Go Back   ADVrider > Bikes > Beasts > Moto Bellissima: All Other Dualsports
Old 11-26-2012, 11:08 AM   #3421
kirb
should be out riding
kirb's Avatar
Oddometer: 1,806
Originally Posted by pyoungbl View Post
Kirb,
On a sorta related note; since you are the king of CNC, waterjet cutting, fabrication, and such have you considered making up a storage case to go between the right side case and the bike? There must be 4" of wasted space there, enough for a substantial tool box. Others have made do with a PVC pipe and that seems to work well but I'd like a bit more storage.
Peter Y.
King? Not really. I am an electrical engineer with a CAD department and a laser cutter down the street. I have enough contacts for fab up said tool/storage box without too much trouble. I have more of a desire to help out/share ideas of bike stuff more than turn a hobby into a job.
I have thought about that void space and wanted to see if Stucchi Luigi would convert the aux fuel tank they make (pre-NTX) into a storage box.
A Ducati, some Guzzi, a KTM, and a Excelsior...Indian in resto.
kirb is offline   Reply With Quote
Old 11-26-2012, 11:14 AM   #3422
James Adams
Misplaced
James Adams's Avatar
Oddometer: 10,086
Originally Posted by Sock Monkey View Post
Very nice James!
Do you have a bit of commentary re. how the big girl held up? Good hook up w/ the knobs, no TC or ABS troubles? Nothing vibrated loose? Etc....
-SM
The tires (mostly-new Scorpion Rally on the back, 4000-mile worn TKC-80 on the front) worked great at 25psi; I never had any major traction issues and no wheel damage either. The ABS and TC were disabled for the dirt. No drops and nothing vibrated loose, but the fork seals are shot. The suspension was the biggest challenge--it is not set up for all of the hard-edged bumps encountered in that type of terrain. A steering damper would help in the sand.
If I keep doing things like this, however, I imagine that a clutch replacement will be needed quite a bit sooner than usual.
505 XC-F DUKE 690
James Adams is offline   Reply With Quote
Old 11-26-2012, 12:22 PM   #3423
Sock Monkey
Corporate slave
Sock Monkey's Avatar
Oddometer: 2,239
ROFL!
So, what did in your fork seals, hard hits or dust/dirt/grime? I'd be surprised if you blew them out with hard hits as your rims would likely be toast as well.
Re. the clutch, yeah, that's something BMW did right after years of people roasting the dry clutches in muddy bogs, sand, etc.....they went with a wet clutch for '13. The bad news is like all wet clutches, it turns your oil to blackened syrup in no time. I love changing the oil in a dry clutch bike and seeing nice clean(ish) oil in there vs. the grunge that comes out of a wet clutch bike. I wonder if we'll see wet clutches on Guzzi's in the future, or if they'll stay with the dry variety....
In any case, good on ya for takin' the big girl out and playing in the dirt with the mini bikes.
-SM
aka NoVector
Current: 2012 Moto Guzzi Stelvio NTX, 2008 Yamaha WR250R
Gone: Ducati Multistrada, Moto Guzzi Norge, BMW R1200GS, BMW F650 GS Dakar, KTM 520 EXC, Suzuki DRZ400E, and the list goes on.......
Sock Monkey is offline   Reply With Quote
Old 11-26-2012, 12:39 PM   #3424
James Adams
Misplaced
Oddometer: 10,086
I know I was using the full travel of the suspension and there was dirt and sand everywhere, so I'm guessing it was a combination of the two.
The dry clutch is great in most situations. Fortunately the Guzzi is geared low enough that you can just tractor through a lot of things in first gear.
505 XC-F DUKE 690
Old 11-26-2012, 01:49 PM   #3425
Sock Monkey
Corporate slave
Oddometer: 2,239
+1
That's what, IMO, makes the Guzzi more attractive than its rivals. Its low-rpm performance is better than anything else I've ridden in this class of bike. The closest thing to it is.....*gasp*.....a Harley (or similar long-stroke cruiser), which makes gobs of usable torque from idle on up. The big difference with the Guzzi is the fun keeps going all the way to the 8krpm redline, with a real nice "kick" right around 5krpm.
-SM
aka NoVector
Old 11-26-2012, 01:54 PM   #3426
dirtymartini
Shaken, Not Stirred
dirtymartini's Avatar
Oddometer: 2,615
Use the footpeg to gain extra height to swing your leg over the pannier. Obviously it has to be on the sidestand to do that, but it should be on the sidestand anyway when you mount up as she's a hefty girl and can get away from you if you try it without. DAMHIK.....
-SM
This is what I do...simliar to getting on a horse; step on the footpeg and swing you leg over. It's the only graceful way I have found to mount up!
"A free people ought not only to be armed and disciplined, but they should have sufficient arms and ammunition to maintain a status of independence from any who might attempt to abuse them, which would include their own government." -- George Washington
dirtymartini is offline   Reply With Quote
Old 11-26-2012, 03:19 PM   #3427
James Adams
Misplaced
Oddometer: 10,086
I've done this with pretty much every bike I've owned, and not because I'm short, either. It just made sense.
505 XC-F DUKE 690
Old 11-26-2012, 03:20 PM   #3428
James Adams
Misplaced
Oddometer: 10,086
+1
-SM
Large-diameter dry clutch = good flywheel
505 XC-F DUKE 690
Old 11-26-2012, 03:36 PM   #3429
Sock Monkey
Corporate slave
Oddometer: 2,239
True....to a point. There's a lot more going on than just that though, because my BMW GS didn't run worth a damn below 3k rpm, and would cough and die at 2500 rpm. The Stelvio, on the other hand, pulls like a freight train from 2k rpm.
-SM
aka NoVector
Old 11-26-2012, 03:58 PM   #3430
James Adams
Misplaced
Oddometer: 10,086
-SM
Indeed. Any idea how the bore/stroke compares?
505 XC-F DUKE 690
Old 11-26-2012, 04:42 PM   #3431
Toadride
Toadride's Avatar
Oddometer: 839
You can see that I am definately using the side stand down, foot on peg and over method.
With my get up, I've been doing it for 15000 miles now. The side stand is holding up very well, unlike my F800GS side stand that bent all out of shape doing that.
You can also see the 4" ABS I used to fill the void between the wheel and the bag frame. Works pretty well but if there was an aluminium box that wide and, say another 6" deeper, that would be great too.
Old 11-26-2012, 04:48 PM   #3432
stevie88
That's gotta hurt
stevie88's Avatar
Oddometer: 19,311
Originally Posted by james adams View Post
indeed. Any idea how the bore/stroke compares?
bmw 101-73
mg 95-81.2
I wasn't born with enough middle fingers.
stevie88 is offline   Reply With Quote
Old 11-26-2012, 05:51 PM   #3433
Mr. B
Contrarian
Mr. B's Avatar
Oddometer: 1,909
-SM
You mean the "old man" way to mount your bike. I do that when nobody is looking
'12 Moto Guzzi Stelvio NTX
'06 Honda Helix
Mr. B is offline   Reply With Quote
Old 11-26-2012, 06:01 PM   #3434
dirtymartini
Shaken, Not Stirred
Oddometer: 2,615
I've given up on hiding it anymore.... In January I qualify for the senior citizen discount at my local grocery store
Old 11-26-2012, 06:12 PM   #3435
kirb
kirb's Avatar
Oddometer: 1,806
I'll be looking into it this winter....looking at this photo, you really need a rear rack. You can buy the combo meal if I do another run.
Times are GMT -7.   It's 12:29 AM.
