Old 01-07-2012, 02:07 PM   #36436
opjocephus
I'm down, I'm down!
opjocephus's Avatar
Oddometer: 591
To mcma111 (Steve) or anyone else
Figured I would pull the plug today and adjust the valves. Plug really didn't want to come out of the spark plug hole. Here's why
Looks like the washer didn't get seated to the plug properly . Looks like about 2mm shy. Looks like aluminum stuck to the bottom of plug. I'm guessing that aluminum boogered up the threads on the way out. Can this be heli-coiled or is it new head time?
I have put 5000 miles with the plug not full seated. Would this cause any other damage to the motor?
Any help from anybody is appreciated.
Joe
OP
"They're skanky, but they look pretty good!"
Plastic seat sweat, my balls are mighty wet.
"Your eyes look like a couple of piss holes in a snow bank." The Great Jaydini
opjocephus is offline   Reply With Quote
Old 01-07-2012, 02:30 PM   #36437
Drunk_Uncle
Drunk_Uncle's Avatar
Oddometer: 2,278
Does anyone know the overall lenght of the XRL? Trailering reasons are why I am asking.
"I refuse to tiptoe through life only to arrive safely at death" '13 Tiger 800XC, '14 Street Triple, '00 KLR 650(finished project), and 2010 Honda NT700V wife's.
Drunk_Uncle is online now   Reply With Quote
Old 01-07-2012, 02:40 PM   #36438
mcma111
mcma111's Avatar
Oddometer: 12,435
Joe
The spark plug threads can be tapped. There is a tap that is placed in the head and brought out so all of the bits come out. The other way is to grease the plug tap and slowly tap the hole and hope all of the bits come out. The best method is to pull the head and have a machine shop repair the threads. Don't know why your threads got buggered. I Never Seize the plug and when it hits bottom give it a bit more love and call it good.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 01-07-2012, 04:21 PM   #36439
katbeanz
earthbound misfit, I
katbeanz's Avatar
Oddometer: 7,782
I know I needed about seven feet in my old cargo vans for xrl or DR650, would have a few inches to spare on the stock taillights.
I rigged my enclosed cargo trailer/camper chocks the same way. I had to move one of the chocks for a buddy's drz400. He brings me whiskey and pie, so I can't bitch.
katbeanz is offline   Reply With Quote
Old 01-07-2012, 04:34 PM   #36440
mendoteach
mendoteach's Avatar
Oddometer: 1,622
Originally Posted by Walterxr650l View Post
79465.4
Walter
Holy sh#!. Walter I am envious!!!!
mendoteach is offline   Reply With Quote
Old 01-07-2012, 04:54 PM   #36441
mendoteach
mendoteach's Avatar
Oddometer: 1,622
Originally Posted by AndyCBR View Post
When I did my subframe braces I repainted with the Color rite system, code NH146 Accurate Silver which is the factory frame color.
I would recommend using their 2-part clear also (I did) as the color won't hold up well and most 1 part clears are lacquer which are not near as durable. Their 2 part clear kit includes a nice little aerosol sprayer that works really well.
I think I got some paint, their primer, and the clear kit for about $80.
Looks factory when done.
Hope this helps,
Andy
Andy, your memory doesn't serve you well or they've had some serious inflation over at Col rite–$115 bucks for a rattle can of color, clear and primer. OUCH! What is one going to do?
mendoteach screwed with this post 01-07-2012 at 11:24 PM Reason: Typo
Old 01-07-2012, 04:59 PM   #36442
mendoteach
mendoteach's Avatar
Oddometer: 1,622
I wonder if one could, after tapping, take small flexible hose and plumb it to a vacuum and ? Not ideal, but it might work.
Old 01-07-2012, 05:45 PM   #36443
joespeedfast
Oddometer: 22
Joe
Ouch! The plug would get too hot like that from a lack of head contact for heat-sink while also taxing your ignition from poor grounding. Combustion gases would have destroyed the threads while dropping your compression and performance.
Ihate to say it but, if you had that much trouble properly installing the plug, don't skip on the repair. Take it to a Pro and fix it right. ;-)
joespeedfast is offline   Reply With Quote
Old 01-07-2012, 05:56 PM   #36444
rufus
We're burning daylight...
rufus's Avatar
Oddometer: 4,226
I have been searching for info on a pumper carb for the XRL.
I have found 2 kits, a mikuni from XRs only and an FCR from sudco.
I would appreciate ANY info on these 2 kits.
I tried searching here and didn't get very far.
rufus is offline   Reply With Quote
Old 01-07-2012, 06:01 PM   #36445
mcma111
mcma111's Avatar
Oddometer: 12,435
FCR Carb
Get your FCR carb here:
http://www.pjmotorsports.com/keihin-...ml#fcr%20carbs
They are a Sudco reseller but for less than Sudco.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 01-07-2012, 06:05 PM   #36446
mcma111
mcma111's Avatar
Oddometer: 12,435
Wheels
I have a set of OE wheels that need a new home. Rotors, sprocket and Pirelli MT21's. I would post a pic but the camera's battery is charging.
$275.00 and you pay the shipping.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 01-07-2012, 10:43 PM   #36447
rufus
rufus's Avatar
Oddometer: 4,226
I would like to hear pros and con (if there are any) on both of these carbs before i buy.
Old 01-07-2012, 11:50 PM   #36448
Walterxr650l
Walterxr650l's Avatar
Oddometer: 1,275
Stator cover guards
Is there any interest in stator cover guards punched out of 1/8 inch thick lexan? I'm pretty sure that I have a source for some scrap lexan, and a coworker that is willing to punch a bunch out on one of the CNC punches.
If anyone is interested let me know. Either send me a PM or speak up here. Cost should be pretty cheap, likely just the cost of postage.
Walter
"How much a dunce
That has been set to roam
Excels a dunce
That has stayed at home."
Walterxr650l is offline   Reply With Quote
Old 01-08-2012, 12:28 AM   #36449
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,435
Walter
needs to be shaped also. not interested, just FYI.
Originally Posted by Boondoggle View Post
Watching Dakar is like watching people who've built their own world, and for just a couple of weeks they get to live in it.
beechum1 is online now   Reply With Quote
Old 01-08-2012, 12:30 AM   #36450
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,435
30$ Recover and fix the bad foam spots and widened at the back. Yeah, 30$.
Times are GMT -7.   It's 06:54 AM.
