Old 09-30-2012, 07:34 AM   #47026
techforlife
CDI REPAIR
techforlife's Avatar
Oddometer: 4,307
Originally Posted by Barron View Post
You should see oil squirt 2 or 3 feet out of that bolt when it's cracked.
FWIW.....I don't want to alarm you or get you headed down the wrong track, but the only time I have seen what you are describing was when I bent the oil line inside the engine from the pump (right next to the oil pump gear) the gear ate through the line and starved the top end for oil... I had oil coming out of the fill hole and and all. When I opened the banjo bolt it was squirting a little oil, but it was spitting air also, you should see nothing but oil.
-Barron
Where the hell did you get 2-3 feet of oil squirt coming out,,and how.........gezzzzuuuuusssssss
All the bikes i`ve worked on you could get a good fast drool down the side of the clutch cover,,depending on how much you loosened the banjo bolt......maybe if you took the bolt out and reved the shit out of the engine
I call BS Scott...........and the only way i`m gonna believe you is a video...
SO...........GET ON YOUTUBE AND POST ER UP
This should be cool.......wear your sunday best too...or a white t-shirt..
B
techforlife is offline   Reply With Quote
Old 09-30-2012, 07:40 AM   #47027
Rider11x
Resident Hillbilly
Rider11x's Avatar
Oddometer: 142
-Barron
I am guessing this is done at idle?
If I leave the dipstick dangle in the hole while running, wouldn't it just overflow if the line to the head was being starved?
2012 Honda XR650L Adventure Bike
Honda XR Fan for 30+ years!!!!!
Rider11x screwed with this post 09-30-2012 at 07:48 AM
Rider11x is offline   Reply With Quote
Old 09-30-2012, 07:41 AM   #47028
Barron
M0DAH0LIC
Barron's Avatar
Oddometer: 2,389
B
Yeah I used to just crack it enough to see the oil ooze out, but after melting my top end I always unscrew the bolt til I can see the top of the hole... I didn't think it would shoot that far either which is why I was washing the oil off the side of my house
Just cracking it will show flow, but if there is air in the pump I might not see the air getting pushed out. I might be wrong, but I know opening it all the way up lets me know when it's good for sure... YMMV
-Barron
1996 XR650L with a couple mods
If everyone brewed beer there would be no war.
Barron is offline   Reply With Quote
Old 09-30-2012, 07:42 AM   #47029
Barron
M0DAH0LIC
Barron's Avatar
Oddometer: 2,389
Yes, never rev an engine when you first start it, your engine will hate you.....
Old 09-30-2012, 07:53 AM   #47030
Rider11x
Resident Hillbilly
Rider11x's Avatar
Oddometer: 142
By the way, just out of curiosity could you go over in detail how you check your oil level... The reason I ask is because you may have it grossly over filled... have you seen oil under the bike or in the air box?
-Barron
Sure. I come home from a ride. I shut down the bike and after a minute or two I remove the dipstick and clean it off. I prop the bike upright, and insert the dipstick until the threads tap the top of the hole, and remove it to check level.
Old 09-30-2012, 07:57 AM   #47031
Barron
M0DAH0LIC
Barron's Avatar
Oddometer: 2,389
That should be good. I was kinda hoping you'd say you checked it cold, and saw oil under it after filling it up...
Old 09-30-2012, 08:48 AM   #47032
Rider11x
Resident Hillbilly
Rider11x's Avatar
Oddometer: 142
B
Old 09-30-2012, 08:51 AM   #47033
scotty69
scotty69's Avatar
Oddometer: 903
A honda mechanic told me to stop wasting money on expensive motorcycle oil and dump Rotella, the dino kind, in the bike and ride! Anyone think this is really safe? I kinda believe the guy because he is a Honda mechanic. Hmmmm....
Orchestrated Chaos
arkansas500.com
scotty69 is offline   Reply With Quote
Old 09-30-2012, 09:02 AM   #47034
cyclewizard
cyclewizard's Avatar
Oddometer: 4,814
-Barron
Face shot baby.....open wide.
C-dub......
Powered by CW-Pistons/cams
Wizard manufacturing....
cyclewizard is offline   Reply With Quote
Old 09-30-2012, 09:04 AM   #47035
Barron
M0DAH0LIC
Barron's Avatar
Oddometer: 2,389
It got me in the leg pretty good... I wasn't expecting it to... be so excited....
Old 09-30-2012, 09:07 AM   #47036
kenny61
Crazy Idiot
kenny61's Avatar
Oddometer: 24,578
no way bike will explode before you could even start it
On the plains of hesitation lie the blackened bones of countless millions who at the dawn of victory lay down to rest, and in resting died.
Go forth and be a force of the awesome!
kenny61 is offline   Reply With Quote
Old 09-30-2012, 09:15 AM   #47037
Rider11x
Resident Hillbilly
Rider11x's Avatar
Oddometer: 142
Yeah, My 400ex race quad got me in good practices with it's dry sump engine. Same procedure.
Old 09-30-2012, 09:35 AM   #47038
Rider11x
Resident Hillbilly
Rider11x's Avatar
Oddometer: 142
Old 09-30-2012, 09:37 AM   #47039
ThumpnRed
Pig Wrangler
ThumpnRed's Avatar
Oddometer: 2,538
Your Honda mechanic is a wise and honest man.
Originally Posted by Cigar Mike :With plastic buy two.
'93 XR650L A few stock parts left...
ThumpnRed is offline   Reply With Quote
Old 09-30-2012, 10:18 AM   #47040
Barron
M0DAH0LIC
Barron's Avatar
Oddometer: 2,389
If you mean the flexible hose from the frame to the head, yeah that's possible, easy to check too.... the oil line with the PSI is the metal one that goes up the back of the engine to the valve cover.
You might want to make sure there isn't something blocking the passage into the engine where the hose attaches to the engine, I'd take a valve cover off and shine a flask light in there then look through the hole to make sure it's clear.
-Barron
Times are GMT -7.   It's 07:49 AM.
