Go Back   ADVrider > Bikes > Beasts > Moto Bellissima: All Other Dualsports
Old 11-11-2012, 03:11 PM   #3346
oalvarez
Resident Raggamuffin
oalvarez's Avatar
Oddometer: 2,554
Originally Posted by pyoungbl View Post
Leafman weighed his standard GS recently (a 2007 1200GS) in totally stock condition, maybe 1 gallon short of a full tank. That weighed 545 lbs. Now if we can get someone with a standard Stelvio to weigh it we can put this to rest. FWIW, the NTX came in at 616 lbs with 1/2 tank and about 650 with a full tank. That's about 60 lbs difference between the basic GS and the NTX with about the same amount of fuel. I'm guessing that the basic Stelvio will be within 20 lbs of the basic GS. If that's correct, the difference is insignificant.
the comparison made above was vs. the current NTX.....yes, of course, we can do this all day long to try and "match up" the bikes to get the results one wants, but as for the current GS and a NTX, the GS is much lighter which is the point that i was trying to make.
the basic (non-NTX type) Stelvio and a GS will be closer in weight as you say, but even then the Stelvio will be the heavier of the two.
2014 Ducati MTS1200S
2012 Vespa 300 Super
past: Ducatis, Aprilias, Moto Guzzis, a Husky, KTM 1290 SDR, and some BMWs as well.
oalvarez is online now   Reply With Quote
Old 11-11-2012, 08:01 PM   #3347
James Adams
Misplaced
James Adams's Avatar
Oddometer: 9,673
I installed the OEM heated grips this afternoon. By far the most difficult part of the installation was locating the plugs. On mine, they were hiding underneath the ABS pump. I probably spent a good 60+ minutes just looking for them after the tank came off.
But it's worth it. Riding back home from my friend's shop with warm hands was delightful.
KTM 505
James Adams is online now   Reply With Quote
Old 11-11-2012, 08:59 PM   #3348
Ham
Oddometer: 321
So we are back at the inane discussion on weight. Would the man, and I will be PC here, woman, please step forward that can clean and jerk 500 lbs.............thats what I thought.
What matters here is Center of Gravity, balance, tractability.
COG goes to Guzzi because of engine design...you can only put those parrallel cylinders just so low. Balance in my estimation goes to Guzzi because of COG, and lower fuel, as in height, capacity. I think the engine is more in line with very low grunt and torque. And, as my brother pointed out, you just sit down into the Guzzi better.
So the GS simply isn't as good of a design. In its day, a much simpler design day I might add, the GS was quite good, its day is done unless BMW gets back to the R80s basics.
I know there will always be people who go after the GS fancy tech, witness the car arena. But the truth is there are simpler better balanced machines now and the Stelvio is one of them. The only thing remaining to be seen is if it dependable. I will get back to you next summer.
And if I had spent well north of 20K...I would get quite defensive too.
Ham is offline   Reply With Quote
Old 11-11-2012, 10:54 PM   #3349
oalvarez
oalvarez's Avatar
Oddometer: 2,554
^ funny
Old 11-12-2012, 12:09 AM   #3350
THE BONE SHAKER
Adventure Tourer
THE BONE SHAKER's Avatar
Oddometer: 269
Amen to that!!!!!!!
UNDERSTEER is when you hit the wall forwards.
OVERSTEER is when you hit the wall backwards.
HORSEPOWER is how fast you hit the wall.
TORQUE is how far the wall moves after you hit it
THE BONE SHAKER is offline   Reply With Quote
Old 11-12-2012, 08:05 AM   #3351
James Adams
Misplaced
Oddometer: 9,673
Just a reminder to check your Guzzi for loose hardware. I found that three out of four of my upper engine mount bolts were loose (and the one that wasn't loose was actually missing) and also I'm missing some of the hardware that holds the license plate assembly on.
KTM 505
Old 11-12-2012, 01:00 PM   #3352
Ham
Oddometer: 321
Well I guess i will get out the torque wrench and manual and go through the whole bike then. I wish my heated grips and top box would get here.
Old 11-12-2012, 01:05 PM   #3353
Sock Monkey
Corporate slave
Sock Monkey's Avatar
Oddometer: 2,124
Which top box did you go with?
-SM
aka NoVector
Current: 2012 Moto Guzzi Stelvio NTX, 2008 Yamaha WR250R
Gone: Ducati Multistrada, Moto Guzzi Norge, BMW R1200GS, BMW F650 GS Dakar, KTM 520 EXC, Suzuki DRZ400E, and the list goes on.......
Sock Monkey is offline   Reply With Quote
Old 11-12-2012, 01:35 PM   #3354
Ham
Oddometer: 321
While I was at the dealership they just got confirmation from Guzzi that you could get the one that matches the panniers. That is the one that I want though I think I will need to design a pad for my wife. I just like the looks of that one.
Old 11-12-2012, 01:41 PM   #3355
James Adams
Misplaced
Oddometer: 9,673
You can order that case from Twisted Throttle as well:
http://www.twistedthrottle.com/trax-...ck-or-aluminum
They also sell a "backrest":
http://www.twistedthrottle.com/backr...trax-alu-boxes
KTM 505
Old 11-12-2012, 01:59 PM   #3356
keithn
Oddometer: 19
I purchased the Guzzi trunk then used a giving back pad. Shaved it down and mounted it works great.
keithn is offline   Reply With Quote
Old 11-13-2012, 07:32 AM   #3357
RefJeff
Is it Friday yet?
RefJeff's Avatar
Oddometer: 182
Whitehorse Gear also carries the SW-Motech Trax luggage.
http://www.whitehorsegear.com/sw-mot...lu-box-topcase
Almost Heaven - West Virginia
2013 Moto Guzzi Stelvio NTX
1991 Suzuki GSX1100G - For Sale
1980 Kawaski KDX 250
RefJeff is online now   Reply With Quote
Old 11-13-2012, 08:15 AM   #3358
James Adams
Misplaced
Oddometer: 9,673
Good to know. I wonder if SW-Motech has a west coast distributor? Both Whitehorse and Twisted Throttle are in New England.
KTM 505
Old 11-13-2012, 05:12 PM   #3359
Ham
Oddometer: 321
Thanks for the options folks. When I get time next week I will pursue.
Old 11-15-2012, 08:06 AM   #3360
pyoungbl
Colonel Blood
Oddometer: 481
NTX Aux light mod
The Hella lights on the '12 NTX can short out due to vibration. The leads going into the rubber boot will rub against the inside of the metal light housing and that's where the short happens. Leafman60 can tell you all about that adventure. This will cause a 30A fuze to blow and suddenly the electrical charging system is inop. I recommend installing a fuze in each light lead, in addition to preventing the short in the first place. This job is best done with the side panels off:
This is the connection between the wiring harness and the light leads. Note that the harness wires are color coded, not so on the Hella lead. Blue is the ground wire.
Splice in a fuze holder and install a 7.5A fuze. Put everything back in place and you are done! Oh, this is a good time to make sure all the wires are not going to get close to the exhaust, particularly on the right side.
Growing old ain't for sissies!
pyoungbl screwed with this post 11-15-2012 at 10:01 AM Reason: typo; should read 7.5A, not 75A
pyoungbl is offline   Reply With Quote
Times are GMT -7.   It's 06:20 AM.
