Old 01-11-2012, 09:06 AM   #36616
Barron
M0DAH0LIC
Barron's Avatar
Oddometer: 2,428
Originally Posted by ThumpnRed View Post
If you plan to put stickers on it... seal the inside of it NOW before it ever sees gasoline. I wish I had sealed mine back when it was new... too late now
I've had stickers on mine for years and they are fine. They slid down a little but they still look great and no bubbles. YMMV. I got the black one, what color is yours? I've heard the natural ones bubble more.
-Barron
1996 XR650L with a couple mods
If everyone brewed beer there would be no war.
Barron is offline   Reply With Quote
Old 01-11-2012, 10:20 AM   #36617
Spud Rider
Spud Rider's Avatar
Oddometer: 3,777
Originally Posted by XR650L View Post
Ok Guys
I am ready to do this modification, got an brand new Clark 4.7
With it came a small piece of wire with eyes at the ends.
The place where the fuel cock attach is quite loose
Do I use any sealer underneath it? and if so what must I get?
What in the life would I do with that piece of wire?
Must I get some Aluminium Flatbar and make my own arms that connect to the bottom ends of the tank
Any other advice for me to help make this as painless as possible?...
I seem to remember my fuel tank had an an O-ring that fit between the tank and the petcock mounting plate. I tightened the mounting plate firmly with a phillips head screwdriver, and I don't have any leaks.
If you can, allow the fuel tank to sit in the sun and warm up a bit before you install it. My tank mounted fine, but I had to push quite a bit to get it to fit onto the rubber "hockey pucks" that support the front of the gas tank.
Unlike the others, I attached the wire "coat hanger" to the two screws, and I'm perfectly happy with that installation. The front of the fuel tank doesn't require any more vertical support. The wire is designed to prevent the tank from expanding sideways, and slipping off the rubber "hockey pucks."
Spud
Spud Rider screwed with this post 01-11-2012 at 03:15 PM
Old 01-11-2012, 11:02 AM   #36618
Drunk_Uncle
Drunk_Uncle's Avatar
Oddometer: 2,231
The will also work fine with only sitting on the pucks and the rear bolt. PO fabricated the mounting tabs you talked about and I proptly broke them on the trails and I think jumping it on a MX track helped also. Almost cleared the table tops.
"I refuse to tiptoe through life only to arrive safely at death" '13 Tiger 800XC, '14 Street Triple, '00 KLR 650(finished project), and 2010 Honda NT700V wife's.
Drunk_Uncle is online now   Reply With Quote
Old 01-11-2012, 11:22 AM   #36619
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,358
Pic of the HD brackets I made for my valdez.
Originally Posted by Boondoggle View Post
Watching Dakar is like watching people who've built their own world, and for just a couple of weeks they get to live in it.
Old 01-11-2012, 11:24 AM   #36620
XR650L
XR650L's Avatar
Oddometer: 224
This Tip came too late!!!
Busy creating a Monster XR
XR650L is offline   Reply With Quote
Old 01-11-2012, 11:34 AM   #36621
XR650L
XR650L's Avatar
Oddometer: 224
clark 4.7
Originally Posted by Spud Rider View Post
I seem to remember my fuel tank had an an O-ring that fit between the tank and the petcock mounting plate. I tightened the mounting plate firmly with a phillips head screwdriver, and I don't have any leaks. - [COLOR="Blue"]Must confess, when I loosened the little plate, I did find the O Ring. Tightened the whole lot and it was perfect
[/COLOR]
If you can, allow the fuel tank to sit in the sun and warm up a bit before you install it. My tank mounted fine, but I had to push quite a bit to get it to fit onto the rubber "hocky pucks" that support the front of the gas tank. - Did not even had to do this, just wiggled it a bit and on it went.
