Go Back   ADVrider > Bikes > Beasts > Moto Bellissima: All Other Dualsports
Old 05-28-2013, 07:23 AM   #5236
swmckinley
Oddometer: 84
Fluid change..heads up.
While changing the fluids on my NTX this weekend I had a problem with the tranny drain bolt. After removal of the bolt I noticed that one of the threads from the case side was on the bolt. It would not tighten up upon re-installation. I have always used a torque wrench and tightened up to spec. Its at the dealer now and either getting a Heli-Coil or a Sert. Just thought I would pass this along.
Steve Mckinley
Austin, TX
2012 Moto Guzzi Stelvio NTX
swmckinley is offline   Reply With Quote
Old 05-28-2013, 08:24 PM   #5237
danketchpel
Oddometer: 2,561
Originally Posted by jwdub View Post
I'm in the process of trying the ROX vibration damping risers + a ProTaper Standard Low bend bar which should result in the same overall height as the stock bar with just a bit less pull back. I wasn't aware of the Precision riser option. AlphaBetaDog went with the ROX vibration damping risers with a shorter bar and has reported good results -- noticeably less vibration.
I ordered a set of ROX 2" vibe dampening risers today. I will swap those for the solid ones I have now and see how things improve.
I'm going to try a prototype mockup of a couple cross bar configurations to see how that works also.
I also picked up a standard RAM U-bolt style handlebar mount for the GPS. The SW-Motech deal I bought isn't so compatible with the ROX setup. It may go up for sale and I'll just stick to the full RAM setup I was using on my other bikes.
13 MG Stelvio NTX, 09 Duc Sport Classic, 02 Speed Triple
13 Husky Terra 650, 00 Suzi DRZ400-S
danketchpel is offline   Reply With Quote
Old 05-28-2013, 08:52 PM   #5238
James Adams
Misplaced
James Adams's Avatar
Oddometer: 10,085
I used the RAM kit that replaces one of the handlebar clamp bolts with a longer bolt and RAM ball; it works great. That said, I have become quite dissatisfied with the RAM cradle for my Garmin 62 and now use the locking Touratech cradle instead (currently on the RXV, but works great on the Stelvio also).
505 XC-F DUKE 690
James Adams is online now   Reply With Quote
Old 05-28-2013, 10:47 PM   #5239
goodcat8
I can pass this guy.....
goodcat8's Avatar
Oddometer: 3,010
Brief Ride Apart review.
http://rideapart.com/2013/05/rideapa...lvio-1200-ntx/
2014 Triumph Scrambler
Prior: 3rd Battalion - 6th Marines - 2nd Marine Division - Lima Company - 2nd Platoon - 0311
goodcat8 is offline   Reply With Quote
Old 05-29-2013, 04:55 AM   #5240
danketchpel
Oddometer: 2,561
Originally Posted by goodcat8 View Post
I don't think anybody ever proof read that write up.
Old 05-29-2013, 06:29 AM   #5241
Mr. B
Contrarian
Mr. B's Avatar
Oddometer: 1,909
Why do some continue to compare the NXT to the BMW GS, instead of the BMW GS Adventure--the obvious competitor?
'12 Moto Guzzi Stelvio NTX
'06 Honda Helix
Mr. B is offline   Reply With Quote
Old 05-29-2013, 06:49 AM   #5242
stevie88
That's gotta hurt
stevie88's Avatar
Oddometer: 19,311
Cause they are afraid it'll kick the GSA in the nutz! As a former GSA owner, I know that it indeed does.
I wasn't born with enough middle fingers.
stevie88 is offline   Reply With Quote
Old 05-29-2013, 07:14 AM   #5243
James Adams
Misplaced
Oddometer: 10,085
Price.
505 XC-F DUKE 690
Old 05-29-2013, 07:23 AM   #5244
Toadride
Toadride's Avatar
Oddometer: 839
Equip the GS like the Stelvio. Then look at the price.
