Old 04-27-2012, 07:33 PM   #41836
techforlife
CDI REPAIR
techforlife's Avatar
Oddometer: 4,353
Originally Posted by rzrob View Post
Google it. They never came with them like the old XLs did. It's a bit of a project. I was all over it until I believe I discovered you need to split the cases to swap-out a gear shaft.
RZ Rob
Yup.gotta split the cases and install the XR600R countershaft...if you want the higher spline count shaft.....or you can use an earlier XL600R shaft.either way you`re going to split the cases..
B
techforlife is offline   Reply With Quote
Old 04-27-2012, 10:38 PM   #41837
Spud Rider
Spud Rider's Avatar
Oddometer: 3,855
Here's an interesting tire-changing tool.
You can buy it for 99.00 Euros, plus tax, plus shipping costs from Estonia. Here's a link to the website.
http://www.veebiinfo.ee/v1/page.php?...urit&page=4540
The website states this tool will work with "hub bearings size 20mm-28mm." That can't be correct, can it? The XR650L axles are 19mm in diameter.
I prefer tire spoons, which are much less expensive. However, I'm not changing Teraflex tires, either.
Spud
Old 04-27-2012, 10:44 PM   #41838
kenny61
Crazy Idiot
kenny61's Avatar
Oddometer: 24,826
That things pretty ingenius
On the plains of hesitation lie the blackened bones of countless millions who at the dawn of victory lay down to rest, and in resting died.
Go forth and be a force of the awesome!
kenny61 is offline   Reply With Quote
Old 04-27-2012, 10:54 PM   #41839
KyoXR
Clouds, Snow, Rain
KyoXR's Avatar
Oddometer: 786
HEY Spud!
So what do you think of your MT21, how many miles do you have on it?
I only have only put on a little over 300+ miles so far .
what are your thoughts on the tire so far?
MT21
D606
MT21 wrapped next to the old D606, I think MT21 is a bit smaller, even when mounted it looks smaller.
first run.
second run and the turn around point.
2007 XR650L
Looking to acquire a stock XRL choke plunger.Also don't get Wenzeled
KyoXR screwed with this post 04-28-2012 at 01:26 AM
KyoXR is offline   Reply With Quote
Old 04-27-2012, 11:11 PM   #41840
purpledrake
No Pretensions
Oddometer: 334
[QUOTE=Spud Rider;18562303]Here's an interesting tire-changing tool.
That is really slick. Spud, how do you find these things?
PD
The Good Lord gave most of us 10 digits; mine are all thumbs.
purpledrake is offline   Reply With Quote
Old 04-27-2012, 11:27 PM   #41841
Spud Rider
Spud Rider's Avatar
Oddometer: 3,855
Originally Posted by KyoXR View Post
HEY Spud!
So what do you think of your MT21 so far? how many miles do you have on it?
I only have only put on a little over 300+ miles so far and it seems a little more rounded then the D606 to me when it was new, which means it seems to be affected by ruts more and seems to loose traction a bit more and slide around a bit more as well, what are your thoughts on the tire so far?
I have ridden about 1,000 miles on my MT21 rear tire; so far, I like it. I bought the size 120/80-18, MT21 tire. I like the lighter weight and lower saddle height afforded by this tire compared to the size 120/90-18, D606 rear tire. Indeed, the MT21 rear tire seems to be more narrow than the D606 rear tire.
Spud
Spud Rider screwed with this post 04-27-2012 at 11:33 PM
Old 04-27-2012, 11:33 PM   #41842
Spud Rider
Spud Rider's Avatar
Oddometer: 3,855
PD
That's a slick tool, but it certainly is expensive, PD. I just happened upon it while surfing the internet.
Spud
Old 04-27-2012, 11:48 PM   #41843
EpHu
enduro RuLezZ
EpHu's Avatar
Oddometer: 61
Ice on the water. C.O. :)
EpHu is offline   Reply With Quote
Old 04-27-2012, 11:49 PM   #41844
Spud Rider
Spud Rider's Avatar
Oddometer: 3,855
Indeed, it is. I don't think one would damage his rims using that tool.
Spud
Old 04-28-2012, 01:27 AM   #41845
Sourjon
TAT'erd
Sourjon's Avatar
Oddometer: 2,051
Spud
That's pretty slick Spud!
John
Endeavor to suck less--Gaspipe
I would rather be riding an imperfect bike than waiting around for perfection. --JDowns
Sourjon is offline   Reply With Quote
Old 04-28-2012, 05:17 AM   #41846
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 7,288
Originally Posted by LexLeroy View Post
I used a stainless socket-head bolt. 20mm x 2.5, 50mm long to start and subsequently massaged on the lathe and shortened. I used high-temp silicone sealer to hold everything together - seems to work OK. The trick is finding a thermometer that reads the appropriate range. I got the bolt and the thermometer from MSC, the o-ring from the local hardware store.
Graingers has a big slection of thermometers. Thats where I got mine.
Regards
Fritzcoinc
fritzcoinc is offline   Reply With Quote
Old 04-28-2012, 05:22 AM   #41847
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 7,288
Spud
And I guess you need different tools for different diameter tires?
Pretty slick.
Regards
Fritzcoinc
Old 04-28-2012, 06:14 AM   #41848
JBADV
searching for sanity
JBADV's Avatar
Oddometer: 3,430
Originally Posted by ced40 View Post
I am not about to read all of 2700 pages to find a few things I want on my (new to me) 2007 XR650L.
Just got it and would like to make it perfect for me. I need some help from your experts here.
I would like to change Handle bars, Pegs, get some bar risers and a skid plate. what do you fellows recommend. I will do more mods later but for now I would like to get it ready for our trip to Nevada. Thanks in advance for your help.
Check out page page 2686.
The older I grow,the faster life goes.
The more I learn,the less I know.
JBADV is offline   Reply With Quote
Old 04-28-2012, 06:34 AM   #41849
Stretch67
Bent, But Not Broken
Stretch67's Avatar
Oddometer: 6,956
The XRL Index Thread: http://advrider.com/forums/showthread.php?t=451212
IBA # 33113
Alaska
Blue Ridge Parkway & Outer Banks
XR400 Index
Stretch67 is online now   Reply With Quote
Old 04-28-2012, 07:42 AM   #41850
Rider11x
Resident Hillbilly
Rider11x's Avatar
Oddometer: 142
Tip of the day: Anyone installing an Acerbis tank on an xrl, when the tank needs to spread to fit the frame, fill it with hot tap water and it will flex right into place. Bolt down and drain it. Let it cool before removing it to shake out the water. Gently reforms the tank to fit.
2012 Honda XR650L Adventure Bike
Honda XR Fan for 30+ years!!!!!
Rider11x is offline   Reply With Quote
Times are GMT -7.   It's 10:50 PM.
