Old 12-26-2005, 11:34 PM   #1
cross-country OP
cross-country's Avatar
Oddometer: 1,649
640 adv petcock
I was thinking about removing the main fuel petcock on my 640 and plating it off, (i have already built the block-off plate) and running the two small valves into a "Y" to the carb. Can anyone think of a reason why this would not work. I do alot of technical offroad on the bike and am worried about it being removed accidentally.
cross-country is offline   Reply With Quote
Old 12-27-2005, 07:37 AM   #2
ChrisC
Amal sex?
ChrisC's Avatar
Oddometer: 6,316
If you don't mind losing your reserve standpipe, have at it.
Oh, and somes pics might be interesting as the "suddenly missing petcock" topic gets some regular play around here...
Chris
1974 Bultaco Sherpa T 350
1943 BSA M20WD
ChrisC is offline   Reply With Quote
Old 12-27-2005, 08:57 AM   #3
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,224
Or get/make a rallye skidplate with boxes; best protection for your pet cock.
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 12-27-2005, 09:20 AM   #4
creeper
Still alive...
creeper's Avatar
Oddometer: 10,718
I've been talking with a fellow, Chris Barnes, who is making some very nice CF tank guards. He will be making a set with an extension on the left guard to offer a degree of protection for the petcock.
I only mention this as an alternative to removing the main petcock, which at first thought sounds like a good idea... until you remember that should you run out of gas and need to open the second valve to use what remaining fuel you have... you will need to stop and get off the bike to do it.
There have been a few situations come to mind where this would be neither practical nor safe.
C
So... how's tricks?
creeper is offline   Reply With Quote
Old 12-27-2005, 10:05 AM   #5
meat popsicle
Ignostic
Oddometer: 14,224
I dreamt pictures too...
Just CF or is Chris Barnes using kevlar fabric as well? The banter about this type of guards has been pretty adamant about CF alone being insufficient to protect the tank (see discussion in Orange Crush). Shouldn't be that much more expensive, unless you want ballistic kevlar
Old 12-27-2005, 10:12 AM   #6
cross-country OP
Oddometer: 1,649
Losing the reserve does not bother me. I won't be losing any fuel volume, just a reminder that Im close to empty. The low fuel light that is on it gives the rider the same "reminder'' that the 950 gives, since the 950 has no reserve setting on its petcock.
Old 12-27-2005, 11:02 AM   #7
Rad
Just me
Rad's Avatar
Oddometer: 12,172
Do you know anyone who had theirs knocked off on a 640 Adventure? Nobody here has ever posted that they have. I think it is not worry'n about.
Rad is offline   Reply With Quote
Old 12-27-2005, 11:20 AM   #8
meat popsicle
Ignostic
Oddometer: 14,224
Just a couple - certainly not a common problem. One fella even put it back on with JB Weld! But it seems like an unnecessary risk, particularly for folks who travel to B.F.E.
Old 12-27-2005, 11:25 AM   #9
Rad
Just me
Rad's Avatar
Oddometer: 12,172
If someone really feels it is a problem, protect it, don't remove it. There is far more chance of a leaky fuel line or flood'n or leak'n carb when parked where a petcock would come in very handy. Also, trail side repairs regading removal of the tank will be even more of a problem.
Old 12-27-2005, 12:10 PM   #10
meat popsicle
Ignostic
Oddometer: 14,224
So if this guy simply blocks off his petcock spot, then will he have to use the screw-valves on the other two fuel lines as a 'petcock'? Not sure of the physics of this stuff...
Old 12-27-2005, 12:19 PM   #11
ChrisC
Amal sex?
ChrisC's Avatar
Oddometer: 6,316
yes
Chris
1943 BSA M20WD
Old 12-27-2005, 12:23 PM   #12
Rad
Just me
Rad's Avatar
Oddometer: 12,172
Depends on the year, some had 1 valve and 1 petcock and some had 2 valves and 1 petcock.
Old 12-27-2005, 12:47 PM   #13
Donkey Hotey
De Jo Momma
Donkey Hotey's Avatar
Oddometer: 11,736
My 97 has two petcocks (left and right) and one screw valve (in front of the radiator). Both petcocks have reserve positions.
The 99 I just bought has one petcock (left side) and one screw valve (also in front of the radiator). The tank feels like it's got the lugs molded in for the additional right side petcock and just needs to be drilled.
Greg
Donkey Hotey is offline   Reply With Quote
Old 12-27-2005, 01:40 PM   #14
meat popsicle
Ignostic
Oddometer: 14,224
Originally Posted by ChrisC
yes
OK, oh one of brief wisdom... if I might clarify - why does the petcock on my bike (03 with two additional valves) shut off the gas (when the extra two valves are still open)?
Old 12-27-2005, 02:17 PM   #15
creeper
Still alive...
creeper's Avatar
Oddometer: 10,718
Why would you shut off the crossover valves unless you are removing the tank? To have a primary... and secondary "last chance" reserve?
So... how's tricks?
Times are GMT -7.   It's 12:59 AM.
