Ulysses
07 klx 250
GS750T is offline   Reply With Quote
Old 08-07-2013, 09:34 AM   #8255
Lutz
Killer Rabbit
Lutz's Avatar
Oddometer: 1,448
Originally Posted by GS750T View Post
...The EPA sucks...
True on so many levels. Nice bike, by the way.
Lutz is offline   Reply With Quote
Old 08-07-2013, 01:23 PM   #8256
Ranger Ron
Ranger Ron's Avatar
Oddometer: 737
The Thermo-Bob is the cure. Fast warm-ups, even temperatures. As a bonus, you can jet for one temperature and have consistent fueling.
More info here:
http://www.watt-man.com/
Ron
Ranger Ron is offline   Reply With Quote
Old 08-07-2013, 01:52 PM   #8257
IDRIDR
Take me to the River
IDRIDR's Avatar
Oddometer: 1,466
More info here:
Ron
Got one. Agree it makes for fast warm-ups. Especially in winter when the bike warms up quickly as opposed to hardly warming up at all.
Have one for the KLR and need to get it installed.
IDRIDR is online now   Reply With Quote
Old 08-07-2013, 01:53 PM   #8258
Bultaco206
Back-to-back motos suck
Bultaco206's Avatar
Oddometer: 2,329
Winter? It's 10-below here. I don't go outside.
'07 DL650, '06 KLX351, '97 DR350, '83 XR350R (vintage GP racer), '74 Bultaco Alpina (trials)
Bultaco206 is offline   Reply With Quote
Old 08-07-2013, 01:55 PM   #8259
IDRIDR
IDRIDR's Avatar
Oddometer: 1,466
Year-round riding here...
Old 08-07-2013, 01:57 PM   #8260
Lutz
Killer Rabbit
Lutz's Avatar
Oddometer: 1,448
Yeah, winter riding can be great fun! If you don't do it, you're missing out.
Old 08-07-2013, 02:02 PM   #8261
De250r
De250r's Avatar
Oddometer: 73
I just put odi waffle clamp on grips on it today. Best 20 I've spent on bike. They come with a new throttle tube with different cams so u can go to 1/4 twist instead of half. Made a noticeable difference in throttle response just because u don't have to reset your wrist to get full twist. Just twist Nd it's wide open. Love it. The new to me renthal bars r nice as well. Gotta put my brush guards on tomorrow
Sent from the back woods of vt via patchy Internet
Live free and ride hard
De250r is offline   Reply With Quote
Old 08-07-2013, 02:24 PM   #8262
Bultaco206
Bultaco206's Avatar
Oddometer: 2,329
I've done it. But I learned long ago that screws are for wood.
Old 08-07-2013, 03:15 PM   #8263
cjbiker
Nobody's Robot
cjbiker's Avatar
Oddometer: 2,733
Trails around here are closed to bikes from first snow to May 15th
cjbiker is offline   Reply With Quote
Old 08-07-2013, 04:27 PM   #8264
IDRIDR
IDRIDR's Avatar
Oddometer: 1,466
That is sad. We ride the hills until the snow pushes us out, then head to the desert and ride on.
Middle of January with plenty of snow in the mountains.
November, higher elevation desert
Old 08-07-2013, 09:30 PM   #8265
rickypanecatyl
SE Asia adventure tours
Oddometer: 1,113
You guys aren't getting snow already!
Silly nit pick I can't seem to figure out is my bike will no longer start/crank over with the clutch in while it is in gear. I have to be in neutral for the starter to work.
I'm often climbing some crazy muddy hills when I stall and being able to start in gear would be great.
Anyone know what effects that? I've played with the clutch adjustment... my plates are fairly new/in good shape... any ideas where the problem is coming from? Thanks!
rickypanecatyl is offline   Reply With Quote
Times are GMT -7.   It's 08:46 PM.
