12-04-2005, 06:26 PM
#1 |
making chips
Oddometer: 26,648
lc4 odometer. who has the most miles?
ok... i'll edit the first post as you guys add info. how many miles are on your lc4 and what major repairs have you done? maintenance does not count. i'll start. mine has 25,000km with absolutely no engine repairs whatsoever.
lets hear it guys updated 11.02.10. gunnerbuck - 127,000km - http://www.advrider.com/forums/showthread.php?t=632893 jan from finland - 97,000km clintnz - 95,000km - http://www.advrider.com/forums/showthread.php?t=633753 samh - 71,000km - 44,000m - no repairs (new owner) castleman - 49,600km - 31,000m - water pump seal, ignition coil motomike - 33,600km - 21,000m - replaced main bearing, carb issue, new clutch mikeprod92211 - 25,600km - 16,000m - starter clutch loadedagain - 25,000km - 15,500m - no repairs herobikes - 24,480km - 15,300m - no repairs markjenn - 24,000km - 15,000m - no failures, has repaired several problem areas ausierob - 20,800km - 13,000m - no failures (slipping starter clutch) ktim - 20,800km - 13,000 - cylinder head leak empedrado - 20,800km - 13,000m - minor ignition failure martindktm - 20,000km - 12,000m - cylinder head leak braaap! - 14,500km - 8700m - no failures chrisc - 9,080km - 5,675m - no repairs sherpa - 0 - 0 - brand flippin new
** iba - 22936 *** Alcan5000 - 2006, 2008, 2012 *** Stenhouse Racing - Specializing in KTM Upgrades custom cnc service available to suit your specific needs. Loadedagain screwed with this post 11-03-2010 at 05:19 PM |
12-04-2005, 06:38 PM
#2 |
Molon Labe
Oddometer: 6,287
I'm just a piker. 2003 - 5,675 miles - no issues (save one leaky fork seal).
Chris '03 KTM Adventure 640 '43 BSA M20WD |
12-04-2005, 07:17 PM
#3 |
90S on the bench
Bwahahaha
71,000k's, 44,000m's and I haven't even got it yet. I'll know in 2 days if that's worth bragging about ![]() Work done... a lot I hope. |
12-04-2005, 07:49 PM
#4 |
...Robert
05 Adventure...0.8 miles...no repairs yet.
just got it yesterday, and we're supposed to get 4-8" of snow tonight.
Trebor Home Inspections 05 640 Adventure 08 KTM 250 XCFW I'd trade all my motorcycles for one Flying Dragon. |
12-04-2005, 08:07 PM
#5 |
HE AINT HEAVY HES MY LC4
Oddometer: 207
Miles
15,300 miles , no repairs , dead nuts reliable.2000 six days 640e
12-04-2005, 08:12 PM
#6 |
Oddometer: 243
Mileage
Total on bike 13,000 miles, over 10,000 this year (I bought the bike used a year ago). 2003 640 Adv. Not a single problem other than a loose wire in a connection that caused the bike to misfire for awhile and then die entirely. Was able to diagnose myself and has run smoothly ever since.
12-04-2005, 09:48 PM
#7 |
Desert Rat
Oddometer: 585
2000 LC4
16000 miles, replaced starter clutch on the right side under flywheel! Just need new tires.
LC4 Rider
12-04-2005, 10:06 PM
#8 |
Oddometer: 9,739
Around 15K, 5K with me on a 2000 Adv. If we're talking engine problems, none that I know of, although I have done a couple upgrades for problem areas.
- Mark |
12-04-2005, 11:02 PM
#9 |
Just Gas It!!
Oddometer: 377
13000 Miles, no major repairs but needs starter clutch looked at, needs new rear
"And then I asked myself, 'What would God do in this situation?'" "Locusts...." :uhhuh |
12-04-2005, 11:23 PM
#10 |
waiting for the big one
Oddometer: 2,210
14500 kms @ 15mths old... several catastrophic failures of the nut holding the handlebars and now the damn ashtray's full.
Fuckit, time to get a 950! ![]() '04, yeah, the faster orange one! braaap! screwed with this post 12-04-2005 at 11:25 PM Reason: clarification |
12-05-2005, 12:36 AM
#11 |
Guest
Oddometer: n/a
Do I get a prize?
31,000 miles on my 99 LC4. Pulser coil, clutch cable and water pump seal are the only parts replaced other than normal services. I commute to work on it nearly everyday and take the mirrors off and do the family ride thing in our local deserts 2 or 3 times a month.
There is a LC4 in my town with 63,000 miles on the clock. I have no idea how reliable its been. I truely use mine as a true DS bike. I hope KTM comes out with an affordable replacement soon. |
12-05-2005, 04:17 AM
#12 |
Oddometer: 222
Near 20 000km done in around 10 months and only trouble so far was the upper head part develop a leak at around 14 000km. Fixed it myself and no problem since. Lc4 rocks!
Offroad? Is where everythings begin! |
12-05-2005, 05:16 AM
#13 |
Oddometer: 2,306
'02 13,000 miles. Oil leak at valve rocker carrier to head joint, front wheel replaced under re-call (after having a number of spokes snap).
A good friend will come and bail you out of jail...but a true friend will be sitting next to you saying........."Damn..We F*cked Up" - Anon. |
12-05-2005, 06:20 AM
#14 |
Ignostic
Oddometer: 13,872
Where's Jerome?
![]() His website says he did a 75,000 click service in October; that's over 45,000 miles for the retro crowd. Does he win the date with Loaded?
Kronreif Trunkenpolz Mattighofen LC4 640 Its not so much staying alive; its staying human that counts. meat popsicle screwed with this post 12-05-2005 at 09:36 AM |
12-05-2005, 09:12 AM
#15 |
Washed Up Desert Racer
Oddometer: 4,687
21,000 miles, 8,000 since I bought it. I just put a new clutch in and did the bearing swap even though the original looked fine. The only issue I have had is with the carb. The slide is plastic as is the female piece that is pressed into the carb. I guess the years of vibration and some grit that had gotten in there had taken their toll, but the parts were easily replaced and all is well
Lost Coyotes MC |
