Old 02-22-2012, 12:27 PM   #39091
techforlife
CDI REPAIR
techforlife's Avatar
Oddometer: 4,302
Originally Posted by ThumpnRed View Post
No engine in the frame?
Engine,what engine.CW still has most of it
You saw the pic.......nothing in the frame.just back from being powder coated
B
techforlife screwed with this post 02-22-2012 at 04:29 PM
techforlife is offline   Reply With Quote
Old 02-22-2012, 12:38 PM   #39092
Sub Zero
Ice Breather!
Sub Zero's Avatar
Oddometer: 812
I do wheelies, because girls like guys who can get it up!
1994 WR250-Z | 1997 KX500 | 1998 KLX300 | 2004 CRF450R (Motard) | 2009 KX450F | 2001 XR650R | 1992 WR200R | 1992 WR500-Z | 1986 GPZ900 | 2005 RMZ450 | 1986 CR500AF in a 1998 CR250R frame | all street legal
"Great! What am I supposed to use now?! Harsh language?"
- Duke Nukem
Sub Zero is offline   Reply With Quote
Old 02-22-2012, 01:58 PM   #39093
KyoXR
Clouds, Snow, Rain
KyoXR's Avatar
Oddometer: 735
Originally Posted by mcma111 View Post
I have the OE front brake hose on my XRL along with a 280mm rotor. The increase in rotor size does help in slowing the bike down. On my XR600 that also has the CRF fork swap I have a CRF length stainless braided hose. For some reason it is a bit short but it's on there and no I can't tell the difference between the OE hose and the braided hose.
It sounds like your comparing from two different bikes, I bet if you switched to a braided hose on your XRL without changing any other perimeters you would notice a difference.
2007 XR650L,
Looking to acquire a stock XRL choke plunger.
The multi-quote function is your friend.
It's surprising how idiots have good luck, I don't have good luck.
KyoXR screwed with this post 02-22-2012 at 02:06 PM
KyoXR is offline   Reply With Quote
Old 02-22-2012, 02:09 PM   #39094
ShooterDave
Oddometer: 1,381
You have no helmet!!!!! So are you telling me that these same girls like brain splatter? Not sure these are the girls you're looking for.
My Lower 48+ ride on my XR650L - http://www.advrider.com/forums/showthread.php?t=565350
ShooterDave is offline   Reply With Quote
Old 02-22-2012, 02:31 PM   #39095
jesse_a29
jesse_a29's Avatar
Oddometer: 7
Is the xr350 carburetor interchangeable for the xl350 on an *eighty four. *
jesse_a29 is offline   Reply With Quote
Old 02-22-2012, 04:21 PM   #39096
oremike
Motorcyclest
oremike's Avatar
Oddometer: 2,397
In looking at where and how I ride my bike and being a cheap bastard(tm) I want a hooks up like glue and wears like iron set of tires. I ride mostly gravel roads so will be putting a Pireilli MT 21 on the front. Normally I'd put the matching MT 21 on the rear but this time I want to try the MT 43 DOT trials tire. Anybody tried the MT 43? the reviews are great and they say they last 3000 miles or 3 times what I get out of a MT 21.
Mike M.
Creswell, Oregon
'14 KLR 650
Ride what makes you giggle in your helmet
oremike is online now   Reply With Quote
Old 02-22-2012, 04:35 PM   #39097
techforlife
CDI REPAIR
Oddometer: 4,302
Might work well on gravel roads.a Kenda K270 is good on gravel and pavement.....wears really well......but sucks in mud....i get less than a 1000 miles out of D606`s and the MT21 is probably the same.....i get 3000+ easily out of the K270 and i ride hard,,wheelie at every stop sign kinda nuts the K270 is a little squirrelly on corners when new i`ve heard,,i don`t find it bad at all
If you ride sanely you`ll easily pass 3k on a K270...
Oh,nothing hooks up like glue on gravel,,,the shits too loose and flies with any throttle..
B
Old 02-22-2012, 04:54 PM   #39098
taco250
wannabe adventurer
taco250's Avatar
Oddometer: 1,329
I've heard the trials tires are good in sand and mud but wear out quick on harder surfaces due to being made of a softer compound. I've seen then in Central OR. Gravel can be the most evil surface to ride on so I'd lean to more aggressive than less. If you're not worried about a DOT stamp, try the Maxxis Desert IT (not the standard IT). It wears like iron and hooks up really well on just about any surface and is tough in rocky stuff. Plus they won't break the bank. However, getting them off when they're done is "challenging"
Prov 3:5 & 6
www.benddualsport.com
300+ mile Paisley OR day ride
taco250 is offline   Reply With Quote
Old 02-22-2012, 05:42 PM   #39099
ThumpnRed
Pig Wrangler
ThumpnRed's Avatar
Oddometer: 2,536
Gear police? Where are you?
Originally Posted by Cigar Mike :With plastic buy two.
'93 XR650L A few stock parts left...
ThumpnRed is offline   Reply With Quote
Old 02-22-2012, 05:52 PM   #39100
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 6,957
Agree with others and Spud sez the MT 43 was a big disapointment as far as wear goes.
The best combo I have found is the Dunlop 908RR rear and Metzler Unicross front. I got 7171 miles outa the 908 and the Unicross does not wobble even at 90 MPH. Cost more, yes, last twice as long though.
The 908's strong suite was sand but was way smooth on the highway.
Regards
Fritzcoinc
96 XR650L, 96 Guzzi Sport, 07 BMW K1200GT,
86 Husky 400 XCE, 00 Husky Te 610 e, 1999 Husky TC610 SM, 2000 Cagiva GC; Google: TX7
fritzcoinc is offline   Reply With Quote
Old 02-22-2012, 06:43 PM   #39101
mcma111
mcma111's Avatar
Oddometer: 12,067
Cartoons are stupid to begin with. Not worth the wasted breath.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 02-22-2012, 07:28 PM   #39102
prince_ruben
prince_ruben's Avatar
Oddometer: 1,726
Right here! Dude, I just broke a ankle WITH gear!
But then again it's your life and someone may need an organ donor.
Gear up man. We'd hate to see a rider diminish.
No worries in death, no worries in life.
prince_ruben is offline   Reply With Quote
Old 02-22-2012, 07:41 PM   #39103
cyclewizard
cyclewizard's Avatar
Oddometer: 4,814
B
Your Pop's has most of it...... he pawned the other half..
C-dub......
Powered by CW-Pistons/cams
Wizard manufacturing....
cyclewizard is offline   Reply With Quote
Old 02-22-2012, 08:24 PM   #39104
Sub Zero
Ice Breather!
Sub Zero's Avatar
Oddometer: 812
very true! says right on my drivers license "Organ Donor". though i dont push beyond my skill level when im not wearing gear. (which i actually always do wear my helmet and gloves when i ride) but a wheelie in front of my house at 10mph at my youth where skin and bones heal a lot faster for me, I wasn't to worried about a helmet and goggles and gloves and boots and chest protector and reflective vest and knee pads etc, etc, etc, etc
- Duke Nukem
Old 02-22-2012, 08:36 PM   #39105
prince_ruben
Oddometer: 1,726
Once I was part of a cadaver harvest from an organ donor. Man they take everything!
From my mobile yo!
Times are GMT -7.   It's 02:04 AM.
