Old 03-30-2013, 09:04 AM   #346
DaddyBigDaddy
AKA -Evel Kneilson
DaddyBigDaddy's Avatar
Location: Liberal ShitHole, San Fran-sissyco, Kalee-Fornee-a
Oddometer: 310
Originally Posted by wrk2surf View Post
You know the newer two disc hub is with the larger 26mm axle (for 48mm forks) right?
Yes, I converted to 20mm RTT triples/damper and 2007 640A 48mm forks
Have 26 and 30mm axles
DaddyBigDaddy
1998 KTM 620 Adventure
2007 KTM 950 SE
2008 KTM 530 EXC
2004 KTM 450
DaddyBigDaddy is offline   Reply With Quote
Old 04-12-2013, 03:34 PM   #347
hondahawkrider
DAMN Rider/Motardian
hondahawkrider's Avatar
Oddometer: 829
Phase 1 of rebuild almost done
-Jason
DAMN Rider DAMN Rider
Maybe you have to be messed up... before you can step up!
hondahawkrider is offline   Reply With Quote
Old 04-20-2013, 02:24 PM   #348
alfredman22
alfredman22's Avatar
Oddometer: 151
OK I gotta ask Handahawkrider, what the story on that super secret subframe? Its not like mine, my tool box is parallel with the ground, is it modified?
alfredman22 is offline   Reply With Quote
Old 04-21-2013, 07:41 PM   #349
hondahawkrider
Oddometer: 829
There is an earlier post #84..
The 620 EGS-E Adventure had a beefier rear subframe to allow it to carry the heavier rear tanks like the rallye that it wasn't given for street use... At the time, the EGS-E 620 was the street version, similar to how the 640adv is the street version of the 660 Rallye.. The rear just wasn't changed at the time..
Many replace the rear sub from the later 640 to accommodate a more modern high pipe on the LHS rear..
-Jason
Old 04-23-2013, 06:29 PM   #350
DaddyBigDaddy
AKA -Evel Kneilson
Oddometer: 310
Seat
Have a NEW super rare KTM Rally seat from 1997 620 this is the cover and Rally foam only NO SEAT PAN
This was only on the factory Rally bikes and is blue and white. The production seats for the public were the blue/orange seat with stiffer foam. This is NEW never mounted or sat upon!
Thought I'd toss it out to 620 guys before posting in flea market
$120 shipped
[email]Ken@AspenRacing.com[/
DaddyBigDaddy
2007 KTM 950 SE
2008 KTM 530 EXC
2004 KTM 450
DaddyBigDaddy screwed with this post 08-15-2013 at 09:51 PM Reason: Sold
Old 04-23-2013, 07:17 PM   #351
DaddyBigDaddy
AKA -Evel Kneilson
Oddometer: 310
Extreme forks
I also have a set of perfect 50mm Extreme forks, triples, stem w bearings on the block including the bar mounts and original bars...not the front wheel though.
356 original miles on them! $435 shipped
Ken@AspenRacing.com
DaddyBigDaddy
2007 KTM 950 SE
2008 KTM 530 EXC
2004 KTM 450
DaddyBigDaddy screwed with this post 04-24-2013 at 07:48 PM
Old 04-25-2013, 08:12 AM   #352
DaddyBigDaddy
AKA -Evel Kneilson
Oddometer: 310
Finally
Almost have the 1998 620 finished
Need a right side caliper carrier and high fender brake line of a dual disc 640 if anyone knows where to get them
DaddyBigDaddy
2007 KTM 950 SE
2008 KTM 530 EXC
2004 KTM 450
Old 04-25-2013, 08:18 AM   #353
mtbdemon
mtbdemon's Avatar
Oddometer: 999
SWEET! I'm still working on my exhaust conversion so I can save my stock pipes. How did you mount the center stand? My frame looks to have no mounts at all for a center stand. Is it off a 640?
I am a leaf on the wind, watch me.....ride (I know, it makes no sense)
2007 YZ 250F SOLD
2004 KTM 200 EXC
mtbdemon is offline   Reply With Quote
Old 04-25-2013, 05:51 PM   #354
DaddyBigDaddy
AKA -Evel Kneilson
Oddometer: 310
There are holes there but they are threaded. Drill them out and you can mount a 640 S center stand and keep the stock kickstand too
DaddyBigDaddy
2007 KTM 950 SE
2008 KTM 530 EXC
2004 KTM 450
Old 04-25-2013, 05:54 PM   #355
DaddyBigDaddy
AKA -Evel Kneilson
Oddometer: 310
I just threw on a set of 2004 640 Supermoto stock pipes/mufflers... Bolts right up but make sure you get the exhaust flanges too
DaddyBigDaddy
2007 KTM 950 SE
2008 KTM 530 EXC
2004 KTM 450
Old 04-25-2013, 05:55 PM   #356
DaddyBigDaddy
AKA -Evel Kneilson
Oddometer: 310
Wanted to keep the stock plastics.
DaddyBigDaddy
2007 KTM 950 SE
2008 KTM 530 EXC
2004 KTM 450
Old 04-26-2013, 09:46 AM   #357
biensur22
biensur22's Avatar
Oddometer: 179
You still have to weld on the spring return post. Otherwise, he's right, just drill out the frame holes (they're threaded) and fit up any 640 center stand. I had one on for a weekend, lost it in this years desert dash.
Current Rides:1998 KTM 620 Adventure
Past Rides: 1994 KTM 400 EXC WP/D LC4 - Plated; 2001 BMW F650GS Thumper; 1970 CB175; 2003 KLR250
biensur22 is offline   Reply With Quote
Old 07-10-2013, 10:39 PM   #358
hondahawkrider
Oddometer: 829
Anyone know of a source for a skid plate.. I've picked up a few on the cheap to play with mounting.. Since I'm running the low pipes, there isn't enough space on the rhs where the pipe for standard ktm adv skidplate.
If nobody has one, I'll splice something together
-Jason
Old 07-16-2013, 06:46 PM   #359
hondahawkrider
Oddometer: 829
Anyone know if the rally tank, part #5850701304444 - this one
http://www.bikersjersey.com/product/...fo.aspx?id=986
will fit on the egs-e... I'm not having much luck cleaning off the previous sticker off mine (its molecularly bonded to the tank, and its faded) so its gonna have to come off and see if it can be cleaned up.. If the rally tank works, I'd use it and take my time trying to clean mine..
Thanks in Advance
-Jason
Old 08-03-2013, 03:29 PM   #360
hondahawkrider
Oddometer: 829
Picked up a skidplate and a tank from eBay UK for decent price including shipping...
He's got some more stuff - looks like he's parting out a EGS
http://www.ebay.com/sch/m.html?_odkw...m+lc4&_sacat=0
-Jason
Times are GMT -7.   It's 09:54 PM.
