Old 11-19-2011, 03:06 PM   #34681
jungleplant
Motorcyle Stuff
jungleplant's Avatar
Oddometer: 1,858
Originally Posted by kenny61 View Post
A bouncy rack huh?
ya something like this , makes since to me
www.manracks.com
jungleplant screwed with this post 11-19-2011 at 03:19 PM
jungleplant is offline   Reply With Quote
Old 11-19-2011, 03:10 PM   #34682
kenny61
Crazy Idiot
kenny61's Avatar
Oddometer: 24,822
On the plains of hesitation lie the blackened bones of countless millions who at the dawn of victory lay down to rest, and in resting died.
Go forth and be a force of the awesome!
kenny61 is offline   Reply With Quote
Old 11-19-2011, 03:16 PM   #34683
Spud Rider
Spud Rider's Avatar
Oddometer: 3,855
Originally Posted by jungleplant View Post
thats sure gonna help spud
did you make those support bars, mike
I have a good friend who is the maintenance supervisor at a diesel repair shop that has a supply of 1/4-inch thick, steel bar. I told him what I wanted, and he cut the steel bars, welded the short, angled extension on the right bar, and drilled the mounting holes for me.
I realize my subframe supports have limitations, so I try not to overload my luggage rack. Nevertheless, I believe the triangulated steel bars provide additional support, and they have worked well for me so far.
I'm sure your shorter, RotoPax rack that is positioned closer to the saddle will also reduce the stress on my bike's subframe, Mike.
Spud
Spud Rider screwed with this post 11-19-2011 at 03:42 PM
Old 11-19-2011, 03:25 PM   #34684
Spud Rider
Spud Rider's Avatar
Oddometer: 3,855
The stock battery box weighs over ten pounds. I might be wrong, but I don't think the subframe benefits from having the battery box slamming away on it.
Spud
Old 11-19-2011, 03:41 PM   #34685
mendoteach
mendoteach's Avatar
Oddometer: 1,666
Spud
I suppose you're right. Now, I have to buy a welder (wanted one for ages anyway), a Shorai and whatever else I need to get rolling again. I think I am going to leave my battery box on and store tools or tubes or perhaps a compressor like Wattner did. Hell, maybe I'll leave use for other contraband i
mendoteach is offline   Reply With Quote
Old 11-19-2011, 03:43 PM   #34686
jungleplant
Motorcyle Stuff
Oddometer: 1,858
Spud
what do ya think of this spring loaded rack spud
www.manracks.com
Old 11-19-2011, 04:11 PM   #34687
Spud Rider
Spud Rider's Avatar
Oddometer: 3,855
what do ya think of this spring loaded rack spud...
That's a nice "rack," but I'm sure it's pretty expensive.
Spud
Old 11-19-2011, 04:27 PM   #34688
Spud Rider
Spud Rider's Avatar
Oddometer: 3,855
Originally Posted by mendoteach View Post
Here's mine from last weekend. Repeated, forest road water-bar air, fully loaded apparently will break the subframe. Good thing I didn't have my C-Dub 7 fiddy rocket motor in, I would surely have snapped the bike in two.
I'm sorry to hear your bike's subframe cracked, Teach. It appears that particular spot on the frame seems to crack pretty often. Surprisingly, that area of the frame is already reinforced with a small gusset. I'm really surprised to see where Mike Bratcher's frame cracked the second time, after he had gussets welded to the subframe.
Spud
Old 11-19-2011, 04:59 PM   #34689
prince_ruben
prince_ruben's Avatar
Oddometer: 1,734
Originally Posted by Tagnahoor View Post
Anybody have a left hand mirror or can recommend a left hand replacement? I went down on wet trolley tracks, got away with bruised ribs and a spectacularly bruised left calf (where the bike landed,) and all that happened to the little red tank is a broken mirror and a scuffed handguard :)
Mirrors or mirror recomendations?
I went down on some trolley tracks in the Back Bay once during Hurricane Gloria. My buddy was behind and rode right over me. Luckily we were on BMX bikes!
No worries in death, no worries in life.
prince_ruben is offline   Reply With Quote
Old 11-19-2011, 05:14 PM   #34690
jungleplant
Motorcyle Stuff
Oddometer: 1,858
Spud
thats what i am talking about its the vibrations and the welding making it brittle just moves where the next crack will be , you could slow down the cooling by wrapping the weld in sand but thats when it gets crazy,
www.manracks.com
Old 11-19-2011, 05:38 PM   #34691
Spud Rider
Spud Rider's Avatar
Oddometer: 3,855
Originally Posted by taco250 View Post
The other thing about welding is that it can make the adjoining metal brittle. There does need to be a certain amount of flex in the frame. It's a very old design and has limitations.
Perhaps the Twisted Throttle frame braces aren't such a bad idea?
So far, my Spud Struts are working pretty well; however, I don't want to test them by possibly overwhelming them with too much weight.
Spud
Spud Rider screwed with this post 11-19-2011 at 05:44 PM
Old 11-19-2011, 05:45 PM   #34692
jungleplant
Motorcyle Stuff
Oddometer: 1,858
Perhaps the Twisted Throttle frame braces aren't such a bad idea? So far, my Spud Struts are working pretty well; however, I don't want to test them by possibly overwhelming them with too much weight.
Spud
SPUD STRUTS I even like the name , but to easy to make , but if they work Ill make them cheap for you guys , unless you want this marvel of invention
I think your really on to something here spud , this might be it for you , then you can afford those spring mounted racks
www.manracks.com
Old 11-19-2011, 05:57 PM   #34693
Spud Rider
Spud Rider's Avatar
Oddometer: 3,855
Let me state for the record, I'm not interested in selling my Spud Struts. In fact, I have stopped selling my chain rollers.
I also think my Spud Struts present two possible problems. Firstly, I'm not sure the left Spud Strut will fit on a bike that still has the OEM battery box installed. Secondly, the forward mount on the right Spud Strut could possibly shear the bolt attaching it to the frame gusset. Therefore, I think the Twisted Throttle frame braces are probably a better option for most, if not all other XR650L owners. The welded frame gussets might be an even better option, but I do think it's possible the frame can become brittle when the gussets are welded onto it. I'm surprised, and dismayed, to see how Mike Bratcher's frame cracked after he had the gussets welded onto it.
Spud
Spud Rider screwed with this post 11-19-2011 at 06:06 PM
Old 11-19-2011, 05:59 PM   #34694
jungleplant
Motorcyle Stuff
Oddometer: 1,858
Spud
R U a lawyer
www.manracks.com
Old 11-19-2011, 06:07 PM   #34695
Spud Rider
Spud Rider's Avatar
Oddometer: 3,855
R U a lawyer
No.
Spud
Times are GMT -7.   It's 03:51 AM.
