Old 08-19-2013, 07:34 PM   #8296
ScienceOfDirt
U-Boat Rider
ScienceOfDirt's Avatar
Oddometer: 1,723
Originally Posted by jules083 View Post
Finally started the ride report of the Trans-Eastern Trail. Day one is complete, going to start writing day two later.
http://www.advrider.com/forums/showthread.php?t=913010
Going to read that to see how the KLX did. I just bought a 2006 KLX in June. I took the 800GS last time on the WV portion of the TET, but it wasn't much fun in the mud.
Edit: it looks like you started at the same Sheetz by 224 that we did last summer.
Friend: That was some trail shortcut. Me: Yep. See how fast we got lost.
ScienceOfDirt is offline   Reply With Quote
Old 08-20-2013, 03:44 AM   #8297
jules083
jules083's Avatar
Oddometer: 3,895
It was the sheetz in weirton that we started at.
I would much prefer a klx to the 800gs on this ride. It had rained a lot before I went, then rained again on the second day. There was a lot of mud. I'll get more written later on today if I get a chance.
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
COBDR and UTBDR on my klx250:
http://advrider.com/forums/showthread.php?t=1003485
jules083 is offline   Reply With Quote
Old 08-21-2013, 02:24 PM   #8298
jdubeemer
jdubeemer's Avatar
Oddometer: 69
Shift Lever
Can someone recommend a longer shift lever with a larger bar for the KLX 250? I have a 09 with the BB351 and FMF Q4 mostly because I am Six two and 200 lbs. My problem is my size 13 feet. It is fine with regular street boots but when doing the dual sport rides with my size 13 Gaernes it is hard to get my toe under the shifter. I tried rotating it up one notch on the shaft but then it is too high and I have to lift my whole leg to gear up. Not fun. I am not lazy but searching the web is very time consuming and I am 72 so I don't like to waste what time I have left to ride.
I would appreciate your input.
Thanks in advance.
Jim
R1200RT, R1100GS, KLX250/BB351
jdubeemer is offline   Reply With Quote
Old 08-21-2013, 03:47 PM   #8299
IDRIDR
Take me to the River
IDRIDR's Avatar
Oddometer: 1,466
Thanks in advance.
Jim
Search this thread for "shift lever"
XR650L will fit it. I have MSR. TNC has a suggestion here....
http://www.advrider.com/forums/showt...r#post16784410
Others have just cut and welded an extension.
IDRIDR is online now   Reply With Quote
Old 08-21-2013, 04:14 PM   #8300
jdubeemer
jdubeemer's Avatar
Oddometer: 69
Man thanks for the quick response. I will get one coming.
Jim
Old 08-21-2013, 05:04 PM   #8301
cjbiker
Nobody's Robot
cjbiker's Avatar
Oddometer: 2,734
I could not get the MSR XR650L to fit. It needs to be bent out to clear the stator cover. I heated that thing up cherry red and it still would not bend. I ended up cutting mine and welding in another 3/4". That worked out great.
I ended up welding a plate inside the shifter to protect the stator cover. That was a good idea, as I dropped the bike a few times on that side and you could see where it contacted the cover but didn't damage it.
cjbiker screwed with this post 08-21-2013 at 05:09 PM
cjbiker is online now   Reply With Quote
Old 08-21-2013, 05:35 PM   #8302
jdubeemer
jdubeemer's Avatar
Oddometer: 69
Do you think the stock XR650L shift lever would be easier to bend or is it steel also? I wonder how TNC handled that situation? Did he use the stock or MSR?
Jim
jdubeemer screwed with this post 08-21-2013 at 05:49 PM
Old 08-21-2013, 06:00 PM   #8303
cjbiker
Nobody's Robot
cjbiker's Avatar
Oddometer: 2,734
Jim
I'm sure the stock XR lever bends easily.
Old 08-21-2013, 06:18 PM   #8304
jdubeemer
jdubeemer's Avatar
Oddometer: 69
Thanks I'll give it a try.
Jim
Old 08-21-2013, 07:12 PM   #8305
C-Stain
C-Stain's Avatar
Oddometer: 6,169
Anybody have any ideas for a decent street biased DS tire for the KLX? I've promised Mrs. Stain no more off road till next year and I rode mine for the first time tonight. What a fun little bike - but the big assed knobby tires on it are LOUD and it seems a shame to ruin good knobbies on tarmac...
Originally Posted by Mr_Gone View Post
C-Stain is wise.
C-Stain is online now   Reply With Quote
Old 08-21-2013, 07:39 PM   #8306
ScienceOfDirt
U-Boat Rider
Oddometer: 1,723
Why not just use T-63 tires. They're pretty good on the street, and cheap enough. I run K60s for my street oriented tires, but they're pricey unless you're going to do it a lot.
Old 08-21-2013, 07:46 PM   #8307
FlyingFinn
Oddometer: 1,103
IRC GP-1.
I've used them on anything from DR200 to KLR650 and really love them as a "street oriented DS tire". Economical too, not a bargain basement cheap but ecomomical. They last and grip.
Mikko
"It is not when or how you die but how and if you truly were ever alive!" Dr. Jerri Nielsen FitzGerald
FlyingFinn is offline   Reply With Quote
Old 08-21-2013, 09:33 PM   #8308
Lutz
Killer Rabbit
Lutz's Avatar
Oddometer: 1,448
I could not get the MSR XR650L to fit. It needs to be bent out to clear the stator cover. ...
I think maybe you received something other than an XR650L shifter. XR600R or XR650R maybe? Anyway, I recently installed an MSR XR650L shift lever on mine, and it sticks significantly further away from the case than the stock KLX250S lever. In fact I tried a little bit to bend mine closer to the stator cover to close up the gap. And from any pictures I've seen of the MSR XR650L lever installed on the KLX, the situation has been the same...it sticks farther from the stator cover than stock.
Whatever the case, I found that it is much easier to shift now than with the OEM lever.
Lutz is offline   Reply With Quote
Old 08-21-2013, 11:20 PM   #8309
IDRIDR
IDRIDR's Avatar
Oddometer: 1,466
My shifter lever did fit too close or too far out (don't remember which). Put her in the vice and gave a good tug and bent her into submission. She sure is not the soft metal stocker and I do worry a little about breaking the shaft on a crash. The MSR is stiff. Should install a shifter snake. Maybe take TNC advice and check Moose?
IDRIDR screwed with this post 08-22-2013 at 08:34 AM
Old 08-22-2013, 05:27 AM   #8310
cjbiker
Nobody's Robot
cjbiker's Avatar
Oddometer: 2,734
Ah, right. It's been a while since I tried that. You're right, the XR650L shift lever stuck out way too far and needed to be bent in. In any case it was unusable as stock, and I couldn't get it to work.
If the OEM XR650L shifter is as soft as the one on my XR250R, then it should be a piece of cake to bend.
Times are GMT -7.   It's 07:56 AM.
