Old 09-28-2012, 09:31 AM   #46966
Barron
M0DAH0LIC
Barron's Avatar
Oddometer: 2,460
Originally Posted by XR650L_Dave View Post
Ebay it as a "titled XR600 frame", just has a weird gas-tank mount.
1996 XR650L with a couple mods
If everyone brewed beer there would be no war.
Barron is offline   Reply With Quote
Old 09-28-2012, 09:34 AM   #46967
chipbl
chipbl's Avatar
Oddometer: 288
Anybody recognize this part?
Not the penny....
Cleaning some gasket remover overspray from the back of the engine with a rag, this fell out on the garage floor... Spacer? FWIW, the right side cover was off.
Anyone?
2008 XR650L, tons of goodies.
chipbl is offline   Reply With Quote
Old 09-28-2012, 09:39 AM   #46968
Barron
M0DAH0LIC
Barron's Avatar
Oddometer: 2,460
Originally Posted by chipbl View Post
Not the penny....
Anyone?
That piece AND an little rubber O ring go between your oil pump and the side cover, if they aren't both put back you WILL kill your engine...
-Barron
Old 09-28-2012, 09:40 AM   #46969
elsalvadorklr
southern xr rider
Oddometer: 4,154
dude! do not start your bike!
double check its not the spacer that goes to the oil pump and cover...there is an oring too that goes around it...
right cover off
almost 100percent sure...
do it or risk frying your bike...
elsalvadorklr is offline   Reply With Quote
Old 09-28-2012, 09:48 AM   #46970
Spud Rider
Spud Rider's Avatar
Oddometer: 3,809
Not the penny....
Anyone?
That has got to be the "holder" which passes oil from the pump to the right crankcase cover; it's part #13 in the following diagram.
Remove you right crankcase cover immediately and replace that metal sleeve. Also, make sure the O-ring, part #19 is present, or you will certainly damage your engine.
Spud
Old 09-28-2012, 09:55 AM   #46971
chipbl
chipbl's Avatar
Oddometer: 288
Spud
Gentlemen and scholars, all. Will check tonight. Haven't even put oil in yet. Thank you!
Old 09-28-2012, 09:59 AM   #46972
mcma111
mcma111's Avatar
Oddometer: 12,448
It helps to put some grease on the collar to keep it in place:
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 09-28-2012, 01:31 PM   #46973
ThumpnRed
Pig Wrangler
ThumpnRed's Avatar
Oddometer: 2,558
Originally Posted by fritzcoinc View Post
I have a " pumper " carb. on my Husky. The sudden throttle response is fun, for a while, sorta like stiff suspension. I guess?
I'm getting old, I think, I seem to now prefer the smooth response of a CV carb. and the smooth ride of deep, plush suspension. Sonny Boy!!!
I can respect a man who knows he's getting soft and is man enough to admit it.
Beer's on me next time I get to Tejas
Originally Posted by Cigar Mike :With plastic buy two.
'93 XR650L A few stock parts left...
ThumpnRed is offline   Reply With Quote
Old 09-28-2012, 01:34 PM   #46974
ThumpnRed
Pig Wrangler
ThumpnRed's Avatar
Oddometer: 2,558
Originally Posted by smokeeater495 View Post
I feel the same. Had an FCR on my bike for a few weeks. PITA to tune. It's gone now, back to the stock CV. I think if the motor was built with a higher compression piston and some head work the FCR would work better. I too am rethinking my whole bike philosophy.
FCRs are easy to tune! There's just more to tune. Seriously... I did cheat a bit though. JD Jetting's Excel spreadsheet makes the task much easier. Otherwise needle selection can drive you off a cliff.
Old 09-28-2012, 02:41 PM   #46975
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 7,130
Let's race hot shot.
Regards
Fritzcoinc
96 XR650L, 96 Guzzi Sport, 07 BMW K1200GT,
86 Husky 400 XCE, 00 Husky Te 610 e, 1999 Husky TC610 SM, 2000 Cagiva GC; Google: TX7
fritzcoinc is offline   Reply With Quote
Old 09-28-2012, 02:44 PM   #46976
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 7,130
More on the oil tube. An easy thing to leave out. The O ring is PN 91305 below.
BUT, how did it get on the back of the engine??????????????????
Regards
Fritzcoinc
Old 09-28-2012, 02:58 PM   #46977
Mossy-Back
Wet-Sider
Mossy-Back's Avatar
Oddometer: 1,649
Anyone have a stock chainguard? Mine was missing when I bought it...
Also, what's a good replacement for the chain slider on the bottom right behind the front sprocket?
'05 CRF450X
Once a Marine, always a Marine!
Mossy-Back is online now   Reply With Quote
Old 09-28-2012, 03:01 PM   #46978
mcma111
mcma111's Avatar
Oddometer: 12,448
Lower chain slider is an OE only part.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 09-28-2012, 03:19 PM   #46979
Barron
M0DAH0LIC
Barron's Avatar
Oddometer: 2,460
MF'n gremlins dude, MF'n gremlins.
Old 09-28-2012, 04:05 PM   #46980
Mossy-Back
Wet-Sider
Mossy-Back's Avatar
Oddometer: 1,649
Gotcha. Thanks Steve.
'05 CRF450X
Times are GMT -7.   It's 09:01 PM.
