Old 02-04-2012, 01:52 PM   #37951
kenny61
Crazy Idiot
kenny61's Avatar
Oddometer: 24,576
Its wider. reportedly keeps the countershaft from wearing out
On the plains of hesitation lie the blackened bones of countless millions who at the dawn of victory lay down to rest, and in resting died.
Go forth and be a force of the awesome!
kenny61 is offline   Reply With Quote
Old 02-04-2012, 02:15 PM   #37952
Spud Rider
Spud Rider's Avatar
Oddometer: 3,761
Originally Posted by ReferJohn View Post
thanks also for the help SPUD.
well i guess it's time for a beer then start operating.
John
You're welcome, John. The first installation of the XR650R C/S sprocket frequently requires a little "persuasion" to get it to fit. Subsequent installations are easier, after the XR650L countershaft conforms to the wider sprockets.
Spud
Old 02-04-2012, 02:22 PM   #37953
Spud Rider
Spud Rider's Avatar
Oddometer: 3,761
Originally Posted by Dadster View Post
Why run a xrr sprocket on the xrl? Is it cheaper or stronger?
If you wish to learn more about my experience using the XR650R C/S sprocket on the XR650L, you might enjoy reading the following thread.
http://www.thumpertalk.com/topic/867...650r-sprocket/
Incidentally, I always recommend either the PBI, or the Moose Racing, XR650R C/S sprockets for the first installation on the XR650L countershaft. These particular sprockets are a little thinner than others, and also have a deeper chamfer. Therefore, the PBI/Moose Racing sprockets require less "persuasion" for the initial installation. Subsequent installations get easier as the XR650L countershaft conforms to the wider sprockets.
Spud
Old 02-04-2012, 03:04 PM   #37954
Dadster
I'd rather be ridin
Dadster's Avatar
Oddometer: 211
My chain and sprockets are in good shape and my countershaft has ben replaced and is in good shape. To prevent having to replace the counter shaft again I will use the xrr front sprocket next replacement. Thanx. P.S. is this Dave's mods tough to do.
99 CR 250
06 XR 650L
03 KDX 50 Bacon Boy's
07 Hawkeye 300 4x4 Margarita Momma's
Dadster is offline   Reply With Quote
Old 02-04-2012, 03:05 PM   #37955
kenny61
Crazy Idiot
kenny61's Avatar
Oddometer: 24,576
Not if you can take off the carb and use a drill.. If your bike was bought used good chance its done already.. Mine was
Old 02-04-2012, 03:11 PM   #37956
Spud Rider
Spud Rider's Avatar
Oddometer: 3,761
You're welcome. As Kenny stated, Dave's mods are very easy to perform after you remove the carburetor. You can read the details regarding this modification at the following thread.
http://www.4strokes.com/tech/honda/xr650lcarbmods/
I buy carburetor jets for all my bikes from Rocky Mountain ATV/MC.
http://www.rockymountainatvmc.com/p/...eries-Main-Jet
Spud
Old 02-04-2012, 03:30 PM   #37957
Dadster
I'd rather be ridin
Dadster's Avatar
Oddometer: 211
I know the first owner. Carbon is stock. He said he removed the smog stuff. What's that mean?
99 CR 250
06 XR 650L
Old 02-04-2012, 03:34 PM   #37958
Dadster
I'd rather be ridin
Dadster's Avatar
Oddometer: 211
Spud
Im not happy with the throttle response so Im gonna do my homework and take care of business.
Thank you.
99 CR 250
06 XR 650L
Old 02-04-2012, 03:34 PM   #37959
kenny61
Crazy Idiot
kenny61's Avatar
Oddometer: 24,576
left side of cylinder commonly reffered to as smog pump.. Belive it is an egr system or air pump
Old 02-04-2012, 03:48 PM   #37960
ReferJohn
3RD Generation Rider
ReferJohn's Avatar
Oddometer: 447
Many Thanks again..... XRR sprocket installed, lots of grinding the chamfer, 3 beers, 3 tacos later and nice fit.
now i would like to grease rear wheel bearings, drive side has a bearing retanier- does this come out. or do i need special tool for removal? looks like it is peened in place. how do we grease that bearing?
again thanks for the helpful INTEL.
CMA FAST LANE
01' XR650L - 06' NPS50 - 07' KLX 110 - 12' FLTRU - 12' RMZ 250
ReferJohn is offline   Reply With Quote
Old 02-04-2012, 03:51 PM   #37961
Spud Rider
Spud Rider's Avatar
Oddometer: 3,761
The smog "octopus" is stock equipment on all XR650L motorcycles. You can shed 2.0 pounds of unsightly hoses and metal by removing the "smog tumor." Michael Bratcher posted a superb video detailing his removal of the smog pump.
Thanks for taking the time to film the great video, Mike!
Spud
Old 02-04-2012, 03:53 PM   #37962
kenny61
Crazy Idiot
kenny61's Avatar
Oddometer: 24,576
Yes there is a special tool you may also use two drill bits that fit in the hole. hold the tops together with one hand and putsomething between them to twist with the other
Old 02-04-2012, 03:55 PM   #37963
techforlife
CDI REPAIR
techforlife's Avatar
Oddometer: 4,281
Well......you need to drill the peens out,,drill just as far as it`s peened,,don`t drill in any farther.......
You can get a special tool and screw the retainer out,,or use 2 drill bits in the holes and a longer screw driver placed between the drill bits will act as the tool.........
If the bearings are smooth running,leave them alone.....you do not want to go in there unless you plan on installing new seals and bearings...
When/if you replace the bearings,,get double sealed bearings and pop one seal off with a pick and lube with good waterproof grease..
B
techforlife is online now   Reply With Quote
Old 02-04-2012, 04:00 PM   #37964
mcma111
mcma111's Avatar
Oddometer: 11,899
Rear Wheel Bearing Retainer
You should see 4 indents. One each between the 4 holes in the retainer. Get a 1/8" drill bit and drill in about a 1/8". Take a punch and tap the retainer counter clockwise and once free it should spin right out. If the retainer looks un-molested then there is only the factory grease in the bearings which to say AINT SHIT. Have fun greasing away
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 02-04-2012, 04:02 PM   #37965
Spud Rider
Spud Rider's Avatar
Oddometer: 3,761
The XR650L has sealed bearings. You must drill out the peen marks before you can remove the bearing retainer. After drilling the retainer, you can use a special tool to remove the retainer. However, most people put two drill bits into two of the holes, and place a long screwdriver between the two drill bits to torque the retainer counterclockwise.
Spud
Spud Rider screwed with this post 02-05-2012 at 11:13 PM
Times are GMT -7.   It's 04:31 AM.
