Old 02-05-2009, 06:59 AM   #136
Crawdaddy
Navigate 2 Adventure
Crawdaddy's Avatar
Oddometer: 2,241
Small World
Originally Posted by Donkey Hotey
We have been collecting information informally in the flea market but knowing those posts will soon expire, it's time to collect it here for the archives......The rumored numbers knocking around were: 5 imported to the USA in 1997 and 22 in 1998.
Talk about a small world......turns out Alfred (97) and I (98) have a mutual friend......so I went over to Vegas this past weekend and we went for a spin together on our 620 EGS bikes ......fun weekend!
Click on link below for ride report/photos (scan down the thread a ways for photos):
http://www.dualsport-sd.com/forums/i...showtopic=3976
A few teaser pics:
Chris Crawford (Crawford + 4 kids = Crawdaddy )
http://www.CrawdadOffRoadEvents.com
http://www.DualSportMoto.com
http://www.WhereAmIRiding.com
Crawdaddy screwed with this post 02-05-2009 at 08:37 AM
Crawdaddy is offline   Reply With Quote
Old 02-05-2009, 09:33 PM   #137
Crawdaddy
Crawdaddy's Avatar
Oddometer: 2,241
Thumb Renazco
Forgot to mention, got the new Renazco a couple of days before I left for Vegas.......~350 miles later seat and ass are doing fine.
Old 02-06-2009, 07:19 AM   #138
ChrisC
Amal sex?
ChrisC's Avatar
Oddometer: 6,316
Well, at least nobody can accuse you of having your chain too tight!
Nice bike...
Originally Posted by Crawdaddy
Chris
1974 Bultaco Sherpa T 350
1943 BSA M20WD
ChrisC is offline   Reply With Quote
Old 02-06-2009, 10:14 AM   #139
Crawdaddy
Crawdaddy's Avatar
Oddometer: 2,241
Nice bike...
Yep, the linkage tightens things up a tad when my fat ass is sitting on the bike....but I generally keep it within a few whiskers of slapping the swingarm from underneath.....which is also per KTM specs...
Crawdaddy screwed with this post 02-06-2009 at 07:21 PM
Old 04-19-2009, 05:47 PM   #140
LukasM
Oddometer: 5,417
Hey guys,
I am considering adding an LC4 to the stable again, just so I have something to ride around while I take the DR apart.
I found an Adventure locally, cheap and low kms. It's advertised as a 97:
Got a few questions that I hope you can help me with:
- Can the year be right if it doesn't have the low pipe?
- I prefer the later model plastic for the rear, does this bolt on or do I need a newer subframe?
- What can I do for engine reliability, other than the roller bearing upgrade?
Lukas
Old 04-19-2009, 09:34 PM   #141
cross-country
cross-country's Avatar
Oddometer: 1,661
Lukas, I did that conversion on my E/GS along with the exhaust conv. It was pretty easy, I just welded on some spacers to the top of the subframe. I think I also welded some nuts to the bottom, can't recall for sure. Worked fine until the subframe started cracking in a few spots from age and abuse. Then I replaced it with one from an '03 which required no modification.
cross-country is offline   Reply With Quote
Old 04-19-2009, 11:16 PM   #142
wrk2surf
on the gas or brakes
wrk2surf's Avatar
Oddometer: 6,764
Just get it Lucas... you can do a vin year check online; its funny I like the old plastic...I have seen a wood block used on the old subframe to do the new fender but in sure something can work... anything newer will bolt up and partouts are aplenty for upgrades!! sorry to say but it beats the DR anyday..
I would change crank seal, check oil bypass piston and spring and the check oil pumps and jets.. all things could be done cheap and wise.. Lubrication is key on these.. valve adjust, harness check, new coolant and relube, antisieze and loctite of everything
wrk2surf is offline   Reply With Quote
Old 04-24-2009, 02:48 PM   #143
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,234
bump for G-funk.
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 04-24-2009, 03:04 PM   #144
LukasM
Oddometer: 5,417
Thanks for the info, sounds like this is easily doable. LC4 subframes are a dime a dozen here as well, so I might snag one on Ebay.
Originally Posted by wrk2surf
Just get it Lucas... sorry to say but it beats the DR anyday..
You know not what you speak of my friend. Or you haven't seen my DR! (and how could you, I don't have any pics yet that show the latest mods)
But I am going to look at the 97 as well as an 98 rolling chassis this weekend. Both are affordable and I need a project here in Vienna anyway (my DR is in Madrid).
Good stuff, thanks! Not sure how far I should trust myself to work on the engine, after seeing your thread I might be tempted to add Wossner piston, some head work, 660 crank and a cam....
Old 04-24-2009, 08:49 PM   #145
G-Funk
That ... Umm ..... "Dude"
G-Funk's Avatar
Oddometer: 5,259
Originally Posted by meat popsicle
bump for G-funk.
Thank you, and soon .....
I've been reading and re-reading this thread for throughout the day.
I've pulled the trigger, and I'm waiting the hear back. I would think it will be about 10 to 14 days from now ...... I'll be posting some pics.
G.
03 Caponord
"The Funness out-weighs the Dumbness ....." - Mr. Jetmoto
G-Funk is offline   Reply With Quote
Old 04-25-2009, 11:07 AM   #146
GODSPEED
finger lickin' good
GODSPEED's Avatar
Oddometer: 2,077
G.
soon indeed...
Godspeed
I'd rather do it than watch it.
Those of you with spouse and SO's know this already, but man give them a big hug, and don't take anything foregranted. - MACK RIP
When 51% of the grasshoppers vote, the ants are screwed.
http://godspeed.smugmug.com/Motorcycles
GODSPEED is offline   Reply With Quote
Old 04-25-2009, 11:33 AM   #147
meat popsicle
Ignostic
Oddometer: 14,234
Originally Posted by GODSPEED
soon indeed...
ah-ha...
Old 04-25-2009, 02:53 PM   #148
G-Funk
G-Funk's Avatar
Oddometer: 5,259
ah-ha...
Yuppers ..............
I'm buying Godspeed's 97 (titled as a 98) 620 adv ................
I'm stoked ................. though I gotta say, this is a sickness or disease. I'm not sure which one yet ......
Godspeed - got yer PM - and I'll be replying in more depth later today.
G.
03 Caponord
Old 05-03-2009, 09:03 AM   #149
Crawdaddy
Crawdaddy's Avatar
Oddometer: 2,241
Thumb
Congrats! Here's a front 620 wheel raised in your honor!
Old 05-03-2009, 10:36 AM   #150
G-Funk
G-Funk's Avatar
Oddometer: 5,259
Thank you sir .... thank you.
And!
Here she is ......
Now on to going through her ..... like swapping out the carb, it has the edelbrock in it - but it also came with a Mikuni to throw in.
More later - as I am working off a mild hang over from Dagwood's B-Day party yesterday ..........
G.
03 Caponord
Times are GMT -7.   It's 10:47 AM.
