Old 12-05-2005, 07:55 AM   #1
Pointman0853 OP
Unregistered Gun Owner
Pointman0853's Avatar
Oddometer: 1,402
640 Adventure disappearing coolant problem...SOLVED!
I finally pulled all the hoses and radiators off my 640 Adventure to try and find where the coolant was going to.
My local dealer pressure tested both radiators and found the right one leaking up around the filler neck. Further inspection found the overflow nipple to be the culprit. As the radiator cap would vent coolant to the overflow, it would leak out here and evaporate leaving no clues...
Problem is, the whole thing is made of aluminum, and the nipple is some POS pressed in plastic thing! WTF was KTM thinking on this???
So now I either need to find a way to have a bit of short aluminum pipe welded on to this impossibly small area, or buy a new radiator... Can aluminum be soldered or braised??? I think not.
At least It looks like I won't need to be pulling the head off...
Pointman
AMA Life Member 600475
IBA #5
CarsonMotorSports.com
Pointman0853 is offline   Reply With Quote
Old 12-05-2005, 08:20 AM   #2
LKN4DRT
Mended
LKN4DRT's Avatar
Oddometer: 714
Could you use epoxy or JB weld?
Nine five O A
Six nine O E
Five three O
Four five O
Five O O
LKN4DRT is offline   Reply With Quote
Old 12-05-2005, 09:07 AM   #3
craigincali
Just hanging around
craigincali's Avatar
Oddometer: 2,064
Take it to a good radiator shop, you may be suprised.
Me
I am usually drunk when I post so dont take it personally !
2010 KTM 990
craigincali is offline   Reply With Quote
Old 12-05-2005, 11:46 AM   #4
Pointman0853 OP
Oddometer: 1,402
Radiator suprise!!!
SUPRISE! The radiator shop says they cannot fix it by welding....
I have some nasty two part epoxy given to me by a friend that is used on cruise missles or some such thing, and I'll try this.
Ima' bit concerned about long term hot/cold cycles effect on this, but my only other option is to get 'bent over' at the dealership for a new un'
Pointy
IBA #5
Old 12-05-2005, 12:25 PM   #5
craigincali
Just hanging around
Oddometer: 2,064
Intersting, doesnt sound like it would be that hard to fix.
Me
2010 KTM 990
Old 12-05-2005, 12:39 PM   #6
clintnz
Trans-Global Chook Chaser
clintnz's Avatar
Oddometer: 3,426
I cracked my rad a while back & the rad shop fixed it with some epoxy stuff which is still holding 10000km later.
Cheers
Clint
'03 KTM 640 LC4 Enduro
The wilderness, the desert - why are they not crowded
.................................................. .....with pilgrims?
clintnz is offline   Reply With Quote
Old 12-05-2005, 12:46 PM   #7
Jim Bud
Jim Bud's Avatar
Oddometer: 3,439
The trick to a good epoxy weld is surface preparation...
Pointy
It must be very clean...and free from all grease and wax....and moisture...
and roughing upthe surface with emery paper will only make it stronger
If you do the surface prep well. it will be very strong and last a long time....
Jim Bud
"Nearly all men can stand adversity, but if you want to test a man's character......give him power".....Abraham Lincoln
Jim Bud is offline   Reply With Quote
Old 12-05-2005, 01:08 PM   #8
rideLD
The further the better!
rideLD's Avatar
Oddometer: 5,391
Yep, JB weld is about the only thing that will work on a alluminum radiator. People have been fixing motocross radiators with it for years. I had patched a leak on my VFR800 radiator and it was still holding just fine 80,000 miles later when I sold it.
Karl | 2014 BMW R1200GSW Adventure | 2009 BMW G450x
Originally Posted by SchizzMan View Post
We pay Motorrad to design weight off the bike then pay TouraTech to bolt it right back on.
rideLD is offline   Reply With Quote
Old 12-05-2005, 10:35 PM   #9
Castleman
Guest
Oddometer: n/a
If you ever have coolant loss without any leaks, pull the gas tank and remove the breather tube that goes to the tappet cover. If its full of white milky snotty goo, replace your water pump seal. Don't remove the LC4 head looking for a leaky head gasket.
Old 12-06-2005, 07:42 AM   #10
Beez
Given to fly
Beez's Avatar
Oddometer: 5,796
Before you buy a new one (if the epoxy doesn't work) give Mylers a call. They specialize in motorcycle radiators and might be able to save it. I just had a severely bent rad. from my 450 EXC repaired by them and cannot believe how straight it is now. Cost me $70.00 including shipping, new is $199. Infact, you may want to call them BEFORE you gunk it up with epoxy. Good luck.
If the link doesn't work their number is 800-367-7699.
Beez is offline   Reply With Quote
Old 12-06-2005, 09:21 AM   #11
Hornet
Hornet's Avatar
Oddometer: 192
Myers Rocks
I second the Myers suggestion. When I got my DR650, the radiator was 'customized' by the previous owner in a drunken rage with a crowbar. They patched a small leak and straightened it out beautifully. The results were remarkable and the damage is not even noticable.
$80 including shipping and the turnaround was a week and a half (shipping from New Jersey to Utah and back included!).
Hornet is offline   Reply With Quote
Old 08-15-2006, 06:12 PM   #12
mazuko
mazuko
Oddometer: 5
mylers
I will third that motion...
I got my radiators back so fast is was silly... It only cost me $75 to fix the radiator on my old rmx 250. That radiator was crushed, and bent. It worked perfectly when I got it back..
He keeps his tricks secret.
mazuko is offline   Reply With Quote
Old 08-15-2006, 10:18 PM   #13
KTM640Dakar
Motorsick
KTM640Dakar's Avatar
Oddometer: 2,073
Your radiator can be TIG welded.
A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
It is not the destination, it's the journey.
KTM640Dakar is offline   Reply With Quote
Old 08-15-2006, 11:27 PM   #14
GODSPEED
finger lickin' good
GODSPEED's Avatar
Oddometer: 2,077
DR650- radiator
Godspeed
I'd rather do it than watch it.
Those of you with spouse and SO's know this already, but man give them a big hug, and don't take anything foregranted. - MACK RIP
When 51% of the grasshoppers vote, the ants are screwed.
http://godspeed.smugmug.com/Motorcycles
GODSPEED is offline   Reply With Quote
Old 08-16-2006, 12:50 PM   #15
PackMule
love what you do
PackMule's Avatar
Oddometer: 19,460
Originally Posted by GODSPEED
DR650- radiator
Oil cooler?
Nate in N.E.
Yes, I have a Dakar problem -- that there are 50 weeks of the year without Dakar!
They don't expect you to finish. That's why it's the Dakar. -- PPiA
PackMule is offline   Reply With Quote
Times are GMT -7.   It's 09:07 PM.
