Old 12-02-2005, 05:30 PM   #1
Velocibiker OP
Adventure Antagonist
Velocibiker's Avatar
Oddometer: 1,164
Penny-tech stone guards for 640 Adventure
Well, I've been mulling the pros and cons of a Lexan style headlight guard. Basically, I don't like them. So have been on the hunt for wire mesh type stone guards. Plenty out there, just nothing that will fit the tiny Adventure lights.
Happened to be at Fry's (Outpost) the other day looking at PC cases. I spotted some 120mm case fans guards. Figured, what the hell. $4 for two. Looks like they might fit....
Turns out the fit like a charm! Cut off the two outer rings and this made the arms where you screw them into the case the perfect length. I kid you not! After a little bending + expanding two mounting holes a bit, they screwed right on to the two head light mounting bolts. One arm I cut off completely and the other I bent in so it rests on the head light case where the adjusting screw is. The metal is a lot stiffer than I though it would be, so it appears just having the two mounting points will work. If not, I can rig a small, low tension spring to the arm I cut off to hold it more securely in place. There is about a 1/4 inch gap between the lens and the guard. All and all, for only $4 and about an hour or so of labor, pretty slick.
Currently bikeless.
Velocibiker is offline   Reply With Quote
Old 12-02-2005, 05:55 PM   #2
dirtydeeds
I'm alive.
dirtydeeds's Avatar
Oddometer: 2,685
super genious.
990SMT, 640A, TXC450, TE510, ATC350X, ATC200ES, 550MXC, BW200. Need more space in garage.
dirtydeeds is online now   Reply With Quote
Old 12-02-2005, 07:59 PM   #3
ktmnate
ktmnate's Avatar
Oddometer: 3,066
Another great idea. at first I thought you used some film developing reels. I might have to give that a try.
Nate
ktmnate is offline   Reply With Quote
Old 12-02-2005, 08:27 PM   #4
GunshipDriver
Adventure in Iraq '07!
GunshipDriver's Avatar
Oddometer: 464
great post and great idea!
The Stable: '03 KTM 640 Adv / '08 KTM 530 EXCR / '05 BMW R1200RT / *looking for an Elise/Exige*
Former Rides: 06 950 SM / '04 950 Adv / '04 RSVR Factory / '04 625 SMC / '03 XR650R / '98 Tiger / '99 R1 / '97 ZX-6R
GunshipDriver is offline   Reply With Quote
Old 12-02-2005, 10:42 PM   #5
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,236
Good job Velo! Are they contacting the lights or is there some room between the guards and the lights? If not, what about using those in conjunction with the 3M stickies? I was wondering if small rocks might still get between the bars and damage the lights (which the 3M stuff would probably deal with). And perhaps the 3M stuff might help absorb some of the impact energy from larger rocks that are caught by your guard. They are not too expensive either, and I believe they do not yellow with age (or at least that's what they claim).
Just a thought...
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 12-03-2005, 01:33 AM   #6
BSTARD
Mmmmm...shiny
BSTARD's Avatar
Oddometer: 330
At least it don't look visually impaired.....it's just a computer geek, when r ya installing the pocket protector?
Flea Market ban in place since 19/3/2015!
BSTARD is offline   Reply With Quote
Old 12-03-2005, 07:08 AM   #7
KTM640Dakar
Motorsick
KTM640Dakar's Avatar
Oddometer: 2,089
Thanks for sharing your idea. I like it.
A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
It is not the destination, it's the journey.
KTM640Dakar is offline   Reply With Quote
Old 12-03-2005, 07:18 AM   #8
ChrisC
Amal sex?
ChrisC's Avatar
Oddometer: 6,316
I've had the 3M thick plastic stick-on covers on for almost two years. Still as clear as new....
Chris
1974 Bultaco Sherpa T 350
1943 BSA M20WD
ChrisC is offline   Reply With Quote
Old 12-03-2005, 01:02 PM   #9
BSTARD
Mmmmm...shiny
BSTARD's Avatar
Oddometer: 330
Are smashed headlights a real problem? It's just that I've bin riding bikes since I was 7 (30 years now) and most of em have had headlights and I have never had one broken by a rock or anything else for that matter. The most likely scenario for a broken light would be roost from the bike ya following. The bloke I ride with most of the time rides a GS1150ADV and boy does this thing throw some shit behind it. When I'm following him (which is most of the time) I just drop back out of the roost zone, problem solved.
I also use the 3M stuff on my ADV as to replace both lights is about $700AUD. It's not gunna stop a large rock from smashing the lens but it will hold the glass in place until a repair can be made, that's enough for me.
Old 12-03-2005, 03:13 PM   #10
Velocibiker OP
Oddometer: 1,164
Not a "problem". More like simple prevention. You said it yourself. $700 to replace . $4 is cheap insurance. You can't predict when that rock is going to fly. I also ride a lot on the street, and I've been hit a number of times with rocks. The windshield on my car has a couple good rock chips too. I suppose I could make a claim on my insurance if I get my lights cracked, but again, this is a hell of a lot easier and cheaper.
Currently bikeless.
Old 12-03-2005, 03:15 PM   #11
Velocibiker OP
Oddometer: 1,164
Just a thought...
There's about 1/4" between lens & guard. Enough to get a rag in for cleaning / bug removing.
Currently bikeless.
Old 12-03-2005, 03:32 PM   #12
craigincali
Just hanging around
craigincali's Avatar
Oddometer: 2,093
The fist time I took mine off road it cracked the low beam glass on a branch. I always hit branches and brush for some reason....
I like the idea and may do it myself. I still dont understand where you secured them but I am slow...
Me
I am usually drunk when I post so dont take it personally !
2010 KTM 990
craigincali is offline   Reply With Quote
Old 12-03-2005, 04:06 PM   #13
dagwood
dagwood's Avatar
Oddometer: 35,427
and in a pinch you can point them up and grill a bagel on them too.
now thats DS'ing
I'll find my way out....
dagwood is offline   Reply With Quote
Old 12-05-2005, 08:37 AM   #14
Velocibiker OP
Oddometer: 1,164
When you remove the fairing, there are two bolts at about the 4 and 8 o'clock position that hold the lights to the frame. There is also an adjusting screw at the 11 o'clock (low beam) and 1 o'clock (high beam).
The lower two arms attach to the mounting bolts (right behind the bolt head). The other arm, I just bent so it rests against plastic housing of the adjusting screw.
(I can't find a place to post a fische image...)
Does this help?
Currently bikeless.
Old 12-05-2005, 11:27 AM   #15
craigincali
Just hanging around
Oddometer: 2,093
perfect, thank you.
Me
2010 KTM 990
Times are GMT -7.   It's 11:12 AM.
