Go Back   ADVrider > Bikes > Beasts > Moto Bellissima: All Other Dualsports
Old 04-09-2013, 04:00 PM   #4516
stevie88
That's gotta hurt
stevie88's Avatar
Oddometer: 19,322
I thought it was Nuevo Tomale Xtracaliente?
I wasn't born with enough middle fingers.
stevie88 is offline   Reply With Quote
Old 04-09-2013, 04:02 PM   #4517
James Adams
Misplaced
James Adams's Avatar
Oddometer: 10,113
Originally Posted by Adam R View Post
Has anyone ridden to old, 180 rear tyred Stelvio AND a 150 sectioned one? I'm wondering what the handling characteristics are on the road, with a view to maybe changing to the 150 wheels. Ta!
I haven't ridden the wide-wheeled version, but if anyone has a wide wheel hanging around and feels like giving it away (or close to that ), I'll be happy to liberate it from the corner of the garage.
505 XC-F DUKE 690
James Adams is online now   Reply With Quote
Old 04-09-2013, 05:05 PM   #4518
Forseti
Forseti's Avatar
Oddometer: 1,267
Mine came with the wide rear. I swapped it for the narrow one.
Biggest change was a little quicker turn in.
Much better tire selection for the riding I do with the 4.25 rim....
Politics is a pendulum whose swings between anarchy and tyranny are fueled by perpetually rejuvenated illusions.
Albert Einstein
Forseti is offline   Reply With Quote
Old 04-09-2013, 05:33 PM   #4519
James Adams
Misplaced
Oddometer: 10,113
My problem is that I like to ride both on and off-pavement, and no tire is good enough for me for both (sorry, Heidenau ).
I'd love a second set of wheels, with the wide rear rim, for on-road tires. But since I usually change my own tires, they'd need to be really cheap to be worthwhile.
505 XC-F DUKE 690
Old 04-10-2013, 04:04 AM   #4520
RRVT
Wild and Crazy Guy
RRVT's Avatar
Oddometer: 233
Riding offroad
Guys,
do you keep traction control on or off when on gravel? I assume ABS would be off, but maybe not for everybody.
Roman
Burlington, VT
2009 F800GS, 1995 R1100GS, 2013 Moto Guzzi Stelvio NTX, 2002 Triumph Tiger, 1984 Honda Magna with Velorex Sidecar, 1969 Jawa Sport
RRVT is offline   Reply With Quote
Old 04-10-2013, 04:09 AM   #4521
WitchCityBallabio
Guzzi weirdo
WitchCityBallabio's Avatar
Oddometer: 855
My bike came with the 180 rim. Changed to the 150 rim to open up a much greater choice of tires. All I can tell you is that going from the 180 rim to the 150 rim made the bike feel like it shed 150 pounds. I can't help but think that that rim is exactly what the engineers at Guzzi intended for the bike.
I like the 150 rim so much that I sold my 180 rim.
2011 Moto Guzzi Griso SE, 2009 Moto Guzzi Stelvio
2004 Moto Guzzi V11 Sport Ballabio, 1979 Moto Guzzi V1000 Roadster Cafe
1970 Moto Guzzi Ambassador
1966 Moto Guzzi Stornello
IBA # 35648
WitchCityBallabio is offline   Reply With Quote
Old 04-10-2013, 04:17 AM   #4522
Adam R
Adam R's Avatar
Oddometer: 146
Seems a clear choice then! I may well be moving to the cast wheels too - I'm too careless to look after spoked, mine look shocking. but the worst thing is that with the tyres they have on now, they leak air from the rim/tyre joint. So I'd have to stick with the OE Pirellis to be sure of a proper match - not a great way to keep costs down long term...
Thanks for the feedback folks!
Moto Guzzi Stelvio 1200 2008
Adam R is offline   Reply With Quote
Old 04-10-2013, 05:57 AM   #4523
James Adams
Misplaced
Oddometer: 10,113
...they leak air from the rim/tyre joint...
This means your rim is bent or your tire is damaged or defective. Any properly sized tubeless tire should mount up fine and hold air regardless if you're using the tubeless spoked or cast wheels.
505 XC-F DUKE 690
Old 04-10-2013, 06:08 AM   #4524
stevie88
That's gotta hurt
stevie88's Avatar
Oddometer: 19,322
B
Old 04-10-2013, 08:21 AM   #4525
Sock Monkey
Corporate slave
Sock Monkey's Avatar
Oddometer: 2,249
Keep in mind 2 things. First, Adam is posting from the UK, and depending on where he lives/rides, rust can be a very big issue there. Second, the Guzzi Stelvio uses the Alpina STS system, which is a thru-the-rim spoke system. If any of the spoke seats are damaged or have begun to rust, they'll leak. Just saying it's not necessarily a bent rim or bad tire bead.....
-SM
aka NoVector
Current: 2012 Moto Guzzi Stelvio NTX, 2008 Yamaha WR250R
Gone: Ducati Multistrada, Moto Guzzi Norge, BMW R1200GS, BMW F650 GS Dakar, KTM 520 EXC, Suzuki DRZ400E, and the list goes on.......
Sock Monkey is offline   Reply With Quote
Old 04-10-2013, 08:55 AM   #4526
Mr. B
Contrarian
Mr. B's Avatar
Oddometer: 1,910
Originally Posted by RRVT View Post
Guys,
I turn mine off. The next time you're riding on gravel, try making a quick stop with the ABS turned on.
Don't try this going down a steep hill, BTW. Some years ago there was a ride report here that showed the effects of riding downhill on a gravel road with ABS. There was a pic showing a big GS in a ditch because the bike wouldn't stop. That pic alone convinced me to turn off the ABS, esp in hilly areas.
'12 Moto Guzzi Stelvio NTX
'06 Honda Helix
Mr. B is offline   Reply With Quote
Old 04-10-2013, 09:25 AM   #4527
James Adams
Misplaced
Oddometer: 10,113
-SM
He stated that it was leaking at the tire-rim junction, hence the bent rim statement. Obviously the wheel could be damaged in many other ways.
505 XC-F DUKE 690
Old 04-10-2013, 09:29 AM   #4528
rocker59
diplomatico di moto
rocker59's Avatar
Oddometer: 15,928
-SM
Aluminium does not rust.
The rims are not steel.
Rocker59 (aka guzzimike), Aux Arcs
Moto Guzzi Sport 1100
IBA #24873
"Do what you can, with what you have, where you are." - Theodore Roosevelt
rocker59 is offline   Reply With Quote
Old 04-10-2013, 09:32 AM   #4529
James Adams
Misplaced
Oddometer: 10,113
Guys,
I have TC off most of the time unless it's wet, snowy, or icy and I'm on pavement. ABS stays on most of the time unless I'm on a loose surface (like gravel, sand, or loose dirt), though I usually keep it on for hard-packed surfaces (including snow).
505 XC-F DUKE 690
Old 04-10-2013, 09:36 AM   #4530
Adam R
Adam R's Avatar
Oddometer: 146
You'd think - but no. Changed to a Conti Trail Attack - lost air lots - checked all - concluded it was the tyre. Changed it. Same but less. Stick another make road tyre on it, okay again. It just seems the trail attacks don't like the rim.
That said, there is some damage to it, but not in any sealing area - just corrosive damage from (and this is just supposition) tyre weld type gunk...
And yes - it's definitely from the tyre/rim joint. The corroded nipples and rim are just red herrings
Times are GMT -7.   It's 11:17 PM.
