12-05-2010, 02:16 PM
#21856 | |
CDI REPAIR
Oddometer: 3,339
Looking at a cylinder wall and piston won`t help you much.you need the cylinder measured to see if it`s in spec (within taper and out of round specs).....if it`s still in spec the next thing to do is measure the ring gap,to see how badly worn the rings are... I`d have an engine shop check the head and cylinder......you may find that just replacing the valve seals,grinding the valves,honing the cylinder and putting new rings in will be all that`s needed... Get it done/checked right.........or you`ll be dissapointed in the end..you`ll never be looking back if it`s a good job..and it`ll last for years.. ![]() B
01 XR650L,102mm JE 11.25:1 ..NX650 second gear,FMX650 fifth gear,ported CW head,KW valve train,MegaCycle 173X25.Cycra probend CRM,Scott`s sharkfin,Xr`s Only casesaver.FMF "Q2",Sutton Oil Cooler,Clarke 4.0,Red XR`s Only skidplate,Doubletake mirrors,Manracks Rotopax rack..one Minature Schnauzer
12-05-2010, 02:40 PM
#21857 |
Oddometer: 8,011
Oh, BTW...Those WHITE exhaust valves lead me to think your running LEAN and HOT
Steve in SF BMW's 58 R26 79 R100s 91 R100gs 87 Harley FXRS-SP ~ 06 KTM 625 SMC ~ 72 Honda CB750/915cc ~ 92 XR600/654cc ~ 95 XR650l/675cc ~ 03 CRF450r ~ 05 CRF450x ~ 02 XR650l/675cc ~ 86 YZ490 ~ 93 YZ80 ~ 93 XR650l Project |
12-05-2010, 02:46 PM
#21858 |
Oddometer: 564
JE piston hot cam
some new parts from the flea mkt
http://www.advrider.com/forums/showthread.php?t=642296 just spied them there
dirt bikes, vstrom, cruiser, etc. "what hurts, instructs" - ben franklin |
12-05-2010, 02:47 PM
#21859 |
¯\_(ツ)_/¯
Oddometer: 1,246
I was thinking the same thing.
1995 XR628R -Lots of goodies...room for more. Drinking: Funky Cold Medina. |
12-05-2010, 02:50 PM
#21860 |
Oddometer: 8,011
Well, Hell's Bells. Someone's paying attention around here.
12-05-2010, 02:58 PM
#21861 | |
Green Cantern
Oddometer: 6,514
Replace with stainless steel and get the seats cut - done for life. Honda valves are soft.
950/990 CRASH BAR BAGS, FENDER BAGS, and more. Made with pride. Pachaug Map '08 KTM 450 xcr-w, '10 KTM 990 Adventure '85 Honda CR500 NETRA #24519 |
12-05-2010, 03:03 PM
#21862 | |
Oddometer: 8,011
Notice how the outer edge of the piston is clean of carbon build up? That is due to oil passing the rings and washing the carbon away. BTW... There's nothing wrong with Honda XR valves. Now if we were talking CRF valves. Well that is a different kettle of fish.
12-05-2010, 03:21 PM
#21863 |
SometimesY
Oddometer: 228
Thanks for all the help.
That's what I needed, someone to look at the pictures and tell what is going on. Now I'll pull the cylinder and piston and have them measured to make sure they are in spec.
I was going to replace two valve guides and the seals that go with them now I'll do all 4, but what does it mean to have them cut? |
12-05-2010, 03:50 PM
#21864 |
Motojunkie.
Oddometer: 349
![]() really enjoying the q4, great note seems to have more power on the top! braaaaaaaaaap! |
12-05-2010, 04:14 PM
#21865 |
Oddometer: 4,789
I've put upwards of 60,000 mile on oem XR valves.
Keep your filter clean and they last a long time.
C-dub...... Powered by CW-Pistons/cams Wizard manufacturing.... |
12-05-2010, 06:12 PM
#21866 | |
CDI REPAIR
Oddometer: 3,339
B
12-05-2010, 07:34 PM
#21867 |
Oddometer: 1,083
Honda Valves
Honda's valves are harder than a whore's heart
If there's one area that the aftermarket has a hard time improving on it's valves and springs.
12-05-2010, 11:59 PM
#21868 |
Some Fear is Good
Oddometer: 951
Mikuni TM38-85 install
Anyone have a Mikuni on the L? Did a quick "mikuni" thread search and not much specific.
It's on the way. I've had the stock carb on my 04 since day one with Dave's Mods, et al. The last year has been a carb-nightmare. We've cleaned, jetted, and adjusted til I'm blue in the face. Found the Mikuni for a good price and gonna give it a try. If anyone can point me to an install/info thread, I'd really appreciate it! I'd like to get this thing running right again so I can stud the tires for winter and hit the snowy trail! (Gotta ride AK!) Thanks, Jim
R1150GS 01 WR426F |
12-06-2010, 05:44 AM
#21869 | |
Oddometer: 4,789
12-06-2010, 06:05 AM
#21870 |
Green Cantern
Oddometer: 6,514
I disagree, I've seen them wear the valve faces out to the point where they are practically sucked into the cylinder head. I'd recommend stainless steel replacements.