Old 05-29-2013, 07:36 AM   #5245
henerythe8th
Oddometer: 28
...and the weight...
henerythe8th is offline   Reply With Quote
Old 05-29-2013, 11:26 AM   #5246
danketchpel
Oddometer: 2,561
It would be nice to see more apples to apples comparisons.
The one thing BMW did with the GSA that I wish Guzzi would do with the NTX is to give it a slightly lower 1st gear ratio. I've come to find the rest of the gearing to be just about right, but I would like to be able to slip the clutch a bit less from a stop when riding 2 up etc.
Speaking of clutches, I'm beginning to think the "morning groan" is an issue with the clutch facing material. When it's cold mine will groan (I believe it to be chatter) if you let out the clutch fairly aggressively for the first few times. If I let it out gently it won't do it, you can modulate the "groan" with the release rate. I wonder if Guzzi spec'd a different clutch facing material for the Stelvio/NTX, maybe something better suited to higher operating temps but not quite so smooth at cold temps?
At least that's my theory for now.
Another comparison issue. I was reading the "why so many used Teneres on the market now" thread. It's interesting to see how many people are complaining about handlebar vibrations, hmm..... big twins, unbraced long aluminum bars..... , also many owners not so happy with the stock windscreen, complaints about low speed fueling/jerky response, ...... I see a pattern here.
I think the Stelvio fuel mapping is much better than the Tenere myself, but not quite as refined as the GS.
Old 05-29-2013, 11:29 AM   #5247
WitchCityBallabio
Guzzi weirdo
WitchCityBallabio's Avatar
Oddometer: 847
I'm so tired of the "it's soooo heavy" statement when comparing them. The dry weight on my 09 is 16 pounds heavier than the dry weight listed for the KTM 990 Adventure. I find the statement that it's 100 pounds heavier than the GS a tad hard to believe.
I haven't had that hard a time off road with mine either. In fact, I'm usually surprised at how well it behaves off road.
All what you're used to I guess.
2011 Moto Guzzi Griso SE, 2009 Moto Guzzi Stelvio
2004 Moto Guzzi V11 Sport Ballabio, 1979 Moto Guzzi V1000 Roadster Cafe
1970 Moto Guzzi Ambassador
1966 Moto Guzzi Stornello
IBA # 35648
WitchCityBallabio is offline   Reply With Quote
Old 05-29-2013, 11:55 AM   #5248
pyoungbl
Colonel Blood
Oddometer: 507
Originally Posted by WitchCityBallabio View Post
I'm so tired of the "it's soooo heavy" statement when comparing them. .
Our own Leafman60 took scales to the BMW shop and weighed a new GSA, then his own Stelvio NTX....almost identical weight. I mean like, maybe 3 lbs difference (and that could have been fuel in the NTX but not much in the GSA). The real differences are (IMHO) Price, user servicability, dependability (GS has known issues with rear drive, CAN BUS, and ABS pump...not all, just enough to worry me), and simplicity. Of course the GS wins in terms of dealer network and parts supply. The NTX ain't perfect but it has fewer warts than anything else on the market.
Peter Y.
Growing old ain't for sissies!
pyoungbl is offline   Reply With Quote
Old 05-29-2013, 12:05 PM   #5249
James Adams
Misplaced
Oddometer: 10,085
The biggest downside that I regularly encounter is that the higher weight and lack of "real" knobby tires makes stopping distances a bit longer on loose surfaces when compared to dual-sports that have the KLR/DR650-sized 17/21 wheels. And it's easy to get the front wheel to slide when cornering on dirt and gravel--this does not always end well.
From Sunday (courtesy of GrizGirl):
Old 05-29-2013, 12:12 PM   #5250
Forseti
Forseti's Avatar
Oddometer: 1,267
I run mitas E07's. They work amazingly well on the stelvio. Not quite knobby but close. I have the narrow rear rim on my 09 so I can run any tire the GS does.
Sent from my Galaxy Nexus
Politics is a pendulum whose swings between anarchy and tyranny are fueled by perpetually rejuvenated illusions.
Albert Einstein
Forseti is offline   Reply With Quote
Times are GMT -7.   It's 10:44 PM.
