Old 06-23-2008, 06:31 AM   #91
cool dude
cool dude's Avatar
Oddometer: 273
Is My Touratech Rear Rallye Tank Repairable?
Hi guys,
I have just bough a Touratech rallye rear fuel tank off of fleabay and to my surprise found it cracked on arrival . It seems like the tank mount has been stressed during a previous Optic 2000 rallye, maybe after a fall. The area would be tricky to get into and yes, it leaks like a sieve.
The tank is made out of Polyamide 6 (PA 6). My question is, can this be repaired for reasonable cost and perhaps reinforced by plastic welding? I have the possibility of returning it to the seller so all is not lost.
Thanks for your input and wisdom. Here are the pics.
cool dude is offline   Reply With Quote
Old 06-23-2008, 09:00 AM   #92
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,235
PA-6 is what KTM uses for their painted tanks, and I have some links for you from the LC4 index:
http://www.advrider.com/forums/showthread.php?t=62087
http://www.advrider.com/forums/showthread.php?t=62059
http://www.advrider.com/forums/showthread.php?t=113337
I hope you find the info you need. I read that plastic welding is a skill, so if you go that route you should try to find someone who knows what they are doing.
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 06-23-2008, 10:58 AM   #93
cool dude
cool dude's Avatar
Oddometer: 273
Thanks for that.
I have read all thread that prefer to Polyamide and tank repair but could not decide whether to stick with it or return it. Given that the tank cost me the equivalent of around $540US then perhaps I would be better returning it for a full refund. Any repair is unlikely to be as strong as the original and I guess that the mounting point puts stress exactly where the fracture occurred.
Old 09-30-2014, 04:51 AM   #94
svenb
svenb's Avatar
Oddometer: 144
2003
Hi, Got a crack in my tank i Albaniaraid a week ago.
Its a 2003 and a friend will help welding.
Material?
PA och PA6?
Its marked PA
svenb is offline   Reply With Quote
Old 10-02-2014, 09:51 AM   #95
meat popsicle
Ignostic
Oddometer: 14,235
Material?
PA och PA6?
Its marked PA
The stock KTM 640 Adventure tank was made from Polyamide-6 in 2003 (grey paint).
Old 01-08-2015, 07:12 AM   #96
hajoktejnSI
hajoktejnSI's Avatar
Oddometer: 67
I know it ain't the prettiest repair, but so far (couple of hours) it's holding water. Going to leave it for a couple of days just to be sure. I couldn't do it without discoloring the material I welded with, looks like my soldering gun was an overkill with it's 100 watts ...
I'm going to glue a piece of rubber on both sides to help the tank with absorbing vibrations and impacts.
hajoktejnSI is offline   Reply With Quote
Times are GMT -7.   It's 08:29 PM.
