Old 02-15-2012, 06:08 PM   #38656
mcma111
mcma111's Avatar
Oddometer: 12,435
I have a Twin Air and a couple UNI. They are different in shape. So I am going to say NO. No clue about No-Toil.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 02-15-2012, 06:58 PM   #38657
Spud Rider
Spud Rider's Avatar
Oddometer: 3,809
Thank you, Steve.
The Twin Air filter for the XR650L has part #150601. Does your Twin Air filter with cage look like the photograph below?
Is the Uni air filter taller than the Twin Air filter? It appears the Twin Air filter might not fit over a taller, Uni air filter cage.
Spud
Spud Rider screwed with this post 02-15-2012 at 07:42 PM
Old 02-15-2012, 07:03 PM   #38658
Cloud9
I was HERE?
Cloud9's Avatar
Oddometer: 1,882
Originally Posted by Spud Rider View Post
Thank you, Steve.
Spud
Wait, wait, wait... Don't they all use the same hook and latch system that comes in the OEM air box???
Cloud9 is offline   Reply With Quote
Old 02-15-2012, 07:13 PM   #38659
Spud Rider
Spud Rider's Avatar
Oddometer: 3,809
Yes, I believe all the XR650L air filters employ the Honda, hook and latch system. However, my Uni air filter is a tight fit with the Honda, hook and latch system. I wonder if the Twin Air filter cage is shorter. If so, the Twin Air cage could still fit the Honda, hook and latch system, yet the Twin Air filter would not fit over a taller, Uni air filter cage.
Spud
Old 02-15-2012, 07:15 PM   #38660
mcma111
mcma111's Avatar
Oddometer: 12,435
Thank you, Steve.
Spud
Not at home now so I can't compare them.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 02-15-2012, 07:33 PM   #38661
elsalvadorklr
southern xr rider
Oddometer: 4,154
FWIW:
I use a UNI and a DT1 foam filter on the oem stock cage, the dti filter also fits nicely on the UNI plastic.screen cage,
So in short YES some are interchangeable.
I would assume that any foam filter is designed to work on the oem cage...
That twin air cage posted above does look quite a bit different than the UNI or stock.
All filters will use the stock cage/latch system right? dont know about KN
hope this helps
cheers
elsalvadorklr is offline   Reply With Quote
Old 02-15-2012, 07:37 PM   #38662
Spud Rider
Spud Rider's Avatar
Oddometer: 3,809
As always, I appreciate your willingness to help, Steve. If you have time, please compare the two filters when you are home.
Spud
Old 02-15-2012, 07:40 PM   #38663
Spud Rider
Spud Rider's Avatar
Oddometer: 3,809
Originally Posted by elsalvadorklr View Post
FWIW:
hope this helps
cheers
Thank you for your reply. However, the XR650L does not have a stock, air filter cage, since the XR650L comes stock with a throw-away, paper filter, instead of a foam air filter.
Spud
Old 02-15-2012, 07:42 PM   #38664
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,435
looks liek the twin air has a taller cage to make up for the shorter filter.
Originally Posted by Boondoggle View Post
Watching Dakar is like watching people who've built their own world, and for just a couple of weeks they get to live in it.
Old 02-15-2012, 07:55 PM   #38665
elsalvadorklr
southern xr rider
Oddometer: 4,154
Spud
right again...
But aftermarket filters are the same for both the 650l and xr600 no? maybe a good way to have interchangeable filters is to use a stock 600 oem screen cage.
then get whatever foam air filter you like. Dont know how it would affect the cv carb over the slide carb on the 600, but who knows might be a wrthwile swap?
Both my UNI and dt1 filter have the same sealing surface, what changes is the slight height difference, the UNI is a bit taller...
Id say the dt1 filter is just like your twin air.
cheers
Old 02-15-2012, 07:56 PM   #38666
ecubed
LFC Cat
ecubed's Avatar
Oddometer: 695
fork brace
Just finished my fork brace today......second iteration...
Spud, you NEED a fork brace! [and so does everyone on this thread]
'02 XRL '95 K11RS '14 KZ1000ABS
ecubed is offline   Reply With Quote
Old 02-15-2012, 07:59 PM   #38667
Lonestar2112
scatology expert
Lonestar2112's Avatar
Oddometer: 7,683
Has anybody noticed FatherXI sigline? 11???
Wow.
Is is this 205?
http://share.findmespot.com/shared/f...SKgzdmS9ir0XK3
Wypierdalaj ty chuju jebany
F*CK CANCER
Lonestar2112 is offline   Reply With Quote
Old 02-15-2012, 08:01 PM   #38668
elsalvadorklr
southern xr rider
Oddometer: 4,154
you make that?
looks very similar to the rsw...very nice...
Im selling mine...
I see you are using screws on both sides of the clamps...no twisting binding issues?
cheers
Old 02-15-2012, 08:08 PM   #38669
ecubed
LFC Cat
ecubed's Avatar
Oddometer: 695
you make that?
Im selling mine...
cheers
The RSW is VERY nice and for the price, "not can beat"! His is one piece center which is nice......
I made this because I can. I want to design a better one but this design is because I already made the fork clamps and had a flat piece over the tire. Caught the mud so I made it raised.
No problem with the clamps.
eee
Old 02-15-2012, 08:09 PM   #38670
mcma111
mcma111's Avatar
Oddometer: 12,435
Some of us don't need no stinking fork brace
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Times are GMT -7.   It's 11:52 PM.
