Go Back   ADVrider > Bikes > Beasts > Moto Bellissima: All Other Dualsports
Old 04-29-2013, 04:31 PM   #4726
danketchpel
Oddometer: 2,564
Speaking of bar risers....
I have a set of Rox risers on my Vstrom but I saw these PowerMadd risers on a buddie's DR650 last weekend and really liked them.
They offer both 2" and 3" rise in 7/8" - 7/8" and 7/8" - 1 1/8"
I think I will go with these on the Stelvio. I like that they won't twist like the Rox risers can, plus they are cheaper.
13 MG Stelvio NTX, 09 Duc Sport Classic, 02 Speed Triple
13 Husky Terra 650, 00 Suzi DRZ400-S
danketchpel is online now   Reply With Quote
Old 04-29-2013, 04:35 PM   #4727
James Adams
Misplaced
James Adams's Avatar
Oddometer: 10,105
In my experience, it's not twisting that's an issue, but rotating in the stock clamps. The PowerMadd risers would be susceptible to the same issue.
That said, they'd work fine as long as the distance between the clamps is compatible. I don't know what it is, but with the Rox Risers it doesn't matter.
James Adams is offline   Reply With Quote
Old 04-29-2013, 05:15 PM   #4728
henerythe8th
Oddometer: 28
So, are you going to change your bars?
henerythe8th is offline   Reply With Quote
Old 04-29-2013, 05:53 PM   #4729
Lomax
Nanu-Nanu Adventurer
Lomax's Avatar
Oddometer: 9,159
Has anyone had any issues with the bike cranking fine and not starting up? Sometimes mine does this but it does start on the second or third try. Just wondering if anyone has run into this and has any ideas ?
It usually happens after riding for about 1/2 hour and then letting it sit for an hour, Like doing lunch, but the other day it did it cold right out of the garage.
Marc
84 R100RS LE,14 Ducati MTSGT, 73 850 Commando, 78 CT90, 14 Ural, 74 Eldorado police, 64 R50/2, 13 TR650, 01 DRZ400E, 94 900SS/CR
Lomax is offline   Reply With Quote
Old 04-29-2013, 06:39 PM   #4730
Sock Monkey
Corporate slave
Sock Monkey's Avatar
Oddometer: 2,246
Marc
Sometimes mine did this, but as I get more miles on it (nearing 6k now) it has been doing it less and less. In my case, it would fire first or second revolution in the morning, but in the afternoon it could take 6-8 revolutions before it would fire. No clue what the difference was, but it hasn't done it in a while so I'm not too concerned.
-SM
aka NoVector
Current: 2012 Moto Guzzi Stelvio NTX, 2008 Yamaha WR250R
Gone: Ducati Multistrada, Moto Guzzi Norge, BMW R1200GS, BMW F650 GS Dakar, KTM 520 EXC, Suzuki DRZ400E, and the list goes on.......
Sock Monkey is offline   Reply With Quote
Old 04-29-2013, 06:49 PM   #4731
James Adams
Misplaced
Oddometer: 10,105
Marc
Mine always starts up pretty quickly, even when it's 20 degrees outside. It's got 8K miles on it and doesn't seem any different than it did when it was new.
Old 04-29-2013, 08:23 PM   #4732
Demar39
Demar39's Avatar
Oddometer: 297
Marc
My 2012 NTX has not had this happen, always starts right away. On my 2010 Bonneville T100 I had a similar problem after I removed the air injection. Previous to the removal it would always start right away. After removal, if I let it cool for 1/2 to 1 hour it won't start unless I use the choke. It acts like it's flooded. I think it's some type of vapor lock in the FI. I just use the choke.
La Dolce Vita 15 is my limit on schnitzengruben.
2012 Stelvio NTX
Demar39 is offline   Reply With Quote
Old 04-29-2013, 09:57 PM   #4733
Ham
Oddometer: 361
Pyounbl,
No what I was getting at is if your headlight isn't on you blew the fuse that also runs the alternator. And you will soon run out of juice and be walking.
The headlight is fantastic.
Ham is offline   Reply With Quote
Old 04-29-2013, 10:07 PM   #4734
James Adams
Misplaced
Oddometer: 10,105
Originally Posted by pyoungbl View Post
If the 30A fuze is blown the headlight still burns.
Old 04-29-2013, 10:13 PM   #4735
Blakebird
r-u-n-n-o-f-t
Blakebird's Avatar
Oddometer: 16,345
Marc
Just as a point of reference, Marc....that bike never did in in the ~12,000 miles I had it. Always a quick start.
IBA #11735 . 1968-present
Blakebird is online now   Reply With Quote
Old 04-30-2013, 05:10 AM   #4736
kirb
should be out riding
kirb's Avatar
Oddometer: 1,808
Same here...2012 w/5200 miles- never an issue. 2013 with 500 miles, same as 2012. Hot, cold, wet, dry...didn't matter. Fired up on the first few turns.
A Ducati, some Guzzi, a KTM, and a Excelsior...Indian in resto.
kirb is offline   Reply With Quote
Old 04-30-2013, 05:46 AM   #4737
boxermoose
Now fully goosed
boxermoose's Avatar
Oddometer: 2,854
+1 - never a problem
Isn't hard start sometimes a tight valve issue?
Sometimes you get the ABAT....and sometimes the ABAT gets you
boxermoose is online now   Reply With Quote
Old 04-30-2013, 05:50 AM   #4738
Lomax
Lomax's Avatar
Oddometer: 9,159
Most of the time it fires right up on the first turn, zoom. But every now and then it takes some cranking, kind of like it is flooded???? I will mess with it and see if I can determine the exact conditions that it happens under.
I love the bike however. What a hoot to ride.
Marc
Old 04-30-2013, 06:24 AM   #4739
jwdub
Oddometer: 728
My 2010 always takes about 3 - 5 seconds to fire off.
jwdub is offline   Reply With Quote
Old 04-30-2013, 06:38 AM   #4740
kirb
kirb's Avatar
Oddometer: 1,808
Connector Brand?
Looking for the brand of connector used on the fog lamps. I want to create a plug and play in-line fuse holder (will create extras for you fine folk). Connector in question circled.
Times are GMT -7.   It's 04:32 AM.
