Old 08-18-2010, 02:32 PM   #301
EvanADV
Big Bearded Boy
EvanADV's Avatar
Oddometer: 1,337
this thing looks AWESOME. nice work.
Current Steed: '08 FJR1300
9 states left to ride: WI, MN, ND, SD, UT, OK, KS, AK, and HI.
EvanADV is offline   Reply With Quote
Old 08-30-2010, 08:38 PM   #302
S.t.t.G.
Mind over metal...
S.t.t.G.'s Avatar
Oddometer: 1,717
hmmm....
S.t.t.G. is online now   Reply With Quote
Old 10-24-2010, 04:48 AM   #303
JoeyBones
Encouraging Entropy
JoeyBones's Avatar
Oddometer: 1,387
Just came across THIS link on the Carolina Riders site. This guy used an old scooter frame and I think he may be on to something.... Wouldn't take much to dual-sport it a little...
Proud to have ridden all 50 US States. IBA #48773.
Check out my Motorcycle Courier Adventures or the Charlotte Ride Planning & 3rd Thursday Pizza-Meet
"I picked up a nice burlap thong. It makes me feel pretty." - BluRidgeRider
JoeyBones is offline   Reply With Quote
Old 10-24-2010, 12:43 PM   #304
Danger4u2
'04KX500isDanger4u2
Danger4u2's Avatar
Oddometer: 667
Hey, Joe would you copy and post a picture please, you have to join the site to view the pictures. I'm on too many forums to join one just to see pictures. Thanks.
Go faster than everyone.
Only worry about what's in front of you.
Danger4u2 is offline   Reply With Quote
Old 10-24-2010, 03:55 PM   #305
JoeyBones
Encouraging Entropy
JoeyBones's Avatar
Oddometer: 1,387
Will do when I get home tonight. Pretty cool approach...
Old 10-24-2010, 04:16 PM   #306
dwayne
Silly Adventurer
dwayne's Avatar
Oddometer: 3,553
You need to be a member to see the photos...
Rum Runners Yukon, NWT & Alaska
Roads and Ruins Scotland
Kinbasket Lake Golden B.C.
A "Day" of Dirt Biking Rockies East Slopes
High and Dry Colorado and Utah
"When your only tool is a hammer, every problem looks like a nail"
dwayne is offline   Reply With Quote
Old 10-25-2010, 02:45 AM   #307
JoeyBones
Encouraging Entropy
JoeyBones's Avatar
Oddometer: 1,387
Sorry about that folks - didn't realize you had to join to see photo's. So here they are.... In short, he bought a used, junked scooter for $20, cut away everything that he didn't need (which was a lot, of course), then welded up a body-framework. With that framework "skinned", the swingarm re-attached and a "tongue" added, he says he has about $250 in the whole thing... He does say he's going to put higher-grade bearings in the back wheel to handle the higher speed.
Kinda fitting that there's an Airstream in the background of that last shot...
In any case, I think this is a cool idea and could easily be expanded upon to include the rear shock, remove the rear brake disc, etc (hard to tell in the pics but it looks like he did NOT carry over the suspension?).
Old 10-25-2010, 08:04 AM   #308
slimjim503
Oddometer: 5
i pulled this from MN to OH [IMG][/IMG][IMG]
slimjim503 screwed with this post 10-25-2010 at 08:14 AM
slimjim503 is offline   Reply With Quote
Old 10-25-2010, 08:43 AM   #309
tomatocity
Retired and lovin' it
tomatocity's Avatar
Oddometer: 835
Looks like a very nice simple trailer. What are you using for a rear wheel on the trailer? I would like to see how you connected to the swingarm.
2012 Yamaha Super Tenere - 2005 Kawasaki KLR - 1993 Chevrolet S10
tomatocity is online now   Reply With Quote
Old 10-25-2010, 10:20 AM   #310
dwayne
Silly Adventurer
dwayne's Avatar
Oddometer: 3,553
Has anyone seen trailers using the footpegs as the tow points?
Old 10-25-2010, 07:50 PM   #311
reed523
To pedal or not to pedal
reed523's Avatar
Oddometer: 395
Here's another approach from a leftover motorcycle. It is still a work in progress. Some days i think i'm on the right track...some days i think i need to scrap the whole deal.
Keith
NC700X
www.crazyguyonabike.com/whenlife
reed523 is offline   Reply With Quote
Old 10-26-2010, 12:05 PM   #312
dwayne
Silly Adventurer
dwayne's Avatar
Oddometer: 3,553
I like a lot of the concepts there, which do find to work well, and which are challenges?
Old 10-26-2010, 12:21 PM   #313
ag_streak
Tiene Ruta Cuarenta?
ag_streak's Avatar
Oddometer: 3,199
I humbly suggest that although the weight of two bikes is modest, the COG is relatively far from the contact patch, which gives the mass of the load "leverage" over the hitch, and therefore, the bike..
In the same vein, I encouraged another poster to eschew trying to design a one-wheeled trailer for a kayak. A two-wheeled design would manage the weight and balance better.
So look at the BOB-style (bicycle-trailer) in the picture above. It keeps the COG real low and close to the tire/wheel. Everything it carries isn't much above the tire. "Mass centralization".
Reed, does it sway a bit?
2013 Triumph Tiger 800, 2012 Suzuki DR650, 2006 Suzuki V-strom Sidecar Rig
ag_streak screwed with this post 10-26-2010 at 12:27 PM
ag_streak is offline   Reply With Quote
Old 10-26-2010, 12:50 PM   #314
dwayne
Silly Adventurer
dwayne's Avatar
Oddometer: 3,553
so if you moved the load lower and possibly fwd, do you think you have a feasible design? Do you feel the front up attitude of the trailer might play a role in stability of this rig?
I am interested in the hitch design specifically, low mount to the pegs and the use of the U-joint.
Old 10-26-2010, 03:35 PM   #315
reed523
reed523's Avatar
Oddometer: 395
I suspect ag streak has it nailed. I have only pulled it empty at this point but it does develop some sway at about 50mph. I still need to eliminate a little slack in the hitch joint (u joint is solid but there is some slack in receiver portion)-also, the starter bike was a 20 something year old bike and the tire is in bad shape with an obvious flat spot. It does seem heavy side to side with the bicycles on it. My design was focused on keeping tongue weight down, but i suspect the high CG may be too big to overcome (unless i get a wing to tow it!).
I'm having some computer issues right now. I'll try to post more pics later of the hitch assembly.
Keith
NC700X
Times are GMT -7.   It's 11:23 AM.
