Old 05-31-2012, 06:51 AM   #42901
EntiatRider
EntiatRider's Avatar
Oddometer: 87
Hey MCMA111. I hope you are healing well. How did you adjust your shifter. I've researched for hours and have not found an answer on how to raise the shift lever. I see you pulled off the cover for access. Can you just loosing the bolt and adjust it? My fancy new riding boots don't fit to shift gears. Thanks.
EntiatRider is offline   Reply With Quote
Old 05-31-2012, 07:04 AM   #42902
elsalvadorklr
southern xr rider
Oddometer: 4,154
loosen bolt, slam flat screwdriver in slot to open gap
pull shift lever off
notice grooves/teeth
reinstall(with screwdriver still in slot on shift shaft with a little grease or locking compound) 2 or 3 teeth up
take screwdriver off
tighten bolt with locking compound
cheers
elsalvadorklr is offline   Reply With Quote
Old 05-31-2012, 07:08 AM   #42903
mcma111
mcma111's Avatar
Oddometer: 12,588
cheers
^ What he said
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 05-31-2012, 07:12 AM   #42904
elsalvadorklr
southern xr rider
Oddometer: 4,154
thats my first
"WHAT HE SAID"
time to celebrate now! jajajajaja
oh wait no Im sick
eeeh
Old 05-31-2012, 07:17 AM   #42905
mcma111
mcma111's Avatar
Oddometer: 12,588
The shift lever fits on the shift shaft that is splined so that it stays in place. Usually you need to tap a flat blade screw driver in the split of the lever to help open it up so it will slide off of the shaft. Best to mark the lever and shaft before you start moving it around so you know where you started from. The shaft has a groove all the way around it so that if the bolt lossens up the shifter doesn't just fall off. The bolt has to be removed before the shifter will slide off of the splines. I had to remove the counter shaft cover because the shift lever would hit it (not enough travel) and not allow me to shift.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 05-31-2012, 08:56 AM   #42906
Dinty
Oddometer: 3
Pics of your handlebars with Tusk handguards
Hey All,
I'm trying to finish up my handlebar upgrade from stock:
  • Pro Taper Contour 1-18" Oversized Handlebars KX High
  • 2" Rox Risers
  • Tusk fat bar adapters
http://www.rockymountainatvmc.com/p/...or-%2528P%2529
Now I have just about everything back together and tightening things up with final adjustments... and am finding that the cables and the tusk hand guards seem a little tight. My question to the group is in your current setup, do you have your cables routed below or above your hand guard hardware? Currently I have the cables routed above the hand guards but because I had to install the Tusk hand guard adapter for the fat bar, things seem a little tight - and I'm not sure longer cables would help. Tonight I may swap and route the cables below - but if I do that, the Tusk guards may be a little higher than I would like. Anyone have any pics of your setup you can share info I'd appreciate it.
I may post a picture tonight.
Dinty is offline   Reply With Quote
Old 05-31-2012, 08:59 AM   #42907
brendon2009
Oddometer: 2
NEW to this forum
Hey guys, Im a member over at supermotojunkie and I recently decided to join here. I've had 3 suzuki bikes and now my first honda. Right now its an 07 xrl mainly factory. Im building it over the summer and converting to sm setup. I like a lot of the ideas i see in this thread and I'll be posting pictures here I'm sure. Here is a pic of what it looks like currently, as all I've done so far is the warp 9 wheels and IMS smog kit.
brendon2009 is offline   Reply With Quote
Old 05-31-2012, 09:03 AM   #42908
thebigman
bout a dollar 3.98
thebigman's Avatar
Oddometer: 3,524
Originally Posted by Dinty View Post
Hey All,
  • 2" Rox Risers
I used these.
http://www.google.com/products/catal...ed=0CGMQ8gIwBA
Marko
08 xr650l ,99 xr650l, 10 HDXR1200X ,84atc200s 85atc200s, 80ct110 ,99xr70, 04xr650l ,
Dumb ass people do dumb ass things
thebigman is offline   Reply With Quote
Old 05-31-2012, 09:18 AM   #42909
AZ TOM
Oddometer: 4,079
Very little grinding on the sprocket retainer & it will slip on. Steve grind off a little on the bottom of the sprocket cover, just enough to clear the lever & reinstall it.
AZ TOM is offline   Reply With Quote
Old 05-31-2012, 09:30 AM   #42910
XR650L_Dave
Oddometer: 3,761
Originally Posted by Cumbacheech View Post
I think that is my problem.. I can put the retainer on I can not turn it to line up with the holes... I tried tapping the sprocket onto the shaft, but that did not work... looks like i am slightly off. I will try to grind down the retainer a little...
Thanks for the help guys!
I would chamfer the sprocket splines on the case sides instead of grinding the retainer...
---->>Thanks for the rotor, guys!<<----
XR650L_Dave is offline   Reply With Quote
Old 05-31-2012, 09:40 AM   #42911
AZ TOM
Oddometer: 4,079
I took such a little off the retainer I think a file may have done the job. Don't think the retainer was weakened any. Once in place I doubt there is much strain on it?
Old 05-31-2012, 10:00 AM   #42912
Barron
M0DAH0LIC
Barron's Avatar
Oddometer: 2,461
Quick question here that I think I already know the answer to....
My bike's running kinda rough after I changed some gaskets in my carb, the only thing that I can think is different is where the fuel screw was adjusted, would that do it? I'm really behind on the carb power curve...
1996 XR650L with a couple mods
If everyone brewed beer there would be no war.
Barron is offline   Reply With Quote
Old 05-31-2012, 10:17 AM   #42913
mcma111
mcma111's Avatar
Oddometer: 12,588
There are two type of fuel/air adjustments. If the screw is between the carb and the air box it is a AIR screw. If the screw is between the carb and the engine it is a FUEL screw. The XRL has a FUEL screw. By turning in the screw (leaner) you are reducing the amount of fuel at the lower operation range of the engine, idle to about 1/8 throttle. By turning it out you are giving the engine more fuel = richer. I usually set mine around 2 1/2 turns out from having the screw gently seated.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 05-31-2012, 10:23 AM   #42914
Barron
M0DAH0LIC
Barron's Avatar
Oddometer: 2,461
Cool, thanks
Old 05-31-2012, 10:39 AM   #42915
tjrockit
One day closer...
tjrockit's Avatar
Oddometer: 1,212
Originally Posted by jungleplant View Post
We Have them , only got 6 sets,MR. Spud and Mr. Cigar Mike get the first 2 , but the first guys that pm me at 2am pacific tonight, time gets the other 4 sets make sure i have the shipping addy , these are for testing ok guys , all i can say is that they will be called FA Brackets because that's all they will do, which we think will be good enough, if we see some failures we can make them thicker , None for sale don't wanna get banned thanks spud and mike for all the hard long hours you put into these things, should help a lot of folks out there
mike
ps
gonna powder coat them clear with gold sparkle we pay the shipping to usa all others pay there own shipping ok
Yep, I guess that's what happens when you only read the thread over lunch...
Any pics of them mounted?
BTW - The first set of tie downs you sent me had off set holes and so I tried them on my XR250R and they bolted right up!! The second set seems to have the holes more exact so they only fit the XRL. Was happy that I got the first set when I did so I can have them on both bikes. Works nice on my carrier.
2007 Honda XR650L
Dirt Roads within a 100 mile radius of Austin, TX
*** The views or comments I express on this site and/or on any other site/forum/social media are strictly my own and do not reflect any past, current or future employer and/or any organization. They are solely my own personal opinions.***
tjrockit is offline   Reply With Quote
Times are GMT -7.   It's 06:12 PM.
