Old 05-13-2012, 12:05 PM   #42346
Lexey63
AlcoDventurer
Lexey63's Avatar
Oddometer: 46
Samara city
National Park "Zhiguli"
http://zovff.ya.ru
Lexey63 is offline   Reply With Quote
Old 05-13-2012, 01:16 PM   #42347
81cr450
Oddometer: 96
Boobies
Now that I have you attention I need some input on my 95 XRL650. I'm wondering what the maintainece interval on the connecting rod is. My bike is internally stock with 18,000 miles on it. I'm getting a little blow by & am going to do a ported head, stage 1 hotcam, FMF header, Kehein pumper carb, & a 2mm overbore. I'd rather not dig into the bottom end if I dont have to but... I'll check the side to side & look it over of course. I'm just not sure it will need it as I've searched for rod failure on on an xrl650 & not one post comes up. The thing has a few miles but it really seems like its been babied. I'm gonna pick up a jug & have the bore & hone done. I just bought a head & will get it gone through before I tear into it. Basically I just wanna have it all lined up to tear down & put right back together, just curious on how deep I should go? Thanks in advance for any input.
81cr450 is offline   Reply With Quote
Old 05-13-2012, 01:30 PM   #42348
Wattner
Wattner's Avatar
Oddometer: 5,283
Sounds like a nice project! The rod will be discolored and have a blue hue on one end, not to worry. The rod will last a long long time and usually only needs replacing if the wrist pin goes and the rod is scored... May I suggest some kibblewhite (or CW) stainless valves and a set of aftermarket springs with Ti-retainers? CW (CycleWizard) makes cams, pistons, rods and valves and is well known here for his excellent quality and prices, FWIW. Another thing, allow CW to rebuild the oil pump and extend the clutch arm going into the motor... Little things that pay huge dividends
On the bottom end, replacing the stock 2nd gear with an NX650 gear is one of the best mods you can do.... While you are at it, change the 5th as well. The 2nd gear takes the gap out between 1st and 2nd and the 5th allows you to run lower final gearing.... This transforms the bike drastically and with the mods you are adding, will make your bike a whole new machine! You can run 15/48 sprockets and creep along at idle and still tool down the road comfortably at highway speeds
Wattner is online now   Reply With Quote
Old 05-13-2012, 01:36 PM   #42349
ThumpnRed
Pig Wrangler
ThumpnRed's Avatar
Oddometer: 2,536
The internals on my '93 were in great shape (except the fragged countershaft and the leaking valve seal). Your bottom end may very well be in need of nothing.
Originally Posted by Cigar Mike :With plastic buy two.
'93 XR650L A few stock parts left...
ThumpnRed is offline   Reply With Quote
Old 05-13-2012, 01:59 PM   #42350
81cr450
Oddometer: 96
Excellent thanks for the input. The countershaft does show some wear but I'm hoping the PBI XRR sprocket will get me some more miles out of it.
"(CycleWizard) makes cams, pistons, rods and valves and is well known here for his excellent quality and prices, FWIW. Another thing, allow CW to rebuild the oil pump"
Is CW a member you need to pm for parts or does he have a website?. I can grind my own valves as I work in a machine shop assembling pulling / drag race diesel motor's. D-Max & Cummins. I'll do my own porting as well. But I do plan on replacing the guides & exhaust valves atleast. The pump rebuild & clutch arm fix sound like sound advice. Just been bargain hunting trying to come up with the best prices on some good parts. Timing chains go bad? Especially running stiffer spring?
Old 05-13-2012, 04:42 PM   #42351
Barron
M0DAH0LIC
Barron's Avatar
Oddometer: 2,385
New Fender...
Yeah it's made for a CRF, but that's nothin a dremel can't fix I still have some smoothing out around the cuts, but it should fit under that new rack pretty well.
-Barron
1996 XR650L with a couple mods
If everyone brewed beer there would be no war.
Barron is offline   Reply With Quote
Old 05-13-2012, 05:03 PM   #42352
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,311
If anyone has a CRF stem to turn down now is the time. I have three going to my friend tomorrow. Get yours in now just to make it easier on him. PM for $ details if you're in.
Originally Posted by Boondoggle View Post
Watching Dakar is like watching people who've built their own world, and for just a couple of weeks they get to live in it.
Old 05-13-2012, 05:43 PM   #42353
kubiak
Oddometer: 4,829
-Barron
they look nice on the xrs, i even put one on my bmw dakar!
Old 05-13-2012, 06:18 PM   #42354
Cumbacheech
XRated
Cumbacheech's Avatar
Oddometer: 823
-Barron
Barron,
Be sure to post pics on how you mounted your fender... I am always looking for other ways to mount the CRF fender... Thinking of getting a black fender as well.
Cheers,
Cumbacheech
2001 XR650L - Done for now...!!
Pics: Adventure setup, SUMO setup, Dirt setup
Cumbacheech is offline   Reply With Quote
Old 05-13-2012, 06:40 PM   #42355
xr400r
xr400r's Avatar
Oddometer: 3,138
Please dont beat me for this......
Anyone run 20w-50 oil.? The owners manual says 10w-40 but would it be a bad thing to run 20w-50?
Riff Raff 2015!
xr400r is offline   Reply With Quote
Old 05-13-2012, 07:02 PM   #42356
Drunk_Uncle
Drunk_Uncle's Avatar
Oddometer: 2,182
81cr450
+1 on have CW do your motor. Before I could run flat out in any gear, now not so much. Twisted the throttle at 65 lost the rear end going side to side. Almost to much power but I LOVE it!!!
Big Thanks to the Wizard for a bad ass bike!!
"I refuse to tiptoe through life only to arrive safely at death"
'13 Tiger 800XC, '14 Street Triple, '00 KLR 650(current project), and a 2010 Honda NT700V for the wife.
Drunk_Uncle is offline   Reply With Quote
Old 05-13-2012, 07:07 PM   #42357
onaXR OP
Druid
onaXR's Avatar
Oddometer: 2,086
Where are you guy buying body plastics? I need a airbox side cover.
Klaatu barada nikto
onaXR is offline   Reply With Quote
Old 05-13-2012, 07:27 PM   #42358
KyoXR
Clouds, Snow, Rain
KyoXR's Avatar
Oddometer: 735
since the subject is up again, I would like to know just for reference if putting in the NX650 2nd gears gap is the same between 2nd and 3rd now as it was between 1st and 2nd with the stock 2nd gear? is it a more subtle gap? or about the same just moved from 1st to 2nd to 2nd to 3rd?
also, Wattner, lets see some pic's of the floor after your "tire buffing".
2007 XR650L,
Looking to acquire a stock XRL choke plunger.
The multi-quote function is your friend.
It's surprising how idiots have good luck, I don't have good luck.
KyoXR is offline   Reply With Quote
Old 05-13-2012, 07:35 PM   #42359
techforlife
CDI REPAIR
techforlife's Avatar
Oddometer: 4,301
Unfortunately if you need one to fit the XRL with the battery box still in place it`s OE or nothing,,for some reason no one seems to want to make them in the aftermarket...which really sucks...
B
techforlife is online now   Reply With Quote
Old 05-13-2012, 07:38 PM   #42360
techforlife
CDI REPAIR
Oddometer: 4,301
Gap is just moved up..but........since the bike is moving at a decent speed it is far less noticeable........
I put in the FMX 5TH gear too.......it is really tall,you gotta be moving at a decent speed to use fifth now,,30mph and fifth = lugging/chain slap like crazy...........but it`ll be sweet at high speeds..
B
Times are GMT -7.   It's 04:00 PM.
