Old 05-16-2015, 01:32 PM   #1
tharondrake OP
Oddometer: 4
Ke100 brake light problem
Just picked up a used ke100. The battery was dead no lights were working. Put a new battery turn signals and headlight now work. Tail lamp had been replaced, the wires wern't plugged in. I plugged them in tail light works but no brake light. There are three wires coming from the bike and only 2 from the lamp. Did the previous owner just put on he wrong lamp. Can I make this one work?
tharondrake screwed with this post 05-16-2015 at 02:09 PM
tharondrake is offline   Reply With Quote
Old 05-16-2015, 04:14 PM   #2
techforlife
CDI REPAIR
techforlife's Avatar
Oddometer: 4,333
Pull the bulb....if it only has 1 contact on the bottom you have a choice,either you can have a park light,,or brake light,not both,you need a 2 cintact bulb socket with ground..in other words you need a three wire tail light for everything to work..
B
techforlife is offline   Reply With Quote
Old 05-19-2015, 01:51 PM   #3
tharondrake OP
Oddometer: 4
Where would I find one of these
Old 05-22-2015, 05:54 PM   #4
tharondrake OP
Oddometer: 4
Got the brake light figured out, now working on the front brake handle having. Problems with the switch there
Times are GMT -7.   It's 05:20 PM.
