Go Back   ADVrider > Bikes > Beasts > Moto Bellissima: All Other Dualsports
Old 02-27-2013, 04:44 PM   #4156
dirtymartini
Shaken, Not Stirred
dirtymartini's Avatar
Oddometer: 2,619
Heated Drip question
I just installed my factory heated grips. Should they turn on with key on or do you need the engine running. I can't get mine to show in the display.
"A free people ought not only to be armed and disciplined, but they should have sufficient arms and ammunition to maintain a status of independence from any who might attempt to abuse them, which would include their own government." -- George Washington
dirtymartini is offline   Reply With Quote
Old 02-27-2013, 05:21 PM   #4157
stevie88
That's gotta hurt
stevie88's Avatar
Oddometer: 19,431
I suspect the engine needs to be running. Why doncha fire that puppy up and find out?
I wasn't born with enough middle fingers.
stevie88 is offline   Reply With Quote
Old 02-27-2013, 05:23 PM   #4158
dirtymartini
Shaken, Not Stirred
Oddometer: 2,619
I still have the tank off for some other work....
Old 02-27-2013, 05:27 PM   #4159
James Adams
A few crayons short.
James Adams's Avatar
Oddometer: 10,219
Engine running.
505 XC-F DUKE 690
James Adams is offline   Reply With Quote
Old 02-27-2013, 05:34 PM   #4160
dirtymartini
Shaken, Not Stirred
Oddometer: 2,619
Originally Posted by James Adams View Post
Engine running.
Thanks. By the looks of the extended forecast I won't be riding anytime soon. Time for farkling!
Old 02-27-2013, 05:56 PM   #4161
stevie88
That's gotta hurt
stevie88's Avatar
Oddometer: 19,431
Are you performing a canisterectomy?
Old 02-27-2013, 06:06 PM   #4162
dirtymartini
Shaken, Not Stirred
Oddometer: 2,619
Maybe I should? Seems like I saw a tutorial on Wild Guzzi... Have you done it to yours?
Old 02-27-2013, 06:53 PM   #4163
stevie88
That's gotta hurt
stevie88's Avatar
Oddometer: 19,431
Yes. It's pretty easy since you've already got the tank off. The one thing I did differently from the posted steps was to tee the tank vent hose into the overflow drain hose using the tee that used to lead forward to the canister from the vacumn hose between the throttle bodies. I had plenty of left over hose to run a single piece between the throttle bodies. It runs great and I don't have to listen to the tip over valve moan any more either.
Old 02-27-2013, 08:37 PM   #4164
Sock Monkey
Corporate slave
Sock Monkey's Avatar
Oddometer: 2,277
Also, you need to hold the switch for a moment to activate the grips. They won't come on with just a flick like the passing flasher. Once on, each flick steps through the 3 heat settings. Turn them off by holding the switch in again.
-SM
aka NoVector
Current: 2012 Moto Guzzi Stelvio NTX, 2008 Yamaha WR250R
Gone: Ducati Multistrada, Moto Guzzi Norge, BMW R1200GS, BMW F650 GS Dakar, KTM 520 EXC, Suzuki DRZ400E, and the list goes on.......
Sock Monkey is offline   Reply With Quote
Old 02-27-2013, 08:41 PM   #4165
Sock Monkey
Corporate slave
Oddometer: 2,277
I did a temporary, reversible canisterectomy on my bike and it made absolutely no difference in how it runs, so I put it back to stock. I don't like the smell of fuel in the garage on those hot summer days/nights, and if it doesn't improve the performance at all, I'm all for saving the endangered baby spotted grey whale-owl.....or whatever the canister is there to protect.
-SM
aka NoVector
Old 02-27-2013, 08:49 PM   #4166
stevie88
That's gotta hurt
stevie88's Avatar
Oddometer: 19,431
-SM
I understand. I would remove the tip over valve regardless.
Old 02-27-2013, 10:04 PM   #4167
Demar39
Demar39's Avatar
Oddometer: 299
-SM
I became quite good at stepping through the settings trying to get my stock heated grips to work the day I bought the bike.
La Dolce Vita 15 is my limit on schnitzengruben.
2012 Stelvio NTX
2010 Bonneville T100
Demar39 is offline   Reply With Quote
Old 02-28-2013, 03:12 AM   #4168
dirtymartini
Shaken, Not Stirred
Oddometer: 2,619
Yes, when I bought mine the grips were like Mante Te'os girlfriend....imaginary!:eek::
Sent from my ADR6300 using Tapatalk 2
Old 02-28-2013, 09:24 AM   #4169
stevie88
That's gotta hurt
stevie88's Avatar
Oddometer: 19,431
I'm finding 5th gear might be a better choice than 6th at highway speeds below 75 mph. What do you guys who have owned their bikes longer do? At 70 in 6th gear the engine is turning around 4k rpm and there is a little vibration that goes away with a few more rpms.
Old 02-28-2013, 10:00 AM   #4170
boxermoose
Now fully goosed
boxermoose's Avatar
Oddometer: 2,849
Rarely use 6th - like to keep the bike revving up around 5k - for me is strickly a highway gear
Nice thing about TX is the higher speed limits - however MPG suffers accordingly
Sometimes you get the ABAT....and sometimes the ABAT gets you
boxermoose is offline   Reply With Quote
Times are GMT -7.   It's 04:02 AM.