Unlike the others, I attached the wire "coat hanger" to the two screws, and I'm perfectly happy with that installation. The front of the fuel tank doesn't require any more vertical support. The wire is designed to prevent the tank from expanding sideways, and slipping off the rubber "hocky pucks."
I am going to make myself 2 flat bar aluminium strips, would like it a little more secure.
Spud
Thanks for in Spud
Old 01-11-2012, 11:42 AM   #36622
ThumpnRed
Pig Wrangler
ThumpnRed's Avatar
Oddometer: 2,555
-Barron
Mine is red. Are your decals vented?
Originally Posted by Cigar Mike :With plastic buy two.
'93 XR650L A few stock parts left...
ThumpnRed is offline   Reply With Quote
Old 01-11-2012, 11:44 AM   #36623
ThumpnRed
Pig Wrangler
ThumpnRed's Avatar
Oddometer: 2,555
You will break more than that with the piggie on a mx track
Old 01-11-2012, 11:56 AM   #36624
michael.brat
michael.brat's Avatar
Oddometer: 497
Originally Posted by cyclewizard View Post
Deals gap I love that place........Brapppppppp...and your on knobbies.....
D606's work well
Ok Guys
Did you find the o-ring in between the bracket and tank?
I originally used the wire and only changed it out for aluminum brackets because the tank had little scoring marks on the inside from swaying back and forth on the engine. I didn't want it to wear over time.
And this only happened because the foam that they provide compresses too much over time (even when double or tripling under the neck). I'd suggest changing out the foam so that the may channel of the tank takes some of the grunt too.
I still have the aluminum brackets, but in a way I prefer the wire. This is because I fear that the tank may crack at the bottom mounting points in a crash when so solidly mounted with aluminum (compared to the wire which would just flex the whole tank. I have never heard of this happening, but just something to consider.
I think we've all collectively covered every possibility with your Clarke tank
to our xrl adv brethren
Mike B
michael.brat is offline   Reply With Quote
Old 01-11-2012, 12:14 PM   #36625
cyclewizard
cyclewizard's Avatar
Oddometer: 4,814
Big Finned Valve cover pics coming as soon as my battery charges for the camera.
C-dub......
Powered by CW-Pistons/cams
Wizard manufacturing....
cyclewizard is offline   Reply With Quote
Old 01-11-2012, 12:52 PM   #36626
XR650L
XR650L's Avatar
Oddometer: 224
Laugh Clark 4.7
Originally Posted by michael.brat View Post
D606's work well
Mike B
Hi Mike
I did find the O ring.
Going to make brackets but will keep eye on foam.
Night time here now, I will post some pictures tomorrow. Thanks to all that gave info and advice, fantastic forum this.
Now to put some miles on it.
Regards
Jaco
Old 01-11-2012, 01:31 PM   #36627
cyclewizard
Oddometer: 4,814
Here is a shot of one clear anodized with knurled fins for easy on and off and they are deeper so you can run big flat track cams with reduced base circles.
C-dub......
Old 01-11-2012, 01:35 PM   #36628
mendoteach
mendoteach's Avatar
Oddometer: 1,593
Hi Spud
I got them from Paul at Highway Dirt Bike, fantastic service.
Thanks for advice on photos
Regards
I second the service from HDB. My kid took and lost a special mirror bolt and he sent two of them for free via Prioity Mail costing him $5.
mendoteach is online now   Reply With Quote
Old 01-11-2012, 01:35 PM   #36629
cyclewizard
Oddometer: 4,814
another........ sorta blurry huh...... like my vision.....
C-dub......
Old 01-11-2012, 01:36 PM   #36630
kenny61
Crazy Idiot
kenny61's Avatar
Oddometer: 24,646
Any Clearance issues with the big tanks?
On the plains of hesitation lie the blackened bones of countless millions who at the dawn of victory lay down to rest, and in resting died.
Go forth and be a force of the awesome!
kenny61 is online now   Reply With Quote
Times are GMT -7.   It's 07:06 PM.
