Old 09-30-2012, 09:35 AM   #47041
Spud Rider
Spud Rider's Avatar
Oddometer: 3,797
Originally Posted by scotty69 View Post
A honda mechanic told me to stop wasting money on expensive motorcycle oil and dump Rotella, the dino kind, in the bike and ride! Anyone think this is really safe? I kinda believe the guy because he is a Honda mechanic. Hmmmm....
Originally Posted by ThumpnRed View Post
Your Honda mechanic is a wise and honest man.
Indeed, your mechanic is wise and honest. However, although it is very good motor oil, there's nothing special about Shell Rotella. All of the commercial grade, 15W/40 diesel oils are very good. I have been using Mobil Delvac, 15W/40 diesel oil in all my motorcycles with excellent results. You might enjoy reading the following articles on motor oil.
http://www.calsci.com/motorcycleinfo/Consumables.html
http://www.calsci.com/motorcycleinfo/Oils1.html
Spud
Old 09-30-2012, 09:49 AM   #47042
mcma111
mcma111's Avatar
Oddometer: 12,401
Originally Posted by Barron View Post
If you mean the flexible hose from the frame to the head, yeah that's possible, easy to check too.... the oil line with the PSI is the metal one that goes up the back of the engine to the valve cover.
You might want to make sure there isn't something blocking the passage into the engine where the hose attaches to the engine, I'd take a valve cover off and shine a flask light in there then look through the hole to make sure it's clear.
-Barron
Wrong and wrong.
The oil line at the back of the front down tube returns the oil from the engine to the frame tank.
To check for blockage at the rocker cover breather hose simply remove it from the frame and BLOW through it.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 09-30-2012, 09:57 AM   #47043
mendoteach
mendoteach's Avatar
Oddometer: 1,616
Here are some pictures everyone will enjoy. These shots are of a flat tracker named Andy from New York. He has been kicking everybody's ass–72 consecutive races His secret? An ancient air-cooled motor massaged by our own Cycle Wizard, aka, CW, C-Dub etc. It is a high compression 724cc motor with a radical cam I'm guessing. CW may chime in about other the other goodies. Andy and CW's mill is kicking ass on 515cc Honda CRF powered bikes. So yes, the CW mill is VERY fast.
mendoteach is offline   Reply With Quote
Old 09-30-2012, 10:09 AM   #47044
Barron
M0DAH0LIC
Barron's Avatar
Oddometer: 2,454
Originally Posted by mcma111 View Post
Wrong and wrong.
I meant the oil line on the back of the engine where you undo the banjo bolt to check for oil flow...
1996 XR650L with a couple mods
If everyone brewed beer there would be no war.
Barron is offline   Reply With Quote
Old 09-30-2012, 10:26 AM   #47045
mcma111
mcma111's Avatar
Oddometer: 12,401
Sokay.
I loosen the bolt on the clutch cover. Less mess to clean up (oil dribbling down the fins of the head)
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 09-30-2012, 11:30 AM   #47046
Rider11x
Resident Hillbilly
Rider11x's Avatar
Oddometer: 142
Originally Posted by Rider11x View Post
If I leave the dipstick dangle in the hole it normally occupies in the top of the reservoir while running, wouldn't the reservoir just overflow if the line to the head was being starved? As in oil entering reservoir, and having no place to escape......Would flood the reservoir, and come out a temp dipstick that gave it a place to go. Just thinking out loud.
This question was misunderstood, so I reworded it above. Thanks everyone....So if the reservoir is vented, and oil backed up, would it just pour out the vents rather than pushing past an o ring in the dip stick? Are XR's only dip sticks prone to leakage?
2012 Honda XR650L Adventure Bike
Honda XR Fan for 30+ years!!!!!
Rider11x screwed with this post 09-30-2012 at 11:35 AM
Rider11x is offline   Reply With Quote
Old 09-30-2012, 11:34 AM   #47047
kubiak
Oddometer: 4,829
found a pic of my 89 xr600 from about 12 years ago.back in the day lol!
Old 09-30-2012, 11:34 AM   #47048
jungleplant
Motorcyle Stuff
jungleplant's Avatar
Oddometer: 1,858
If I leave the dipstick dangle in the hole while running, wouldn't it just overflow if the line to the head was being starved?
www.manracks.com
jungleplant is offline   Reply With Quote
Old 09-30-2012, 12:04 PM   #47049
seth0941
NW Adventure Rider
seth0941's Avatar
Oddometer: 481
seth0941 is offline   Reply With Quote
Old 09-30-2012, 12:33 PM   #47050
bamfslap
Oddometer: 205
Very nice!! The ol gals still got it!
Maybe one day I can afford a sweet ass CW build!
bamfslap is offline   Reply With Quote
Old 09-30-2012, 12:57 PM   #47051
Sub Zero
Ice Breather!
Sub Zero's Avatar
Oddometer: 813
good god! normally i dont care for black on bikes period, but somehow you did it just right! do you have a full resolution pic anywhere?
1994 WR250-Z | 1997 KX500 | 1998 KLX300 | 2004 CRF450R (Motard) | 2009 KX450F | 2001 XR650R | 1992 WR200R | 1992 WR500-Z | 1986 GPZ900 | 2005 RMZ450 | 1986 CR500AF in a 1998 CR250R frame | all street legal
"Great! What am I supposed to use now?! Harsh language?"
- Duke Nukem
Sub Zero is offline   Reply With Quote
Old 09-30-2012, 01:29 PM   #47052
Barron
M0DAH0LIC
Barron's Avatar
Oddometer: 2,454
Soooooooooo you thinking about getting another one soon? Please? I really want to send you a tank to make bigger...
Old 09-30-2012, 01:32 PM   #47053
cyclewizard
cyclewizard's Avatar
Oddometer: 4,814
That is so sweet I think I'm going to pee myself.
C-dub......
Powered by CW-Pistons/cams
Wizard manufacturing....
cyclewizard is offline   Reply With Quote
Old 09-30-2012, 01:54 PM   #47054
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 7,095
Is there an ECHO IN HERE?
Yes safe. No chance of ED.
Regards
Fritzcoinc
96 XR650L, 96 Guzzi Sport, 07 BMW K1200GT,
86 Husky 400 XCE, 00 Husky Te 610 e, 1999 Husky TC610 SM, 2000 Cagiva GC; Google: TX7
fritzcoinc is offline   Reply With Quote
Old 09-30-2012, 01:59 PM   #47055
mendoteach
mendoteach's Avatar
Oddometer: 1,616
The only thing it was missing was a 780cc, 12:1 comp., race fuel only CW BEAST motor. Even with 32 horsepower you can still hall balls if you don't have to slow down and that thing looks like it corners sweet. Someday, Kubiak, you will return to the fold. Admit, it's calling you.
Times are GMT -7.   It's 05:33 AM.
