Old 11-05-2011, 09:12 PM   #34246
mendoteach
mendoteach's Avatar
Oddometer: 1,083
Originally Posted by mcma111 View Post
Every and I mean EVERY time I order spokes from Buchanans they ask me what diameter nipple I want. I don't recall what rim you have but their nipples are usually sized for an Excel rim which has a larger hole than the OE rim. Call them up and they will exchange the nipples for you. BTDT.
Big nipples, exchanging nipples, larger hole, did I ever mention I love spoke discussions Nipples are cool
mendoteach is offline   Reply With Quote
Old 11-05-2011, 09:17 PM   #34247
mcma111
mcma111's Avatar
Oddometer: 8,145
Your just sick. Plain 'n simple. Sick.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 11-05-2011, 09:27 PM   #34248
sc-razor
sc-razor's Avatar
Oddometer: 3,463
We just had a 5.2 earthquake in NW Arkansas. Weird. My chair shook and the lamps shook. They said to prepare for aftershocks.
2009 XR650L
Steve
sc-razor is offline   Reply With Quote
Old 11-05-2011, 09:50 PM   #34249
hogdoc
Oddometer: 254
Nipples and side by side holes........two of my favorite things!
Ooops I guess thats three of my favorite things!
hogdoc screwed with this post 11-05-2011 at 10:05 PM
hogdoc is offline   Reply With Quote
Old 11-05-2011, 10:52 PM   #34250
beechum1
beechum1's Avatar
Oddometer: 4,933
Send a message via AIM to beechum1 Send a message via MSN to beechum1 Send a message via Yahoo to beechum1
The Emig conversion triples and stem are $575.00. The RSW Racing clamps that use the OE stem are $350.00.
Just a little bit of difference here. $$$$$$$$$$$$$
I got my entire CRF front end for 4hunnit and had a friend turn down the stem and threaded the new OD to take the xrl bearings and castle nut.
www.bajastarz.com \\\ 94 XR650L, 85 GL1200A
Rally Moto Kit /// Vendor Thread
Old 11-06-2011, 12:59 AM   #34251
Spud Rider
Spud Rider's Avatar
Oddometer: 3,000
Originally Posted by Flying Cow View Post
Hey y'all,
So the rear spoke saga continues. I returned the Excel kit and burchased a kit from Buchanan's.
WTF!!!! The nipples that came from Buchanan's are to big as well!...
Any advice, opinion....etc.... welcome!
Thanks y'all!
Buchanan's has good customer service. Measure the diameter of your spoke holes, and call Buchanan's as Steve suggested. Once they know the size of the spoke holes, I'm sure Buchanan's will send you the proper size spoke nipples.
Spud
2005 XR650L: Shorai Battery Relocation, Spud Oil Cooler, XR650R C/S Sprocket, Reinforced Subframe, Chain Slipper Roller, Performance Design Lowering Link, Baja Designs Headlight, FMF Hi-Flo Header, ManRacks SD Rack, CST Surge I Front Tire, D952 Rear Tire, Tusk D-Flex Handguards, Uni Air Filter, No-Toil Evolution air filter oil
Old 11-06-2011, 01:10 AM   #34252
Spud Rider
Spud Rider's Avatar
Oddometer: 3,000
Originally Posted by jungleplant View Post
...i am afraid to ask how the rack is holding up after you killed little rubicon
Little Rubicon fought the good fight, may he rest in peace. My RotoPax rack is more rugged than Little Rubicon, and is holding up very well, Mike.
Spud
Old 11-06-2011, 05:27 AM   #34253
Wattner
Wattner's Avatar
Oddometer: 2,774
Hey y'all,
Here is a nipple that came from the rim...
Here is a Buchanan's nipple...
For those of you that bought Buchanan's spoke kit, did you drill out your rim????
Do I have a rim that is NOT stock????
Thanks y'all!
Man a $3.00 drill bit and ten minutes will get ya roiling!!!! Improvise and overcome obstacles!!!
Seriously, I would not hesitate to drill the rim to fit
Wattner is offline   Reply With Quote
Old 11-06-2011, 05:30 AM   #34254
Wattner
Wattner's Avatar
Oddometer: 2,774
Originally Posted by Barron View Post
So I thought I had my oil leak fixed... After a ride back home I noticed my back brakes weren't working again
Powdered it up and couldn't find a leak, then I found it, right at the center of the gasket above the cases in front of the starter
The only good thing about having to replace this gasket is that I want to look at the piston after running so low on oil...
So I took off the top end of the engine. What did I find? Not a ripped gasket, but where the center case gasket met up with the prior mentioned gasket it was slightly sticking up above the case causing the leak. So I shaved the case gasket down, scraped the old gasket off and replaced it.
I had never pulled the piston out of the cylinder prior to this so I got me a piston ring compressor. Oiled up the cylinder, oiled up the compressor, pushed the piston right up into the cylinder... and then I discovered that you can not open up this compressor to get it off of the installed piston HA HA F'ing HA. So I cut it off and put the rest of the motor back together.
I really hope this is the end of that damn leak, I'm getting tired of checking my oil every 40 miles.
-Barron
Darn the luck man!!! Here's to good karma and smooth sailing from here on out!!!! I hope the leak woes are behind you!
Old 11-06-2011, 05:33 AM   #34255
Wattner
Wattner's Avatar
Oddometer: 2,774
Man that is AWESOME!!!!!! You'll love the stiffened front end where you ride for sure!!!!
You can ebay the stock stuff and recoup most of your$$$$$ That "L" front wheel seems to fetch premium $$$
There is a care pack getting some goodies added and will head your way soon!
Old 11-06-2011, 05:37 AM   #34256
cyclewizard
cyclewizard's Avatar
Oddometer: 4,789
My wifes nipples are frickin huge.. they look like pacifiers
C-dub......
Powered by CW-Pistons/cams
Wizard manufacturing....
cyclewizard screwed with this post 11-06-2011 at 05:43 AM
cyclewizard is offline   Reply With Quote
Old 11-06-2011, 06:26 AM   #34257
cyclewizard
Oddometer: 4,789
Drill the rim like Mike said..
C-dub......
Old 11-06-2011, 07:16 AM   #34258
Rman237
Ride Rural Texas
Rman237's Avatar
Oddometer: 430
I had to play around with rims and hubs with my SM, I'd make some phone calls before I started drilling anything!
'06 TW200 Mountain Goat '06 XR650L Sumo
'98 XR440R trick and plated '98 KDX220 plated '84 RZ350 '83 XR350R '83 XR200R
'84 ATC125
Rman237 is offline   Reply With Quote
Old 11-06-2011, 07:24 AM   #34259
elsalvadorklr
Oddometer: 3,974
JUST DID THIS REMEMBER STEVE?
sorry I forgot to mention this...we had to redrill not for size I think but for the angle as I had an excel put on my drum brake 18 inch rear which is quite uncommon...
good luck
elsalvadorklr is offline   Reply With Quote
Old 11-06-2011, 08:20 AM   #34260
JWhitmore44
pistolero
JWhitmore44's Avatar
Oddometer: 1,212
Originally Posted by flyingwombat View Post
You mean like this?
That is how we get across the Golden Crack. See, the XR650R is pretty soft too.
Yea, pretty much
84 Honda Goldwing (GL1200)
03 XR650L
JWhitmore44 is offline   Reply With Quote
Times are GMT -7.   It's 02:25 AM.
