03-28-2006, 03:03 PM
#61 |
...Robert
Cool...nice find...thanks...he really raised it alot...looks like he must have a nut on the backside of the upper connection, wonder if that scraped the stanchion at all...
I've yet to do mine....time just fills up with other stuff and slips away....
Trebor Home Inspections 05 640 Adventure 08 KTM 250 XCFW I'd trade all my motorcycles for one Flying Dragon. |
03-28-2006, 05:18 PM
#62 | |
Ignostic
Oddometer: 13,839
![]() Note: the front fender does not look raised in that pic but it was with the other two (and a pic of a rallye cockpit setup).
Kronreif Trunkenpolz Mattighofen LC4 640 Its not so much staying alive; its staying human that counts. |
03-28-2006, 05:49 PM
#63 | |
Formerly AKA Boejangles
Oddometer: 4,695
Improv is a beautifull thing |
03-28-2006, 06:44 PM
#64 | |
Ignostic
Oddometer: 13,839
![]() Anyways, just trying to help out sherpa - he is still worried that the raised low-boy will hit the bottom of the triple clamp.
03-29-2006, 05:04 PM
#65 |
Chrome+Paint=Garage bike
Oddometer: 126
275mm
I know that Fox and Rock Shox used a goofy way of measuring fork travel. I ASSume that they all do this
Here is how they figured it Measure the how far the shock will compress under load. Then add the negative (pull) That may seem strange but negative is needed according to the shock maker to help keep the wheel on the ground. (no sag is NOT the negative. sag uses up the compressive part) I think it is there so when you pull a wheelie the forks don't go bang! when the springs press them to the end of the tubes. It always seemed a like a sales tactic to me, but there maybe 1" (25mm) on the front fork of a KTM and that is where you have the missing 25mm As always I could be wrong |
03-29-2006, 06:07 PM
#66 | |
Tyre critic
Ohlins shocks have what they call an "anti-top-out spring", IIRC. Yes it is designed to soften the end of the stroke when the load suddenly comes off the shock (think slamming on the front brakes thereby lifting the rear wheel). As a result, they also say you can't measure & set the static sag the same way you would do with a normal shock.
I don't know how this figures into the travel measurements as I've never really bothered with such things on my road bikes. On my '05, I have the fork tubes pulled through by 25mm and it has bottomed the fender into the underside of the lower triple clamp several times. I will reduce the air gap next fork service, to help stop it bottoming.
Cheers, Colin KTM LC4 640 Question? Check here first --> KTM LC4 (640) Index Thread Quote:
04-12-2006, 01:17 PM
#67 |
Ignostic
Oddometer: 13,839
Heya sherpa,
Check out post #6 in this thread. Not sure about the newer suspension that your bike has, but his suspension had another couple inches...
07-12-2007, 03:06 PM
#68 |
Oddometer: 34
Hey guys i tried the gum trick on my forks but found it had an oily taste afterwards, is it worth trying a different brand of gum???
